South Carolina BS thread under new MANAGEMENT and lives in SC
Discussion in 'South East' started by ahspurlock, Jan 18, 2016.
  1. Aug 4, 2023 at 5:46 AM
    Shibbyjeep
    Shibbyjeep Well-Known Member
    Trent
    Greenville SC
    2014 Tacoma DCSB TRD OR
    Do it
  2. Aug 4, 2023 at 11:04 PM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
  3. Aug 5, 2023 at 3:43 AM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Dang, somebody break in? Or did you lock yourself out and finally get to use that krazy beaver shovel?
  4. Aug 5, 2023 at 4:44 AM
    ahspurlock
    ahspurlock [OP] The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD
    Front long travel and Rear long travel including upper and lower rear control arms. Running 456 gears with rear ARB locker . LFD full roof rack with clamshell RTT
    Damn what you do .
    Did that girl you have locked up in the closet finally get out and run :rofl:
    OCD 08 and w.adventures like this.
  5. Aug 5, 2023 at 5:06 AM
    scottalot
    scottalot Well-Known Member
    Scott
    Can’t tell from the pic- is that a molded door? If not you can most likely just replace the glass
  6. Aug 5, 2023 at 5:42 AM
    Jeffvt0508
    Jeff
    Anderson, SC
    So I locked myself out of the house, left my phone in the house, neighbors wouldn't come to the door.. so I took my Halligan bar and pried the door open and when I couldn't get the dead bolt out I had to break the glass..
  7. Aug 5, 2023 at 5:49 AM
    JimboJones
    JimboJones A tradition since last week.
    Jim
    Apex NC
    2019 Offroad Magnetic Gray
    To be honest I have had good luck recently from buying the door at Home Depot and having them schedule an installer. It took a couple weeks but they were prompt and did a great job. Wouldnt even let me tip him. Neighbor said the same thing about Lowe's.
    w.adventures likes this.
  8. Aug 5, 2023 at 8:39 AM
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    So how you lock yourself out of the house with a deadbolt? Common sense says all deadbolts need to turn by a key from the outside? :bananadead:
  9. Aug 5, 2023 at 9:23 AM
    Jeffvt0508
    Jeff
    Anderson, SC
    It was the door I chose to break into.. my back door and French doors were too expensive.. it's the only 1 that was sacrificial at the time.. looking back I should have broken A window but I started by drilling out the lock hoping it would be an easy fix and it didn't work ( drills were in my work van)
  10. Aug 5, 2023 at 2:29 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I learned my lesson the hard way many years ago. Now, at least one door will always have a keypad lock so it’s impossible to be locked out.
  11. Aug 5, 2023 at 4:44 PM
    Bandit
    Bandit Road Warrior
    SC
    2021 TRD OR DC 4x4
    Debadged, decals removed ARE V series Camper Shell, RallyArmor mud flaps I’m old, my truck is boring
    For $6 you can buy a premade bump key and open any house door :spy:
    ahspurlock[OP] likes this.
  12. Aug 5, 2023 at 5:42 PM
    Jeffvt0508
    Jeff
    Anderson, SC
    EODTRD, 01Tac0ma and OCD 08 like this.
  13. Aug 6, 2023 at 5:33 PM
    Jeffvt0508
    Jeff
    Anderson, SC
    Yea I called them and they were out 4 weeks so I ponied up and just did it myself.. I just was being lazy and didn't want to cause in the summer I get lazy lol
  14. Aug 6, 2023 at 5:42 PM
    JimboJones
    Jim
    Apex NC
    Looks like you did a great job. Kudos!
    Jeffvt0508 likes this.
  15. Aug 6, 2023 at 5:52 PM
    Jeffvt0508
    Jeff
    Anderson, SC
    So I did something to my ikamper that I kinda regret but honestly I'm glad I did it. The inner liner "quilted map" was coming off the hard top so I pulled it off to redo it.. well when I did I saw that the inner fiberglass shell was cracked ... and wasn't attached well. I took a Dremel and cut it out. To my surprise the struts aren't reinforced and i feel that is a weak point long term. I'm going to fiberglass the inside and use fiberglass filler to smooth out the "ugly" and strengthen up the 2 struts and block them up. I'm then going to either reglue the map back the right way.. or I'm going to attach a molle panel and attach light objects to it during camping. Im going to roll truck bed liner as the finish. Now for the progress photos: 20230805_140649.jpg 20230806_093946.jpg
    01Tac0ma, banditcamp and w.adventures like this.
  16. Aug 6, 2023 at 5:53 PM
    Jeffvt0508
    Jeff
    Anderson, SC
    Thanks
  17. Aug 7, 2023 at 1:47 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Isn't that thing new?
  18. Aug 7, 2023 at 2:55 PM
    Jeffvt0508
    Jeff
    Anderson, SC
    Freak yea... I was like wtc.. and I put in a warranty claim but I looked on a different forum and the guy was waiting over a yr and didn't hear back so I took matters into my own hands.. the shell itself let's in light in areas so you know the fiberglass is thin...
  19. Aug 7, 2023 at 2:57 PM
    Jeffvt0508
    Jeff
    Anderson, SC
    If I had known all these troubles I would have went a different route but I love that it fits over my bed and doesn't have to go over my cab
  20. Aug 7, 2023 at 3:07 PM
    Jeffvt0508
    Jeff
    Anderson, SC
    Things aren't made like they once were... I did reach out to ikamper other than warranty to see if I can purchase a new shell.. but I fear it would have same issues
