South Carolina BS thread under new MANAGEMENT and lives in SC
Discussion in 'South East' started by ahspurlock, Jan 18, 2016.
  1. Mar 11, 2019 at 9:54 AM
    Tartan Jack
    Tartan Jack Rockin It Old School
    Clinton, SC
    “Sports Cart” -1995 Taco, 2.4 2wd, Manual Everything
    Interior “retroficaton” (in progress) Airbag removal (1st gen/high explosive type) Hard Tonneau (on it when I got it) New grill, with custom badge Light Steelies S-Runner suspenion
    Anyone want to help me replace a fuel filter & pump?
    Like Fri,Sat, or Sun this weekend?
    That’s what the 1st gen forum people think it is.
    Not an expensive part, but hard to get to-unless you lift off the bed- need people.
    Or have the local mechanic fix it?
    scottalot, EricL and Matic like this.
  2. Mar 11, 2019 at 9:59 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    You're only an hour away. I can lend a hand if need be.
    scottalot and EricL like this.
  3. Mar 11, 2019 at 10:00 AM
    Matic
    Tricky Dick
    Easley, SC
    You got air and impact stuff? Plenty of tools.
    I can imagine the bed bolts might give you problems.
  4. Mar 11, 2019 at 10:02 AM
    Tartan Jack
    Clinton, SC
    Only socket & box wrenches & a few others (basic stuff)
    No impact or air tools.
    Matic and EricL like this.
  5. Mar 11, 2019 at 10:03 AM
    EricL
    EricL Tomahawk Chopper
    Greenwood, SC
    2015 Slowmobile
    SOS Offroad Concepts Armor
    I can probably help if all you need are some extra hands, but I bring pretty much nothing to the table in regards to mechanical knowledge.
    Except batteries and windshield wipers. I can change those out all day long. :laugh:
  6. Mar 11, 2019 at 10:07 AM
    Tartan Jack
    Clinton, SC
    Parts (pump & filter- about $110 on Amazon (Toyota/Denso)
    The 1st gen forum estimates 400-500 for a shop to do it.
    Edit:
    That is, or course, assumng fuel pump/filter is thd problem ...
  7. Mar 11, 2019 at 10:20 AM
    Tartan Jack
    Clinton, SC
    When the Miata’s fuel pump was going, it was “stuttering” in corners.
  8. Mar 11, 2019 at 10:26 AM
    Matic
    Tricky Dick
    Easley, SC
    Garage?
  9. Mar 11, 2019 at 10:32 AM
    Tartan Jack
    Clinton, SC
    Nope- I do work in the driveway or under a shade tree.
    Old house
    Not being totally sure it WAS the fuel pump, I will just risk the mechanic
    They estimated 150-200 for labor, plus parts.
    (fingers crossed)
    Matic[QUOTED] likes this.
  10. Mar 11, 2019 at 10:34 AM
    Tartan Jack
    Clinton, SC
    I was going to swap back to the Miata for the next few days anyways, now the rain broke.
    Not the way I wanted to do it ...
  11. Mar 11, 2019 at 10:38 AM
    JayDub
    JayDub Well-Known Member
    Jay
    Pendleton, SC
    06 Tacoma DCSB 4x4
    White camper top for 1st gen Taco in Anderson
    ahspurlock[OP], SwampYota and Matic like this.
  12. Mar 11, 2019 at 10:55 AM
    Matic
    Tricky Dick
    Easley, SC
    Damn.
  13. Mar 11, 2019 at 11:11 AM
    ahspurlock
    ahspurlock [OP] The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD
    Front long travel and Rear long travel including upper and lower rear control arms. Running 456 gears with rear ARB locker . LFD full roof rack with clamshell RTT
    Oh yeah
    saundern[QUOTED] likes this.
  14. Mar 11, 2019 at 11:14 AM
    ahspurlock
    Adam
    just drop the tank down alot easier
    that's not to bad for labor
    scottalot and ovrlndkull like this.
  15. Mar 11, 2019 at 11:21 AM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Dang, too bad it’s for a DCSB. That’s a great price.
    Matic likes this.
  16. Mar 11, 2019 at 11:25 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    There are 4. 2 are in the exhaust manifolds just before the cats and 2 in the y pipe close to where it bolts to the manifolds
    ahspurlock[OP] likes this.
  17. Mar 11, 2019 at 11:38 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Just a note, while ones from an 05 and 09 look interchangeable, the wire length is different because on newer models they changed the location of the bung on the pipe.
  18. Mar 11, 2019 at 11:49 AM
    Matic
    Tricky Dick
    Easley, SC
    I messaged him and asked about keys.
    Says it's nearly new...but idk about that.
    To bad I don't have a frame lying around, would make a nice pull behind OR camper.
  19. Mar 11, 2019 at 11:59 AM
    Tartan Jack
    Clinton, SC
    That’s kinda what I was thinking ...
    Mount a frame & axle to make a trailer.
    Matic[QUOTED] and ahspurlock[OP] like this.
  20. Mar 11, 2019 at 12:11 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    Generally a fuel pump doesn’t just quit while running, it’s possible, but not normal. Check fuses, it may have gotten to the point it was drawing a lot of amps and blew fuse.
    BUT ! Before you buy anything, spray carb cleaner in throttle body while someone is cranking it over, that will at least verify if you have a fuel or spark issue.
    It’ll start and maybe run on carb cleaner for a second or 3 if it’s a fuel issue
    scottalot likes this.
