South Carolina BS thread under new MANAGEMENT and lives in SC
Discussion in 'South East' started by ahspurlock, Jan 18, 2016.
  1. Nov 5, 2023 at 5:26 AM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Dang kids were hovering over my bed at 6am. Forgot they thought it was 7 :annoyed:
  2. Nov 5, 2023 at 5:57 AM
    ahspurlock
    ahspurlock [OP] The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD
    Front long travel and Rear long travel including upper and lower rear control arms. Running 456 gears with rear ARB locker . LFD full roof rack with clamshell RTT
    :rofl:
  3. Nov 5, 2023 at 4:05 PM
    ahspurlock
    Adam
    So I'm selling my new 35s if anyone is interested
  4. Nov 5, 2023 at 4:12 PM
    w.adventures
    Nowheresville, SC
    You forgot to put. I know what I have don’t low ball me.
  5. Nov 5, 2023 at 4:38 PM
    ahspurlock
    Adam
    Lol shit it wouldn't matter they still will .
    At $1200 they are stealing them at that price :rofl:
    w.adventures[QUOTED] likes this.
  6. Nov 5, 2023 at 6:25 PM
    Weatherby789
    Weatherby789 Well-Known Member
    Charleston SC
    2023 MG DCSB TRDOR
  7. Nov 5, 2023 at 6:25 PM
    Weatherby789
    Charleston SC
    2023 MG DCSB TRDOR
  8. Nov 6, 2023 at 3:38 AM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    Nice! its a great time of year for them right now.
  9. Nov 6, 2023 at 3:59 AM
    Weatherby789
    Charleston SC
    2023 MG DCSB TRDOR
    Yeah, it is. Got lucky and ran into a school yesterday.
    ahspurlock[OP] likes this.
  10. Nov 6, 2023 at 4:28 AM
    ahspurlock
    Adam
    Got 1 of the 37s mounted up lol 3 more to go :rofl:PXL_20231106_122250715.jpg PXL_20231106_122244218.jpg
    scottalot, klavender1, AzogSS and 3 others like this.
  11. Nov 6, 2023 at 4:30 AM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    Hit up the Francis Marion with some friends Sunday morning. Made me realize quick that I need some A/T tires if I want my 2wd to be capable.
  12. Nov 6, 2023 at 4:32 AM
    ahspurlock
    Adam
    Yep .you have a elocker in the rear
  13. Nov 6, 2023 at 4:41 AM
    noodles93
    Charleston, SC
    Sure don't. Open diff, momentum was my only friend. Re-gear with an LSD is on the list but man is that expensive since it's beyond my ability.
  14. Nov 6, 2023 at 4:42 AM
    ahspurlock
    Adam
    Yea . Probably be easier to order a complete 3rd member from East Coast gear supply
  15. Nov 6, 2023 at 5:21 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    So I started my truck projects this past weekend and I thought I'd make it easy and break it into chunks. I started with the rear suspension, pulled my 10yr old OME struts and replace with King 2.5 RRs but I thought I'd be able to quickly replace the bushings in my Dakar HD's. Built in '13 with the old pressed bushings. Once I pulled the front bolt and the spring popped out and I saw what I was going to have to deal with, I said F that, old rubber sleeved bushing. Had a whale of a time with straps and bottle jacks to bend and pull it back into place to stab the bolt back in. U-bolt flip kit had to get removed to finagle everything back into place so what "should" have been like a 3-4 hr job max for both sides turned into a 7 hr ordeal. I didn't undo the other leaf spring so that side went in quickly. What I need to do now is purchase a 21 or 22mm 1/2" deep well socket to make removing the U-bolts easier. Frustrating. I have the replacement OME poly bushings waiting on when I want to tackle completely removing the heavy Dakar springs and press out the bushings. Meh.
    Plan for next weekend since it's a long one:
    -New SPC UCA install (replacement bushings and UBJs cost nearly as much as a new UCA)
    -Replace LBJs and bushings with Mevotec TTX
    -Replace passenger side CV axle with Napa axle (rebuild kits are B/O nation wide)
    -Install Kings 2.5 RR up front / pull 10 yr old OMEs
    -Pan drain/fill trans fluid
    -Drop drive shaft and replace carrier bearing with OEM
    -Front diff drain/fill
    -Replace O2 non-foulers due to rust
    -Sand/polish headlights back to clear
    -Rotate tires (maybe, depends on how I feel, alignment will be due after all this work so I may just pay Firestone to rotate)
    I like working on the truck but damn my body hurts so much after it. Lots of squatting and bending. Definitely going to get a 2 post lift when I retire to get the truck higher into the air. I'm looking forward to it but not looking forward to dropping all the steel armor under the truck to get access to the underneath but it'll give me time to grind and repaint. Gonna be a long weekend. I did notice that one of the Kings in the rear had a small amount of oil on the body of the shock. I hope that it was just left over and not leaking. I don't know how they build Kings, if it's from the top or where the inner rod enters the shock body. If they unscrew the top of the shock then it might be an issue because that's were the fluid seems to be originating from. I'll just monitor over the next few weeks. I'm also chasing a rattle that sounds like it's coming from the passenger side of the truck. It's prevalent when the throttle increases slightly above idle, seems to be tied to RPM. While under the truck, I did notice that my Wicked Flows muffler has a crack at the back of the can that follows the weld. That might be the source of the rattle. Ugh. 11 Years on that exhaust is decent but it may be good to replace from the Y-pipe back. The URD pipe looks fine but I wont be able to check it better until that armor gets dropped. I'll replace the Vibrant performance resonator at that time as well with one that's more sized for my exhaust. I think I got 3" in/outlet, I'll step down to 2.5" so I don't have to do any shenanigans with the piping. OK, that's enough for now.
    -J
  16. Nov 6, 2023 at 5:22 AM
    ahspurlock
    Adam
    Yea it's a bitch when we get old lol
    JustAddMud[QUOTED] likes this.
  17. Nov 6, 2023 at 8:09 AM
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    Where are you fishing out of? I’ve been looking at adding a kayak to my garage?
  18. Nov 6, 2023 at 8:46 AM
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    I guess I should have followed up with my previous post, does anyone recommend a decent exhaust shop in the Summerville / North Charleston area that could spark up a Y-pipe back exhaust if I gave them the muffler & resonator?
    -J
  19. Nov 6, 2023 at 8:47 AM
    ahspurlock
    Adam
    Master bend muffler on trolley road
  20. Nov 6, 2023 at 10:53 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    You drive a Mustang :anonymous::burnrubber:
