Southeast GX Broverlanding and BS
Discussion in 'South East' started by Sandman614, Oct 9, 2020.
  1. Sep 15, 2021 at 1:03 PM
    #2381
    AugustaTaco
    AugustaTaco Well-Known Member
    Josh
    Augusta, GA
    2015 DCSBXSPX4X4 2017 GX460
    "Getting out of hand" - Wife
    Edit: she gone
    Any of you boys need a kdss coil spacer? Didn’t end up using it and had no lean…
    DF11602B-CB0D-4B47-85EE-A5346DF6AAC0.jpg 3907AD0D-1DD6-4B0A-9407-F7AEAD7496AB.jpg
  2. Sep 15, 2021 at 3:01 PM
    #2382
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Didn’t even know this was a thing. Some days I have lean and others I don’t :notsure:
    AugustaTaco[QUOTED] likes this.
  3. Sep 15, 2021 at 6:15 PM
    #2383
    AugustaTaco
    Josh
    Augusta, GA
    Depend on how much gas you have maybe? I dunno. Dobinsons recommended getting it just in case and I never used it
    w.adventures[QUOTED] likes this.
  4. Sep 16, 2021 at 5:08 AM
    #2384
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    The new downstream 02 sensor seemed to have cured my P0420 code. 500 miles in and havnt seen a CEL yet.
    Also threw on a new OEM gas cap to help the above issue.
    Filled up this morning and Avg my best tank yet. 16.7mpg.
  5. Sep 16, 2021 at 3:31 PM
    #2385
    bhayes423
    bhayes423 Well-Known Member
    Knoxville, TN
    B1678F13-CB47-4120-9B6C-6774ED369AE9.jpg F01A204E-93B4-4FEF-9698-04BB0757029D.jpg 55557190-7A79-4EEC-AC25-A6B53177687A.jpg
    Just picked it up from the shop!
  6. Sep 16, 2021 at 4:00 PM
    #2386
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    Damn that looks sharp!
    bhayes423[QUOTED] and Archangel like this.
  7. Sep 17, 2021 at 8:45 PM
    #2387
    captrussia253
    captrussia253 IG: ruslan.khinotskiy
    PNW
    2017 Tundra 2016 4Runner
    Same here. Annoying!
  8. Sep 17, 2021 at 8:48 PM
    #2388
    captrussia253
    PNW
    Got the RIGd ultraswing multi rig installed.
    FIRE74 likes this.
  9. Sep 17, 2021 at 8:59 PM
    #2389
    w.adventures
    Nowheresville, SC
    I am intrigued, what is that mat you are using?
    captrussia253[QUOTED] likes this.
  10. Sep 17, 2021 at 9:08 PM
    #2390
    captrussia253
    PNW
    2” foam mat from work. Used to ship large aerospace parts. They were throwing it out and I snagged a piece.
  11. Sep 18, 2021 at 3:24 AM
    #2391
    bhayes423
    Knoxville, TN
  12. Sep 18, 2021 at 2:28 PM
    #2392
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
  13. Sep 18, 2021 at 4:35 PM
    #2393
    w.adventures
    Nowheresville, SC
    Didn’t make it to the Starbucks parking lot.
  14. Sep 21, 2021 at 8:59 PM
    #2394
    jnw32
    jnw32 Well-Known Member
    Dallas, TX
    2016 White Tacoma TRD Off-Road DCSB
    265/75/16 KO2s, SR5 Grille, TRD Pro skid plate, Husky X-Act Contour floor mats, Carhartt front seat covers, de-stickered, partially de-badged, Bilstein 5100s with one inch rear block
    Hello Broverlanders. I’m in TX, but wondering if I could get your opinion. I got my wife a 2018 GX 460, and I like it so much I am thinking of trading my Tacoma in for a 2013 GX. I am planning on going up one size in tires and getting a 2 inch lift, but it will be a while. My question is will the GX in stock form do ok at my hunting lease? It’s on a big ranch and I will mostly be on ranch roads, but they can get rutted out and muddy. Some of them aren’t all that well maintained either. They can tear up trucks pretty quickly. The Tacoma handles them fine, but I worry about the low hanging body work on the GX. Any advice would be appreciated, thank you.
  15. Sep 22, 2021 at 6:01 AM
    #2395
    cgs2k2
    cgs2k2 old man
    Hi John - mechanically you will be fine. The body work could be a concern if you are climbing rocks and ledges, or traversing ruts that are a foot or more deep - but should otherwise also be okay. You can put the bigger tires on now, and then do the lift later. I put 255/80r17 (33") tires on my otherwise stock 2012 GX460 and it performs great offroad. There was slight rubbing on the side steps, so I took them off. I have since replaced them with rock sliders and am still picking out a lift. But to answer your question - stock, this is a very capable vehicle. I have not seen the obstacles you are going to be encountering, but if it is anything other than rock crawling, I think you should be okay.
    FirstGenTundra likes this.
  16. Sep 22, 2021 at 6:15 AM
    #2396
    cgs2k2
    cgs2k2 old man
    you can't tell in the picture, but i'm dragging hitch in the photo above. it's a steep climb up these ledges. this is stock on 33" tires.
    you should be good in the mud and dirt. tires will make the biggest difference. and delete the side steps (takes 30 minutes) - they hang pretty low.
  17. Sep 22, 2021 at 6:38 AM
    #2397
    jnw32
    Dallas, TX
    Thanks! That's very helpful. I don't want to spend very much extra money right now, and the truck has almost new tires on them - Michelin Defender LTX M/S in 265/60/18 - so even though I know changing tires would be an immediate off-road improvement, I will probably stick with them. And, your truck looks great!
  18. Sep 22, 2021 at 8:32 AM
    #2398
    cgs2k2
    cgs2k2 old man
    Thanks! Glad to be helpful.
    I do genuinely think you will be fine. This thing is really a truck with a tuxedo on. Tires would make the biggest difference - but those michelins are M/S rated, so they are probably okay as well.
  19. Sep 22, 2021 at 6:07 PM
    #2399
    misdirection1982
    misdirection1982 Another one
    Mark
    Fort mill
    2017 MGM TRD OR DCSB
    Kings, icon leafs, 305/70/17 recon grapplers, bed cage , rtt, 270° awning
    Lower control arms needed to be swapped since the bushings were seized. Got one side done. Tomorrow doing to other side.
    My big punch worked as a temporary support while I was waiting on the new lcas
  20. Sep 23, 2021 at 5:47 AM
    #2400
    klavender1
    klavender1 Well-Known Member
    Columbia/Lugoff, South Carolina
    2005 GX 470
    Keep your old arms, just in case. On my buddy's lifted GX, the Moogs lasted 6 months. I put Moogs on mine when I lifted it back in Januaryish and so far so good. He's going to rebuild the OEMs with Whiteline bushings and sankei 555 ball joints.
