South Carolina BS thread under new MANAGEMENT and lives in SC
Discussion in 'South East' started by ahspurlock, Jan 18, 2016.
  1. Jul 14, 2022 at 3:30 PM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    Yes I am.
  2. Jul 14, 2022 at 3:49 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    well, I’m out. I’ll clean up those junk tunes later down the road I suppose. Have fun.
    ahspurlock[OP] likes this.
  3. Jul 14, 2022 at 5:02 PM
    Daria
    Daria Can I pet your dog? Moderator
    Dodging tumbleweeds
    Yes.
    Chunk[QUOTED] likes this.
  4. Jul 14, 2022 at 7:00 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    https://www.destinationoutdoor.com/
    My wife, probably kid too, plan on attending this. Trail ride, trail clean up, and all the new Toyotas will be there. Sponsored by Toyota. Anyone else going?
    RedDeadTaco likes this.
  5. Jul 14, 2022 at 7:20 PM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Looks like a good time, I might try to make it with the family.
    AzogSS[QUOTED] likes this.
  6. Jul 15, 2022 at 6:11 AM
    jayandersen5
    jayandersen5 Well-Known Member
    Jay
    South Carolina
    2017 TRD Pro
    OTT Tuned Yukon 5.29s 35x12.50r17 Yokohama MTs RRW RR7-H Wheels Dobinsons MRRs RRW hybrid front bumper ATH rear swing out high clearance bumper Alucab Explorer Canopy iKamper skycamp 2.0 Diode Dynamics SS3 (x4) and SSC2 SOS Sliders C4 full skids Smittybilt X20 Gen3 10k winch Prinsu Cabrack Expedition Essentials 3TPAM Caliraised 40" light bar ExtremeLED 30" light bar Total Chaos spindle/cam tab gussets and bed stiffeners Switch Pro SP9100 Power Tray
    If you want to put on a raffle for a free tune we could definitely work something out! The group isn't specific to Tacoma's however.
  7. Jul 15, 2022 at 8:54 AM
    klavender1
    klavender1 Well-Known Member
    Columbia/Lugoff, South Carolina
    2005 GX 470
    Any electric hot water heater experts here? Had the whole house replumbed last Saturday, including the lines running to the hot water heater. For that to happen, the tank had to be drained and moved. I noticed Sunday morning and Thursday morning the breaker was tripped when I woke up to a lukewarm shower. It's just weird that it happened several days apart. It seems like the element was an issue, it would trip immediately.
    My initial thoughts are twofold.
    1. Moving around a 9 year old heater caused some heating element issues.
    2. The tank wasn't fully full before power was reapplied.
    I can replace both elements and thermostats with a $35 kit from Lowe's. Easy to do. However, both elements test good. They are supposed to read between 10-16ohms depending on their wattage. Mine are 4500 watts and read 12.4ohms. Maybe just outside of what they should be? I can't imagine basic hot water heaters are that smart. Maybe the breaker needs replacing?
    If I have to replace the whole unit, I'm going with a gas tankless. But since I just spent $2400 having the house replumbed I'd like to get more life out of this heater.
  8. Jul 15, 2022 at 9:34 AM
    ahspurlock
    ahspurlock [OP] The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD
    Front long travel and Rear long travel including upper and lower rear control arms. Running 456 gears with rear ARB locker . LFD full roof rack with clamshell RTT
    I'd be looking at wiring connections from where they disconnected it to move it. Could be a chance of the elements just from moving it around .
    klavender1[QUOTED] likes this.
  9. Jul 15, 2022 at 10:15 AM
    klavender1
    2005 GX 470
    I looked at the connections and that looks good. Talked to a friend at lunch about it. He thought probably the breaker. Since the breaker hadn't been touched in years and now it moved. His idea was to turn it off and on a bunch to clean the contacts.
  10. Jul 15, 2022 at 10:31 AM
    ahspurlock
    Adam
    That's a very good possibility too
  11. Jul 15, 2022 at 10:39 AM
    Badknees
    Badknees Well-Known Member
    Kenny
    Anderson, SC
    1998 Tacoma Extended Cab SR-5 4X4
    King Front Coil-overs, Bilstein Rear Shocks, Add-a-leaf Rear Leaf Springs, 16" Toyota Wheels, KO2 Tires, Alpine 2-Din Head Unit, Alpine Amp, JBL GTO Speakers, Undercover Hard Bed Cover, Back-up Camera
    If you can get your hands on an ammeter, check when the hot water heater is under full load and see if it's pulling more amps than the breaker is rated. If not, then it's probably the breaker.
    Best.
  12. Jul 15, 2022 at 11:34 AM
    klavender1
    2005 GX 470
    Test it at the thermostat where the wires come into the top thermostat?
    Badknees[QUOTED] likes this.
  13. Jul 15, 2022 at 12:48 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I just had this happen in my house. I turned off my well pump to replace the whole house water filters, and when i went to turn the breaker back on it was just limp...took it out and it had blown out the side of the breaker. No telling how old it was or last time it was flipped, but I guess they do eventually go bad. They are like $5 so I'd start there.
  14. Jul 15, 2022 at 1:06 PM
    klavender1
    2005 GX 470
    I hope not. It's harder to find Stab Lok breakers.
    FastEddy59 likes this.
  15. Jul 15, 2022 at 2:09 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Had a brand new Federal panel in the garage/shop just when all this BS started. Found out what happened @ Federal then proceeded to shuck said unit for X3 $ & get the Bigger panel I figured I’d never need but really did.
  16. Jul 15, 2022 at 6:10 PM
    RedDeadTaco
    RedDeadTaco The Hipster Woodsman
    Andrew
    Aiken, SC
    '16 Barcelona Red OR
    Mobtown Sliders, Aluminum Skids Bilstein 6112/Extended 5100’s Iron Man constant load leafs JBA High Caster UCA’s Diamond Back Tonneau 285/75/r16 Cooper STT Pros Method 702’s Uptop Overland Alpha Roof Rack
    Probably will go with the gf. Could convoy over there.
    w.adventures[QUOTED] likes this.
  17. Jul 17, 2022 at 11:22 AM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    any of you people ever gone to capers island and camped? im taking somebody there to drop off and Ive never been there.
  18. Jul 17, 2022 at 11:33 AM
    Tyrone_843
    Tyrone_843 Well-Known Member
    Charleston, SC
    2019 Cement Gray 4x4 TRD Off-Road
    Some good spots on the beach to hang a hammock just make sure you bring some bug spray! The inner salt water ponds have some monster reds and flounder but they are also loaded with gators. It’s a cool spot just go prepared.
  19. Jul 17, 2022 at 11:51 AM
    jpneely
    Charleston, SC
    Where do you anchor up? North or south side?
  20. Jul 17, 2022 at 12:06 PM
    Tyrone_843
    Charleston, SC
    Drop these coordinates into google. It’s the perfect little creek to anchor, just keep an eye on the tides. (32.8528124, -79.7017849)
    ahspurlock[OP] and jpneely like this.
