South Florida B.S. Thread
Discussion in 'Florida' started by AWorthyOpponent, Mar 22, 2013.
  1. May 24, 2013 at 4:06 PM
    #141
    Finks99Taco
    Finks99Taco Well-Known Member
    'Fink'
    Coconut Creek, Florida
    1993 pickup
    I'm sure this applies to you 2ns gens but on my rear diff theres a breather. Little cap looking thing. It expands when the diff gets hot so it can 'breathe'. The downfall to that is if you buried your rear axle in water, well its going to suck in water and ruin your diff internals (if you dont drain and change fluids right away)
    So what you can do is go to Toyota and order a union (like $3) and it screws into where the original breather head is. Then with a couple hose clamps, put a new hose on there and redirect it to somewhere where it won't suck up water.
    Mine is in the engine bay up against the firewall (cause if that's in water, I have worse problems to deal with) Some guys will run it to next to their fuel filler neck so its in that door. I put a spectre filter on the end so it won't suck in dust or any of the sort.
  2. May 24, 2013 at 7:01 PM
    #142
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors
    My 10 I accomplished a vented diff, similar but different. Bought the fittings to place a 90 degree setup on the diff. Ran a hose along the brake lines, installed an inexpensive Wix fuel filter and ran the hose into the left rear bed storage box.
    Not as intense as the engine compartment for deep water, but still pretty high up and inside a semi sealed box.
    PK
  3. May 24, 2013 at 7:06 PM
    #143
    PMK
    Florida
    10 DCLB TRD Sport
    Find my truck around town at some point and get a look at the install.
    Honestly about a 15 minute job and worth the effort.
    Just remember the fitting into the diff doesn't hold a wheel on. Seems a bunch of guys on TW stripped their diff housing installing the little fitting.
    PK
  4. May 24, 2013 at 7:07 PM
    #144
    PMK
    Florida
    10 DCLB TRD Sport
    Will need an alignment pretty soon.
    Weber on Georgia Ave, was always good but expensive last time they did the e150 van.
    Are they still good or any better suggestions.
    PK
  5. May 25, 2013 at 2:11 AM
    #145
    Finks99Taco
    'Fink'
    1993 pickup
    Bed box is a good idea. 1st gens don't have those.
  6. May 25, 2013 at 4:45 AM
    #146
    PMK
    Florida
    10 DCLB TRD Sport
    Wasn't knocking your your install, yours is no doubt better for deep water. Before I did mine, I noticed there were some setups that tied the gearbox, trans, front axle and rear axle to a common filtered location on the firewall.
    Being a 2wd prerunner, I will likely see deeper water from a flooded street than get crazy enough to sink it in a mudbog.
    The other downside to the newer trucks I am learning is how the VSC system and electronic Auto LSD (the one that applies a brake to the slipping wheel) also cuts the engine power if it senses a speed above 30 mph and the wheels are slipping or the chassis senses a slide.
    The x runner guys have some work arounds for drag racing, but no one so far has a good method for off-road.
    PK
  7. May 25, 2013 at 8:12 AM
    #147
    Finks99Taco
    'Fink'
    1993 pickup
    O that's interesting.
    I thought I read somewhere you can turn those off by pushing then a couple times or pushing and holding the buttons.
  8. May 26, 2013 at 4:28 AM
    #148
    PMK
    Florida
    10 DCLB TRD Sport
    Problem is, once the computer sees over 30 mph it resets, and if the computer deems it needs to from wheelspin or sliding sideways, it cuts the power to the engine until the computer believes it has recovered the truck for the driver.
    It seems the x runner guys need to disconnect the brake switch in order to accomplish a burnout before a 1/4 mile run. If their truck senses the wheelspin it chops the power.
    This makes the newer trucks less desirable if you plan to drive them off-road or in the case of the x runner, race it.
    PK
  9. May 26, 2013 at 7:37 PM
    #149
    Kicklighter
    Kicklighter I'm the Man
    Andy
    Nashville, TN
    01 SR5, TRD Off-Road
    All-Pro Offroad 3" suspension lift, 1" body lift, 33.4" Toyo Opencountry MTs on 17" ProComp rock crawlers.
    Hey ya'll, my name's Andy. I'm 18 I live in Palm Beach Gardens. Dan (AWorthyOpponent) told me to join here. Dan- next time you're at Chick-Fil-A we'll talk about a place to go wheeling.
    I know of a mud hole out in Hobe Sound behind my buddy's house ya'll. It gets pretty hairy out there. I'll be lifting my truck soon and doing some sweet mods thanks to AllProOffroad.com! Look forward to hangin with ya'll.
  10. May 27, 2013 at 5:22 AM
    #150
    Finks99Taco
    'Fink'
    1993 pickup
    Oh wow. That would deter me from getting a new one if there wasn't a way around it. It makes sense from a safety aspect, I guess, but when you want to push it to the limit, you don't want the truck to fight against you.
    Howdy. I bought my truck from someone up in hobe sound.
  11. May 27, 2013 at 7:24 AM
    #151
    AWorthyOpponent
    AWorthyOpponent [OP] Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    Tires plus on Jog, just south of Okeechobee did a great job on mine. The older guy with glasses really knows his alignments and got mine right after the dealer, goodyear, and another tires plus had tried. Just went to them and payed for the lifetime alignment. Basically they'll align the front tires as often as you want, and its only like $150. If its more, you can talk then down...absolutely worth it if you're keeping the truck...
  12. May 27, 2013 at 7:39 AM
    #152
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    Success!! Definitely gonna have to set up a wheeling trip soon.
  13. May 29, 2013 at 6:10 PM
    #153
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    I really want to BHLM my lights, but I'm scared...anyone want to try it with me?
  14. May 29, 2013 at 6:23 PM
    #154
    PMK
    Florida
    10 DCLB TRD Sport
    I'll accomplish your diff vent mod, and even the tailgate anti-theft mod. Plus other stuff, but that is one I'll avoid.
    PK
  15. May 29, 2013 at 6:32 PM
    #155
    PMK
    Florida
    10 DCLB TRD Sport
    I was messing around with the button on Monday while headed to the in-laws. I tried Auto LSD, ANti-lock brakes off, stomped it to spin the tires, got flashing anti-lock lights, got VSC lights and buzzers when it went sideways and I still don't have it sorted out. Even tried reading the manual.
    Guess I really need to remove the open diff and install this truetrac locker and then see what happens.
    PK
  16. May 29, 2013 at 6:35 PM
    #156
    PMK
    Florida
    10 DCLB TRD Sport
    Let us know. Trying to get some real tires for my second set of rims. Need worthy 17's if anyone has a deal on tires.
    PK
  17. May 30, 2013 at 6:58 AM
    #157
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    Did you ever find any rims? I know you were looking for a set of TRD 17's...
  18. May 30, 2013 at 10:15 AM
    #158
    Sippi
    Sippi Well-Known Member
    Pompano Beach, Fl
    El Taco Blanco - 08 DC 6-Speed
    Makes two of us...I have been looking for some BFG ATs but no luck finding them for the 17s.
  19. May 30, 2013 at 5:19 PM
    #159
    Kicklighter
    Andy
    Nashville, TN
    Just bought Pro comp rock crawler series 98. 17x9 with 3.5" backspace. Will run Toyo Open Country MTs on those... 295/70 R17. Hopefully ordering those next week and will have this truck in the air in the next few weeks :)
  20. May 31, 2013 at 2:32 AM
    #160
    Finks99Taco
    'Fink'
    1993 pickup
    Very nice.
