South Florida B.S. Thread
Discussion in 'Florida' started by AWorthyOpponent, Mar 22, 2013.
  1. Mar 30, 2013 at 3:14 PM
    #41
    Finks99Taco
    Finks99Taco Well-Known Member
    'Fink'
    Coconut Creek, Florida
    1993 pickup
    I have much in all kinds of cracks and crevices.
    Update from the past weekend off offroad excitement with the fords:
    Blew some internals in my rack and pinion resulting in a small truck with big tires and bad alignment a pain in the ass to drive. Getting new rack and pinion and tie rod ends and installing new adjustable UCAs at the same time before final alignment. Truck should drive like a dream afterwards. Until then, parked in the driveway representing the muddy tragedy.
    Also replaced the shifter shaft and seal with the ones Marlin Crawler sells on my 93. Shifter is good and tight. Just waiting on the new CV axles to come in along with the little lift and then going to try and take the tires off the tan truck to take the 4x4 out for a spin!
  2. Mar 31, 2013 at 12:06 PM
    #42
    AWorthyOpponent
    AWorthyOpponent [OP] Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    Happy Easter everybody!!
    Yay, another 4x4. But will those tires fit? Aren't they 35s?
  3. Mar 31, 2013 at 1:37 PM
    #43
    Finks99Taco
    'Fink'
    1993 pickup
    Happy Easter.
    Nah 33's. just by holding them nearby they should fit. Older pickups have decently wide fenders.
  4. Mar 31, 2013 at 1:49 PM
    #44
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    Awaiting pictures...lol
  5. Mar 31, 2013 at 10:22 PM
    #45
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    Wanted to change my parking lights to LEDs tonight. Figured it would only take 5 minutes, so around 10pm, I went out to to it and told the gf I would be right back.
    While putting the LED in, it wiggled off the connector. Needless to say it fell in the light housing. I spent the last two hours taking the headlight and grill out of the truck. What a pain in the ass. It's probabally the dumbest design imaginable.
    On the lighter side, anyone that needs help with how to take them out, let me know. Lol.
    I really need to just stop trying to shove LEDs everywhere.
  6. Apr 1, 2013 at 3:10 AM
    #46
    TacoTues
    TacoTues Well-Known Member
    Grant
    Florida
    hey guys whats up haven't been here in a week or two. good to see someone started a south florida thread.
  7. Apr 1, 2013 at 3:16 AM
    #47
    Finks99Taco
    'Fink'
    1993 pickup
    Did your blinkers freak out with the lower draw LEDs?
    I had to buy a new relay for the fuse panel for mine.
  8. Apr 1, 2013 at 4:09 AM
    #48
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Dan, are you buying LEDs local or ordering them.
    I'm not into having all LEDs, but would want to swap out the two front turn signal / DTRL bulbs to minimize the destruction to the lens from heat.
    PK
  9. Apr 1, 2013 at 10:36 AM
    #49
    TAC1
    TAC1 Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    I ordered mine off of a Forum member who sells them. I replaced my interior bulbs with the bright white LED's (I'll post pics tonight) and my tag lights also. I was contemplating doing the same with my fromt signal lights but I dom't know if it's even worth it if I have to get a relay for it.
  10. Apr 1, 2013 at 12:57 PM
    #50
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    I'm ordering them from a former member. His username is csjumper2003. He's the guy that has a for sale thread in the second GEN marketplace. i tried ordering said off the Internet, but they were crap, so I ordered from him. Not only with a cheaper, but they work perfectly. He sells a whole kit for the daytime running light/turn signals. It comes with the resistors and everything. Check his stuff out.
    I'm not a big fan of throwing LEDs in random places, but I really like the way the interior looks with the LEDs, and the tag looks much cleaner with the white light as opposed to the factory yellow. I thought about doing the daytime running lights as well, but I think the factory bulb is probably better in that situation. I heard that people have problems with the lens melting, but never actually seen it.
    http://www.tacomaworld.com/forum/2nd-gen-tacoma-marketplace/176932-fs-led-lights.html#post3709338
    Remember I mentioned above sells the whole set up for you, so it's basically plug-and-play from what I understand. Be careful though, don't want to drop any LEDs inside your headlights… that's some bullshit.
    I actually didn't replace the turn signals, just the parking lights in the top corners of the light. Didn't like the way they came out easily (falling in the headlight), so I just put the stock bulbs back in it. It was basically a waste of time… FAIL
    The bulbs in the top corner are the 168 bulbs that you can use for the map lights, as well as tag lights. I figured, hey, I might as well since I had an extra bulb...
  11. Apr 1, 2013 at 1:09 PM
    #51
    Finks99Taco
    'Fink'
    1993 pickup
    You guys and your fancy headlights and shananigans.
    1st gens are so much more...simpler.
  12. Apr 1, 2013 at 1:48 PM
    #52
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    LOL, Fink.
  13. Apr 1, 2013 at 1:55 PM
    #53
    Sippi
    Sippi Well-Known Member
    Boca Raton, Fl
    El Taco Negro - 2017 Sport DC 4x4 6MT
    OVTune 2.0 TC Electronic BHLM 4R Sema with Nitto G2s Swing Case OEM Goodies Pro Items
    I will get some up...today has been hectic. Off to another meeting.
  14. Apr 1, 2013 at 1:56 PM
    #54
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
  15. Apr 1, 2013 at 4:18 PM
    #55
    Finks99Taco
    'Fink'
    1993 pickup
    Maybe a little...
    So in other news that spot by regal, just drove by and there is a HUGE sign by the entrance that says no trespassing. Guess Dan was right about cracking down.
  16. Apr 1, 2013 at 8:30 PM
    #56
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    Really? I just thought they were enforcing it more.
    Pics of it???
    So how do we go about finding the owner of the land? Anyone have a clue?
  17. Apr 2, 2013 at 3:21 AM
    #57
    Finks99Taco
    'Fink'
    1993 pickup
    I may swing by there today. Going to the mall this afternoon.
    We were going a decent speed so I only caught a glimpse of the area between the storage place and where those trees start and your could NOT miss it so its got to be a decent sized sign.
  18. Apr 2, 2013 at 9:35 AM
    #58
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    Fink,
    I think big is an understatement… That sign is freaking huge!!!!
  19. Apr 2, 2013 at 11:35 AM
    #59
    Finks99Taco
    'Fink'
    1993 pickup
    I knew it had to be good size when you can still see it flying down 441 lol
    They are not messing around any more.
    What's the OAN nonsense about?
  20. Apr 2, 2013 at 12:49 PM
    #60
    ckeeton
    ckeeton Bazinga
    Duluth, GA
    2011 DC Trd Sport Gray
    trd sport with avid off road light bar, avid rock sliders. OEM roof rack, 12' LED light bar, and Sock monkey decals.
    So what are some good clubs or bars in ft L? i'll be sorta close to downtown on the beach.
    Also, does anyone do the gauge cluster mod? i know there is a member in tampa that does it but forgot his name.
