Southeast GX Broverlanding and BS
Discussion in 'South East' started by Sandman614, Oct 9, 2020.
  1. Dec 8, 2021 at 7:51 AM
    #2981
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    stock offset is 20mm
    18x9” et0 would be great. That’s what size I’m going to be running.
    wvlexus and Gen1FTMFW[QUOTED] like this.
  2. Dec 8, 2021 at 7:54 AM
    #2982
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    That 5mm doesn't change much...
  3. Dec 8, 2021 at 8:27 AM
    #2983
    Gen1FTMFW
    So much for that. The wheels and tires that I want are on national backorder. Apparently every decent sized (33ish) Blizzak is on backorder. WTF.
  4. Dec 8, 2021 at 8:27 AM
    #2984
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Why do you have to go with 18” for a winter setup? Seems like more money for tires.
    Arailt likes this.
  5. Dec 8, 2021 at 8:51 AM
    #2985
    Gen1FTMFW
    I can't find anything bigger than a 32" equivalent. I think it's because winter tires don't want much sidewall.
  6. Dec 8, 2021 at 9:07 AM
    #2986
    klavender1
    klavender1 Well-Known Member
    Columbia/Lugoff, South Carolina
    2005 GX 470
    Any ideas to keep the Weathertech cargo rubber mat from shifting around? It doesn't really make any sense because I have the spare tire back there that should be holding it down. The spare tire is anchored to the 3rd row seat attachment so it stands straight up and doesn't move. I have to lift the spare tire up to move that mat back into place. Plus I have a milk crate full of stuff bungied to the car seat anchor points. And yet the mat will move around and won't stay centered.
  7. Dec 8, 2021 at 9:38 AM
    #2987
    Roody
    Roody Well-Known Member
    Ross
    SW CT
    GX460
    Drill through the mat and bolt it into the anchor points? Or maybe something like stick-on velcro on the underside of the mat?
  8. Dec 8, 2021 at 10:47 AM
    #2988
    Gen1FTMFW
    Think I'm just going to have to do 265/70r17 Blizzaks despite how small they'll look. On a side note, has anyone on here done the Doug Thorley header install? Just curious if you went long vs short and if anyone has done the SAIS delete/bypass along with it.
    w.adventures likes this.
  9. Dec 8, 2021 at 10:57 AM
    #2989
    klavender1
    2005 GX 470
    Ah! I like the velcro idea. Thanks!
    Roody[QUOTED] likes this.
  10. Dec 8, 2021 at 11:10 AM
    #2990
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I’m planning to totally delete SAIS and do the LT’s. The trouble is getting the holes plugged in the head or getting DT to not cut them out on the header flange. 03/04 headers won’t work either.
    Gen1FTMFW[QUOTED] likes this.
  11. Dec 8, 2021 at 11:46 AM
    #2991
    Gen1FTMFW
    You going with the Hewitt SAIS bypass to avoid check engine?
  12. Dec 8, 2021 at 11:58 AM
    #2992
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Tentatively, yes. I'm hoping Mat @ VFTuner can find a way to disable it within the ECU so I can do it that way, since support for GX will be in the next update.
  13. Dec 9, 2021 at 11:00 AM
    #2993
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Just a friendly PSA...check your tire PSI now that cold weather is here.
    :anonymous:
    henryp and Built2Ride like this.
  14. Dec 9, 2021 at 11:43 AM
    #2994
    klavender1
    2005 GX 470
    Don't forget your spare!
    jlemmond[QUOTED] likes this.
  15. Dec 9, 2021 at 11:45 AM
    #2995
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    Kept wondering why my steering felt so damn heavy..
  16. Dec 9, 2021 at 1:01 PM
    #2996
    w.adventures
    Nowheresville, SC
    Good call, it will look like your GX skipped leg day but will be more practical for winter months.
  17. Dec 9, 2021 at 1:40 PM
    #2997
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Thanks for the reminder. I need to swap my tires summer air for winter air.
    Arailt, Roody, klavender1 and 2 others like this.
  18. Dec 9, 2021 at 3:44 PM
    #2998
    w.adventures
    Nowheresville, SC
    Make sure you change your blinker fluid as well. Don’t want it to freeze
    Roody likes this.
  19. Dec 9, 2021 at 4:28 PM
    #2999
    Gen1FTMFW
    It's not great, but not as bad as I had imagined...
  20. Dec 9, 2021 at 4:38 PM
    #3000
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    Doesnt look bad at all!
