South Carolina BS thread under new MANAGEMENT and lives in SC
Discussion in 'South East' started by ahspurlock, Jan 18, 2016.
  1. Jan 27, 2020 at 10:53 AM
    ahspurlock
    ahspurlock [OP] The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD on 37s
    Rear full long travel including upper and lower rear control arms. 37s Mickey Thompson Baja boss MT,
    They will
    klavender1 and JimboAnz like this.
  2. Jan 27, 2020 at 11:03 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    I ran 5100 / 886, they worked. most mfr say it wont, or that you shouldn't, I never had an issue, no blown shocks :thumbsup:
    klavender1 likes this.
  3. Jan 27, 2020 at 11:09 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    I also ran a 3/8" spacer on top of that, which "you shouldnt do", but I did, and it was fine. Was it the best smoothest ride in the world? hell no, but it kept the front end up where it needed to be :muscleflexing:
    SC2SC and Jeffvt0508 like this.
  4. Jan 27, 2020 at 11:10 AM
    klavender1
    klavender1 Well-Known Member
    Columbia/Lugoff, South Carolina
    2005 GX 470
    Good to know. However that still only gives me an extra .5". I need at least 1". That would put me back at 22" in the front. Which is still less than I originally thought when I installed the kit.
    JimboAnz[QUOTED] likes this.
  5. Jan 27, 2020 at 11:15 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    I quoted my own post above :anonymous:
    "I also ran a 3/8" spacer on top of that, which "you shouldnt do", but I did, and it was fine. Was it the best smoothest ride in the world? hell no, but it kept the front end up where it needed to be :muscleflexing:"
    Chunk and klavender1[QUOTED] like this.
  6. Jan 27, 2020 at 11:17 AM
    klavender1
    2005 GX 470
    Ah missed that.
    Chunk and JimboAnz[QUOTED] like this.
  7. Jan 27, 2020 at 11:19 AM
    klavender1
    2005 GX 470
    So the 886 to gain some height back but to also account for the additional weight on the shocks? Then spacers as well to get the full height?
  8. Jan 27, 2020 at 11:19 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    What springs are you on now? 884 maybe i recall? 887 are taller, same spring rate, they even make an 888 which is for turd gens, taller yet, same spring rate. I dont know of anyone that has put 888 on a second gen 5100 shock, but may be worth exploring
  9. Jan 27, 2020 at 11:20 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    bingo :thumbsup: 886 are the stiffies, no two ways about that. 884/885/887/888 are all same spring rate, just different heights (888 being the tallest)
    klavender1[QUOTED] likes this.
  10. Jan 27, 2020 at 11:22 AM
    klavender1
    2005 GX 470
    Yes I'm on 884s now.
    Where can you find 3/8" spacers?
  11. Jan 27, 2020 at 11:25 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    second hand maybe, headstrong sells em, wheelers sells em, along with a host of others. you likely need to press in longer studs for the spacer though, I remember it being close, We did press in longer studs when we did mine with the help of @ahspurlock
    keep in mind, a 3/8" spacer ""should"" yield double that in actual lift +/- due to the geometry and the placement of the spacer in the overall system, angle of the dangle type stuff
  12. Jan 27, 2020 at 11:43 AM
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    Ah shit
    I was going to get them for your birthday present. Oh Well :cheers:
    ahspurlock[QUOTED][OP] and Chunk like this.
  13. Jan 27, 2020 at 11:57 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    why wouldn’t they work?
  14. Jan 27, 2020 at 12:09 PM
    klavender1
    2005 GX 470
    They don't according the Headstrong's website. But others have chimed in and said yes.
    JimboAnz likes this.
  15. Jan 27, 2020 at 12:09 PM
    klavender1
    2005 GX 470
    Headstrong sells 1/2" which is close enough.
  16. Jan 27, 2020 at 12:11 PM
    klavender1
    2005 GX 470
    Will the 884/885/887/888 spring rate be sufficient for the added weight? If so I'd prefer not to have a rougher ride.
  17. Jan 27, 2020 at 12:12 PM
    Daria
    Daria Can I pet your dog? Moderator
    Dodging tumbleweeds
    I ran 886s and 885s on my 5100s back when I had a 2013 Tacoma.
    JimboAnz and klavender1[QUOTED] like this.
  18. Jan 27, 2020 at 12:17 PM
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    886s are fine when you add the weight to them. I currently have them with a front bumper and winch. The ride is better than stock but not as good as a Cadillac.
  19. Jan 27, 2020 at 12:19 PM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    maybe, definitely something to ponder. 886's are stiff indeed.
  20. Jan 27, 2020 at 12:51 PM
    klavender1
    2005 GX 470
    My current setup (before the weight) is slightly stiffer than stock. So sounds like 886s plus spacers. Since according to Wheelers, 886 is made for an additional 110-220lbs up front.
    Also, any thoughts on poly vs aluminum spacers?
    Also also, Wheelers claims 11/16" of lift with their 1/2" spacers. Headstrong says 1" of lift with their 1/2" spacers.
    Sorry for all the newb questions.
