South Carolina BS thread under new MANAGEMENT and lives in SC
Discussion in 'South East' started by ahspurlock, Jan 18, 2016.
  1. Mar 18, 2024 at 5:04 PM
    ahspurlock
    ahspurlock [OP] The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD
    Front long travel and Rear long travel including upper and lower rear control arms. Running 456 gears with rear ARB locker . LFD full roof rack with clamshell RTT
    Oh yeah
  2. Mar 18, 2024 at 5:34 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Thanks for the links. How do you like it? Any parts or characteristics you'd like improved? Just read up on the link kit. So if I'm interpreting things correctly, the upper links hitting the tank on compression, and the lower links contacting the axle on drop are the two limiting factors, given long enough shocks brake lines, and either longer springs or spring retainers?
    We were talking about doing a 3 link with a panhard, with the goal of getting a longer upper link, closer to the center. Would likely involve all new mounts on the axle, including a taller panhard mount., and of course a new upper link mount on the frame side.
  3. Mar 18, 2024 at 5:49 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    You can fit 35s in a few hours. You got this!
  4. Mar 19, 2024 at 2:23 AM
    ahspurlock
    Adam
    Correct that's why Apache off-road links are off set to clear the gas tank at full drop and the lower links are offset at the axle to help slide over thinks . Only think I might change later is the springs I'm running the Dobson heavy springs rated at 1000+ pounds but it's still not to bad tho
    colinb17[QUOTED] likes this.
  5. Mar 19, 2024 at 9:07 AM
    ahspurlock
    Adam
    Hell I need to come by and see what your doing to the taco lol plus you'll get to see the rear LT in person
  6. Mar 19, 2024 at 9:28 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Let me get a little further into the build. Still in disassembly mode, so nothing exciting to see. Once I get the frame chopped off and a few main tubes in place, let's do it!
  7. Mar 19, 2024 at 9:55 AM
    ahspurlock
    Adam
    Sounds good
  8. Mar 20, 2024 at 6:31 AM
    Bandit
    Bandit Road Warrior
    SC
    2021 TRD OR DC 4x4
    Debadged, decals removed ARE V series Camper Shell, RallyArmor mud flaps I’m old, my truck is boring
    Which bed stiffeners are best? All about the same?
    01Tac0ma likes this.
  9. Mar 20, 2024 at 6:35 AM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    I think some, like the TC version, go up a little higher than the others and ostensibly provide better bedside support. I went with the TC for exactly that reason, but honestly the difference could be negligible and may depend on use case. I got them to support a fiberglass topper and roof rack.
    Bandit[QUOTED] and koditten like this.
  10. Mar 20, 2024 at 8:16 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    is there much/anything different about the bed in the 3rd gens? I used to build bed stiffeners for 2nd gen guys before they were readily available from bigger companies like total chaos, and the only scenario you needed them in was if you had a substantially heavy bed rack and also did a decent amount of high speed off road driving. surprised you need them with a fiberglass cap.
  11. Mar 20, 2024 at 8:19 AM
    BabyBilly
    Billy
    2020 TRD
    I may not need them, but I figured it was pretty cheap insurance against bedside deformation. 3+ years and no issues but who knows what the alternative may have been.
  12. Mar 20, 2024 at 6:29 PM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    I have TCs .. I also have a 2nd gen but I love how beefy they are and contours to the bed well
    BabyBilly[QUOTED] likes this.
  13. Mar 20, 2024 at 7:19 PM
    Bandit
    Bandit Road Warrior
    SC
    2021 TRD OR DC 4x4
    Comparing photos on TC site, the top bolt on the TC bed stiffeners is slightly different. I’d probably go that route since they go up higher like @BabyBilly said. Makes sense. Thanks for the input.
  14. Mar 21, 2024 at 6:32 AM
    jayandersen5
    jayandersen5 Well-Known Member
    Jay
    South Carolina
    2017 TRD Pro
    OTT Tuned Yukon 5.29s 35x12.50r17 Yokohama MTs RRW RR7-H Wheels Dobinsons MRRs RRW hybrid front bumper ATH rear swing out high clearance bumper Alucab Explorer Canopy iKamper skycamp 2.0 Diode Dynamics SS3 (x4) and SSC2 SOS Sliders C4 full skids Smittybilt X20 Gen3 10k winch Prinsu Cabrack Expedition Essentials 3TPAM Caliraised 40" light bar ExtremeLED 30" light bar Total Chaos spindle/cam tab gussets and bed stiffeners Switch Pro SP9100 Power Tray
    I also have the TC bed stiffeners. Pretty sure those work for both 2nd and 3rd gens.
    Main reason I went with TC was for the added height and the flat bottom piece so it didn't get in the way of sliding larger things in and out of the bed.
  15. Mar 21, 2024 at 8:10 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    anyone want a Bud Built gas tank skid for a 2nd gen DCSB? this is the 3/16'' steel version. may fit 3rd gen DCSB as well, but not sure.
    yours for $100. just needs a wire wheel and some fresh paint. located in West Ashley, about 15 minutes south of downtown Charleston.
    w.adventures and The_Hodge like this.
  16. Mar 21, 2024 at 8:21 AM
    ahspurlock
    Adam
    If I knew it would fit a 4th gen T4R I'd snatch it from you
    w.adventures likes this.
  17. Mar 21, 2024 at 8:29 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    You going to be over this way anytime soon? Only takes a minute to put it on the jack and lift it up into place to see.
  18. Mar 21, 2024 at 8:38 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    also, if anyone wants the skid because you weren't proactive and screwed up your gas tank, the gas tank is free. the pump/sender is coming out and staying with me, but the tank is in good shape. it's going to the dump if no one wants it.
    ahspurlock[OP] and w.adventures like this.
  19. Mar 21, 2024 at 8:43 AM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Same, I need one for the GX
  20. Mar 21, 2024 at 9:10 AM
    ahspurlock
    Adam
    I'll be that way probably this weekend. I'll be in west Ashley pick up 2 rims for a buddy of mine for his trailer lol
