South Carolina BS thread under new MANAGEMENT and lives in SC
Discussion in 'South East' started by ahspurlock, Jan 18, 2016.
  1. Apr 2, 2020 at 5:00 PM
    Bubbles
    Bubbles Liquor and Whores
    Sunnyvale Trailer Park
    When all this nonsense blows over. Cant take one on the water, why buy something you can't test drive?
    Whaler most likely
    :anonymous:
  2. Apr 2, 2020 at 5:02 PM
    Bubbles
    I'd love to find a clean, original super sport center console from the 80's with a 70hp Yamaha on it.
    scottalot[QUOTED] likes this.
  3. Apr 2, 2020 at 5:12 PM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    I do love some teak...
    Bubbles and scottalot[QUOTED] like this.
  4. Apr 2, 2020 at 5:32 PM
    Bandit
    Bandit Road Warrior
    SC
    2021 TRD OR DC 4x4
    Debadged, decals removed ARE V series Camper Shell, RallyArmor mud flaps I’m old, my truck is boring
    Not sure... been looking at ARB because I’ve seen a lot of them and they seem to hold up well. Wynter seems a bit cheaper but don’t know how it would hold up. Dometic fridges look good too. Itd be used in my truck, in the garage, and maybe on the boat too
    Bubbles likes this.
  5. Apr 2, 2020 at 5:52 PM
    Bandit
    Bandit Road Warrior
    SC
    2021 TRD OR DC 4x4
    My co worker has his dads old center console with an inboard motor that doesn’t run. It’s a Sea Arrow out of Texas and has a V8. Trying to work on it this summer.
    Bubbles[QUOTED] likes this.
  6. Apr 2, 2020 at 6:02 PM
    Bubbles
    scottalot[QUOTED], SC2SC and Apexgigi like this.
  7. Apr 3, 2020 at 3:12 AM
    ahspurlock
    ahspurlock [OP] The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD
    Front long travel and Rear long travel including upper and lower rear control arms. Running 456 gears with rear ARB locker . LFD full roof rack with clamshell RTT
    sweet
    were are you located at
  8. Apr 3, 2020 at 3:24 AM
    Frsh2df
    Frsh2df Well-Known Member
    2017 MGM TRD Off Road 4x4
    Bluffton , SC
  9. Apr 3, 2020 at 3:56 AM
    ahspurlock
    Adam
    Ok . I'm in Summerville/Charleston SC. But I'm pretty sure we can figure something out
  10. Apr 3, 2020 at 4:00 AM
    Frsh2df
    Sounds good, I appreciate it. Now I just have to figure out shipping , since I can’t pick them up anymore.
  11. Apr 3, 2020 at 4:01 AM
    ahspurlock
    Adam
    Oh yeah lol
  12. Apr 3, 2020 at 4:08 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Yeah stopped taking pickups and installs until this stuff clears up. It sucks!
  13. Apr 3, 2020 at 4:34 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Like others have said, Go with Raid 0 and put your OS on a SSD. If you build your raid in the BIOS, it should be able to swap with your OS fairly straight forward. Linux can also read in every drive format that windows operates in. If you use windows to create your Raid, you'll have to do some SUDO-fu in Linux to access the Raid. Dual boot Linux with Windows (as in: install Linux first for the boot loader, then Windows) to check your raid setup before you commit with important files that become unrecoverable once you fully run Linux. I run Ubuntu as my primary OS as it's the easiest for a windows user to transition over to and I haven't looked back. If you're a power user, then you probably wouldn't be asking us for assistance, heh. It's been a looong time since I built a PC, but my WD drives came with a setup disk utility that could create hardware Raids pre OS install. If your drives didn't, check out something like a Raid manager or Drive manager. I did a quick search but nothing was peaking my memory (from 20 years ago, mind you .. :puke:) Everything was turning up "for Windows"
    Maybe I'm mistaken and you can only do this from your BIOS. Do that first, set your raid up in your BIOS, don't use any software Raid config shit through windows.
    -J
    JayDub likes this.
  14. Apr 3, 2020 at 4:37 AM
    ahspurlock
    Adam
    So that means I can't come up and hang out :rofl:
  15. Apr 3, 2020 at 4:39 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Mebbe you probably have a lot more time on your hands now :rofl:
    scottalot likes this.
  16. Apr 3, 2020 at 4:40 AM
    ahspurlock
    Adam
    Honestly this week I've been balls to the wall with work I'm already sitting at 61 hours and I still have the rest of the day to go lol .
    scottalot, Bandit, dan0mite and 2 others like this.
  17. Apr 3, 2020 at 5:10 AM
    Bubbles
    Hell yeah bro!
  18. Apr 3, 2020 at 5:15 AM
    ahspurlock
    Adam
    Yeah . I'm worn out too .
  19. Apr 3, 2020 at 5:25 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    My sudo-fu is on par, just haven't used raid, especially trying to jump it between os's. I'm trying to use what I have until I build out a new rig. As said a couple times, OS is already on a seperate drive from the data raid I want to build. I think mobo raid is out because if the mobo dies or I swap platforms the raid is basically scrapped. FakeRAID might be the best option unless I want to use some sudo-fu with mdadm or the like after the switch to Linux. When I actually do the swap to Linux I'll usb boot it to make sure I can get things to work before I wipe out Win10.
    ahspurlock[OP] likes this.
  20. Apr 3, 2020 at 5:53 AM
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Thats the risk we take with Raid arrays. You already mentioned earlier that you have an offsite backup for your data I believe. If you dont, you might want to look into Raid 10. It's a hybrid of Raid 0 (striping) and Raid 1 (mirroring). Basically, you'd I/O out of your Raid 0 drives and pair your data with a backup drive, albeit much larger drive requirements. That way, in the event you loose a Raid 0 drive, you have backup from your mirrored drive and vise versa. You can config auto backups to occur at set intervals to ensure you have an up-to-date backup similarly as you would save to the cloud. I cant remember exactly if, in the event your mobo dies, if you could swap the HDD's to a new mobo using the same numbered SATA ports if its the same chipset. Maybe that's asking too much, like I said prior, I've been out of the building game for 20 some odd years. Architecture and form factor have probably changed a bit since the early 2000's.
    -J
