Southeast GX Broverlanding and BS
Discussion in 'South East' started by Sandman614, Oct 9, 2020.
  1. Jun 2, 2022 at 7:59 AM
    #3421
    cgs2k2
    cgs2k2 old man
  2. Jun 2, 2022 at 8:13 AM
    #3422
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
  3. Jun 2, 2022 at 11:03 AM
    #3423
    klavender1
    klavender1 Well-Known Member
    Columbia/Lugoff, South Carolina
    2005 GX 470
    What's the part number on it?
  4. Jun 2, 2022 at 12:43 PM
    #3424
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    89661-60D31
  5. Jun 2, 2022 at 3:52 PM
    #3425
    klavender1
    2005 GX 470
    Ah ok. That's a different part number and they don't seem to supersede.
  6. Jun 2, 2022 at 4:05 PM
    #3426
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Any reason to upgrade the lower links? Came across a used set for a somewhat decent price. There either Dobinsons or Ironman.
  7. Jun 2, 2022 at 4:53 PM
    #3427
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    lots of differing opinions on this...personally I bought upper and lower links from Opt Offroad and they are beefy af, but some will say it's way overkill and wasteful spending.
    jlemmond[QUOTED] likes this.
  8. Jun 2, 2022 at 5:02 PM
    #3428
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    Yea I wasn't sure. If I can talk him down more I might grab them.
  9. Jun 2, 2022 at 5:06 PM
    #3429
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Yes, stock ones bend like twigs on impact.
    jlemmond[QUOTED] and klavender1 like this.
  10. Jun 2, 2022 at 5:06 PM
    #3430
    w.adventures
    Nowheresville, SC
    No comment.
    jlemmond likes this.
  11. Jun 2, 2022 at 6:10 PM
    #3431
    klavender1
    2005 GX 470
    Ask him how he knows
  12. Jun 3, 2022 at 12:46 PM
    #3432
    klavender1
    2005 GX 470
    Welp no go on the ECU swap from another 2005 GX. I put his key fob into my key shell and plugged in his ECU. The car wouldn't crank. The security system wasn't recognizing his key fob. So we used a special tool to handshake his key fob to his ECU in my GX. That didn't work. Would have had to reseed the keys to even test that the A/C problem is the ECU. Which means reseeding the keys twice, once to my car and once back to his car. In theory this should work. But really life isn't theory and didn't want to run the risk of messing up his 17 year old ECU. We don't think it's the ECU anyways but I'm grasping for straws at this point. Next comes jumpering the relay while hooked to the A/C machine to read pressures. Basically pointing to or eliminating a partially clogged expansion valve. Which the shop is crazy today so another week goes by with mediocre A/C performance. But I'm staying patient because what choice do I have. :rofl:
    It does stay "comfortable" during these hot days by running the climate on MAX COLD/AUTO the whole ride home.
    w.adventures likes this.
  13. Jun 3, 2022 at 3:03 PM
    #3433
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Did you reprogram the ECU with your VIN? If not that is part of the problem.
    Also, how difficult was it to get the ecu out? Where is it located?
  14. Jun 3, 2022 at 6:59 PM
    #3434
    klavender1
    2005 GX 470
    Behind the glovebox, to the right of the blower motor box. Not bad to get to but wasn't taking a chance on frying his ECU.
  15. Jun 4, 2022 at 9:06 AM
    #3435
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    Finally pulled the OEM fogs out. Hated the bulb and the output. Picked up a set of SAE fogs from @memario1214 during the Memorial Day sale and got them put in. I bent up a piece of flat bar I had laying around to use as a bracket. Pretty straight forward process. I'll get them aimed tonight.
    klavender1, Juforrest and memario1214 like this.
  16. Jun 4, 2022 at 3:05 PM
    #3436
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Max’s??!?
  17. Jun 4, 2022 at 3:21 PM
    #3437
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    Ummm no. To much :spending:
  18. Jun 4, 2022 at 4:10 PM
    #3438
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    lameeeee
  19. Jun 4, 2022 at 4:11 PM
    #3439
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    Ballinonabudget
    Juforrest likes this.
  20. Jun 4, 2022 at 4:49 PM
    #3440
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Don’t know what that word means.
    i try to be cheap but @memario1214 sends the expensive stuff and charges my card accordingly…
    memario1214 likes this.
