South Carolina BS thread under new MANAGEMENT and lives in SC
Discussion in 'South East' started by ahspurlock, Jan 18, 2016.
  1. Feb 9, 2020 at 3:18 PM
    klavender1
    klavender1 Well-Known Member
    Columbia/Lugoff, South Carolina
    2005 GX 470
    My temporary solution.
    scottalot likes this.
  2. Feb 9, 2020 at 4:04 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Make sure that threshold is angled toward the exterior
    JimboAnz likes this.
  3. Feb 9, 2020 at 6:31 PM
    klavender1
    2005 GX 470
    It is. But if enough water builds up it just runs under the door anyways.
    ovrlndkull[QUOTED] likes this.
  4. Feb 9, 2020 at 10:24 PM
    apy_camper
    apy_camper APY CMPR
    Christian
    Fredericksburg, VA
    2015 MGM DCLB SR5
    SR5 package Tow package A.R.E. midrise camper shell with roof rack
    Looking good! Glad I could have a hand in making it come to fruition...and it's provided a little inspiration for some upgrades I've been looking to settle on. I've been looking to budget for adding a Slimline front bumper, sliders and lift...how much did the suspension package run ya, if you don't mind, as I need to start to plan/budget my long term solution.
    klavender1[QUOTED] likes this.
  5. Feb 10, 2020 at 3:25 AM
    klavender1
    2005 GX 470
    Initially, I started out with a package from Headstrong Offroad. Good prices and excellent customer service. I went with OME 884 coils, Bilstein 5100 shocks and their 3 leaf AAL for the rear. I want to say it was around $700 at the time. For a stock access cab, I gained 1.75" front lift, 2" rear lift leaving in the overload spring. That combo rode slightly stiffer than stock.
    Since adding the front bumper and winch (approx 130lbs), I lost about 1"of lift in the front on the 884s.
    I went back and forth on how to get front lift back. Ended up getting a great deal on 886 coils and front OME shocks from @SearArtist. So I installed the 886s on the 5100s. With this combo, I'm at a 2.75" lift in the front. So the truck is pretty level. I'm at 23" hub to fender front and 24" rear. So far I love the ride. Some complain the 886s are too stiff but so far I think it's perfect with the extra weight up front.
    So if you were to buy a 886/5100 package to start, I'd probably say in the $700-$800 range.
    I'm not using the front OME shocks for now. But I'm going to save them just in case the 5100s don't work out with the 886s. Then I'll only have to buy rear shocks. Because technically the valving on the 5100s aren't supposed to work with the 886s. However, some people seem to love that combo, some people don't.
    saundern likes this.
  6. Feb 10, 2020 at 4:54 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Ah, I was picturing a bit different in my head, I didn't realize that it was right there at your doorway. I thought you were just getting seepage through the base of your wall due to standing water. You might want to look at something like a channel drain which might be better for your situation. https://www.homedepot.com/p/U-S-TRE...hannel-Drain-with-Black-Grate-83500/302782454 They can be cut to length and tied into your french drain and you wouldn't need to worry about water intruding under your doorway. You would set it in place prior to pouring concrete. If you put a water dam on your roof or some gutters to assist with the redirection of the water so you're not getting direct runoff from your roof, that would help too. If you don't want to hand jam that trench, you could rent one of those trenchers from any local tool rental place. However, you'd still need to widen the trench if you used one of those little mechanical dudes, they only give you like a 4 to 6" wide trench and you'll need a trench that can accommodate the 4" perf pipe as well as at least 6" wide of gravel base on each side of the pipe, hence the 2 to 3' wide trench. You could use it to dig 2 parallel trenches and then spade out the middle dirt, that could work too.
    -J
  7. Feb 10, 2020 at 6:11 AM
    klavender1
    2005 GX 470
    I have gutters and that has helped. It only happens after torrential rain or after several days of rain. Where the ground gets waterlogged and the water has nowhere else to go. I'm going to get some quotes on having it done. I've had good luck before using Lowe's professional services. At least get an idea on the cost.
  8. Feb 10, 2020 at 6:26 AM
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    I'm all about attempting to do things myself so I try to let you know what you're in for. Is there anywhere in your yard that slopes away from your house? Typically either sloping towards the back yard or towards the street is where I would run the french drain. I really like that popup emitter at the street and it's only like 12" or so below where I'm pulling the water from. You may not need to do a run all the way to the street if there's a better place to push the excess water to.
    -J
  9. Feb 10, 2020 at 6:49 AM
    ahspurlock
    ahspurlock [OP] The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD
    Front long travel and Rear long travel including upper and lower rear control arms. Running 456 gears with rear ARB locker . LFD full roof rack with clamshell RTT
  10. Feb 10, 2020 at 6:58 PM
    Bandit
    Bandit Road Warrior
    SC
    2021 TRD OR DC 4x4
    Debadged, decals removed ARE V series Camper Shell, RallyArmor mud flaps I’m old, my truck is boring
    Dakars installed and icons cranked up. 25” hub to fender in the rear
  11. Feb 10, 2020 at 7:01 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Norkle.
    Bandit[QUOTED] likes this.
  12. Feb 10, 2020 at 7:35 PM
    Bandit
    Bandit Road Warrior
    SC
    2021 TRD OR DC 4x4
    Pretty sure that was my fist mod on this truck. :oldglory:
    Matic[QUOTED] and ahspurlock[OP] like this.
  13. Feb 11, 2020 at 6:23 AM
    HrBrad8
    HrBrad8 Well-Known Member
    Brad
    Charlotte
    2018 ZR2
    did you find the spacer? i know i still have one somewhere in the garage.
  14. Feb 11, 2020 at 6:27 AM
    klavender1
    2005 GX 470
    I never did. So I just ordered one from Amazon so we could get the alignment done today. I appreciate it though!
  15. Feb 11, 2020 at 8:42 AM
    Bandit
    Bandit Road Warrior
    SC
    2021 TRD OR DC 4x4
    Who needs TSB leafpacks with less than 10,000 miles on them?
    Matic and ahspurlock[OP] like this.
  16. Feb 11, 2020 at 8:45 AM
    Bandit
    Bandit Road Warrior
    SC
    2021 TRD OR DC 4x4
    I’ve been hoarding Tacoma parts
    265/60r18 tires on Maverick rims
    2 spidertrax hub centric1.25” wheel spacers
    2 hub centric 1.5” wheel spacers
    OEM UCAs
    OEM LCAs (need rebuild)
    2019 TSB leafpacks
    1” rear block with u bolts
    Front aluminum spacer 3” lift I think. Might be 2.5”
    ahspurlock[OP] likes this.
  17. Feb 11, 2020 at 9:29 AM
    KILLINTIME
    KILLINTIME Like a Villain
    What brand are the 1.5” spacers
    PlumpPossum likes this.
  18. Feb 11, 2020 at 9:30 AM
    Bandit
    Bandit Road Warrior
    SC
    2021 TRD OR DC 4x4
    G-tech I believe. Hub centric. Ran them with zero issues.
  19. Feb 11, 2020 at 9:39 AM
    KILLINTIME
    10/4 thanks
  20. Feb 11, 2020 at 9:44 AM
    Bandit
    Bandit Road Warrior
    SC
    2021 TRD OR DC 4x4
    Just went and checked. They are actually “G2” wheel spacers
