South Carolina BS thread under new MANAGEMENT and lives in SC
Discussion in 'South East' started by ahspurlock, Jan 18, 2016.
  1. Oct 18, 2024 at 5:21 AM
    banditcamp
    banditcamp Well-Known Member
    daniel
    2015 Super White DCSB Off Road
    And even the "biggest best" Viair is only a single. What they came on their site the 440 can air up 35s pretty quick. Then I started to wander will something that's good for big jobs be to much for little jobs?
  2. Oct 18, 2024 at 5:30 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    When talking small compressors like these, you can never have too much, especially with them all being in the "portable" category
    banditcamp[QUOTED] likes this.
  3. Oct 18, 2024 at 5:31 AM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    I think if you were using it as a all general compressor for all kinds of jobs.. id recommend getting one of those air storage tanks... It wouldn't work as hard no matter what you chose
    banditcamp likes this.
  4. Oct 18, 2024 at 5:35 AM
    Jeffvt0508
    Jeff
    Anderson, SC
    They all have a pressure switch that makes them cut off at 150 psi.. but with a storage tank you wouldn't have to cut the compressor on for say blowing up a float
  5. Oct 18, 2024 at 12:33 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Yes they likely are. I wouldn't install one without a tank, especially if you hard mount it
  6. Oct 18, 2024 at 1:14 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Air tanks are essentially useless on trucks. It will have zero effect on filling tires, and enough capacity to run an impact gun for a about 5 seconds at a time
  7. Oct 18, 2024 at 4:37 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    But theres no compressor cycling for your lockers!
  8. Oct 18, 2024 at 5:11 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I stand corrected, noise frequency reduction for lockers is valid.
    ahspurlock[OP] likes this.
  9. Oct 18, 2024 at 5:44 PM
    banditcamp
    daniel
    I'm not gonna install one. Portable is what I'm looking for. So one of the duals for around 200 or less. Or the Viair 440 for 300. Will l I see the benefit of the extra $100 spent or is it just throwing money away?
  10. Oct 18, 2024 at 5:56 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I think the crew will get drunk swigging beers waiting for you to air up all 4 tires.
  11. Oct 19, 2024 at 4:40 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    I have a Viair 400P and I used to keep it up in my pelican case on the roof. It fit fine but I had to lay it sideways to get the pelican case lid closed. I kept it up there for a few months until I checked randomly and there was moisture in the bottom of the case and it was causing my tools to rust. Some of the components on the compressor were starting to pit so I pulled it out and put it back in the cab of the truck until I can figure out how to keep the moisture under control in the pelican. I expressly put it up on the roof to keep shit from taking up rear seat floor space. My kids are getting bigger and need space to put their feet. So if any of you have any suggestions on how to keep the moisture under control, I'd like to put everything back up there again for long term storage.
    I checked the condition of the weather seal and it looks to be clean and free from tears or voids. There is one minor crease but I don't think that would allow moisture to work its way into the box. I had two ideas, one idea was to drill small drain holes in the front and rear corners and another in the middle of the box to let water drain out. Or two, run a bead of silicone around where the weather seal is, cover it with cellophane then close the box while it cures. It's basically what we do in the aircraft maintenance industry when weather sealing swing windows that pilots report leaking. Put a little bit of petrolatum on the lid before closing to keep it from sealing closed. I'm not sure if it's water intrusion from rain or condensation from humidity during the heating/cooling cycle over night.
    -J
  12. Oct 19, 2024 at 5:17 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    If it's from the regular heating and cooling cycles, you can toss a properly sized desiccant bag in there and it should do the trick. Go on Amazon and check out the size ratings. You could also use multiple smaller bags. You can get ones that are reusable by drying them out in the oven or microwave. If there's no clear sign of water intrusion, I'd start there, and you'll either have you solution or narrow down the issue.
  13. Oct 19, 2024 at 10:28 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    It's likely condensation from said heating/cooling. Drill a drain hole in it? The military cases I have have a valve to relieve pressure and possibly moisture
  14. Oct 20, 2024 at 3:42 AM
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    This pelican case had a vent near the handle, I was under the impression that all Pelican cases had vents. Well, I can say that all the pelican cases I've dealt with have that breather. I may just drill the tiny holes and call it a day and hope that the wind across them doesn't whistle.
    -J
  15. Oct 20, 2024 at 8:22 AM
    klavender1
    klavender1 Well-Known Member
    Columbia/Lugoff, South Carolina
    2005 GX 470
    Couldn't decide on pavers for the top of the fire pit and not wanting to spend a lot of money, I just coated the top with mortar mix. Gives it a more finished look. We'll see how it holds up.
  16. Oct 20, 2024 at 2:09 PM
    ahspurlock
    ahspurlock [OP] The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD
    Front long travel and Rear long travel including upper and lower rear control arms. Running 456 gears with rear ARB locker . LFD full roof rack with clamshell RTT
    Found a compressor. For Whoever might be interested
    w.adventures likes this.
  17. Oct 21, 2024 at 1:12 PM
    easleycrawler
    easleycrawler Well-Known Member
    Travis
    Easley, South Carolina
    2014 RC Taco 4wd
  18. Oct 23, 2024 at 3:36 AM
    ahspurlock
    Adam
  19. Oct 23, 2024 at 2:19 PM
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    This big girl took me for about a 5 minute ride on the kayak. :benchpress:
  20. Oct 23, 2024 at 7:17 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    Bumper for the FJ is in! Excited about it!
