Southeast GX Broverlanding and BS
Discussion in 'South East' started by Sandman614, Oct 9, 2020.
  1. Nov 14, 2024 at 4:39 AM
    #4701
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    hmmm. The housing isn’t actually that expensive. What axles are you going to use and I assume the oem backing plate bolts right up?
  2. Nov 14, 2024 at 6:08 AM
    #4702
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    Just stock axles. This whole thing is meant to be a housing replacement with a bigger diff. Everything else bolts up from old axle
  3. Nov 14, 2024 at 2:54 PM
    #4703
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    nice! What do you have invested into it, if you don’t mind me asking?
    I priced out a Dana 60 from ECGS and it was about $6200 :eek:
  4. Nov 14, 2024 at 3:35 PM
    #4704
    wrmathis
    Bonaire, GA
    parts and stuff
    so basically its around $8000. Got the rear diff off ebay for about $600 shipped. $2600 or so for the axle housing. then $5k for the regear, and locking the front and rear diffs. that doesnt really count the small things like seals, sealant, diff breather extension.
    got the diff into the housing today. what was awesome was putting the sealant down for the gasket and picking the diff up and realizing you put the 2 longer studs in the wrong hole. so had to swap those around to the right places and then drop everything down. based on the instructions for the permetex sealant, letting it sit for a few mins before dropping the diff is what is suppose to happen anyways. so yay i guess.
    klavender1 and w.adventures like this.
  5. Nov 14, 2024 at 4:04 PM
    #4705
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    About what I expected. I’d probably just do the D60. I’ll need the extra width anyway to match the LT front.
    should be able to sell my 8.2 and recoup some of the cost.
  6. Nov 14, 2024 at 10:01 PM
    #4706
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    Did a zero point calibration today. Too impatient to find a place where I could do the reset and drive 25mph straight for 10 seconds. This was sketchy with a block wall less than 50' away but got er done!
    klavender1 and Roody like this.
  7. Nov 17, 2024 at 10:24 AM
    #4707
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    After being late to work and $265 dollars later.
  8. Nov 17, 2024 at 12:43 PM
    #4708
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Take it back and get a group 27F
  9. Nov 17, 2024 at 12:53 PM
    #4709
    wrmathis
    Bonaire, GA
    parts and stuff
    got the axle installed and wired up. however, while removing the stock housing, the driver side shock was completely collapsed. no rebound in it at all. It also was stuck on the housing and i ended up cutting the stud off and while i was pressing out the stud from the shock, I fucked up the heim joint. so ordered new shocks for the rear. :rolleyes:
    I also need to touch up the housing with some paint. I scratched it up pretty good getting it in. also, ratchet straps are a god send. used them to hang the axle while i had to adjust the jack and jack stands at times.
    dumontrider likes this.
  10. Nov 17, 2024 at 1:36 PM
    #4710
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    Hard to be picky when I’m stranded at work on a Sunday. Only difference I saw between the 24 and 27 was the reserve time with the 24 having less. Not really something I’m worried about, who just sits there with accessories running and the vehicle not? God gave us alternators for a reason.
  11. Nov 17, 2024 at 2:51 PM
    #4711
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Word
    grab a voltage booster so it’s charging at the correct volts otherwise you’ll end up with 20% less capacity and CCA.
    Gen1FTMFW likes this.
  12. Nov 17, 2024 at 3:07 PM
    #4712
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    I’ll look into that.
  13. Nov 22, 2024 at 1:03 PM
    #4713
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    crashnburn80 likes this.
  14. Nov 22, 2024 at 1:42 PM
    #4714
    wrmathis
    Bonaire, GA
    parts and stuff
  15. Nov 23, 2024 at 7:21 AM
    #4715
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    Kinda on the fence about all this, according to my scanguage I’m already getting 14.1-14.2 normally. Is the extra .3-.5 volts worth the money of a booster?
  16. Nov 23, 2024 at 2:11 PM
    #4716
    Gen1FTMFW
    It's worth it if you want the battery to last more than a few years. 14.5-15VDC is best, with 14.6 or 14.7 being ideal. You can limp it along by putting the battery on a float every so often.
  17. Nov 23, 2024 at 3:45 PM
    #4717
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    10-4. I appreciate the clarification.
  18. Nov 29, 2024 at 8:18 AM
    #4718
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    Weather finally got decent enough to change the oil in this pig.
    11,939 on this OCI.
    w.adventures and klavender1 like this.
  19. Nov 30, 2024 at 12:59 PM
    #4719
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    GX people. I know little to nothing about these. Please enlighten me. I recently sold my Tacoma so I’m looking for a replacement that will serve as my daily driver (45mile commute daily).
    Not a lot of information on this one beyond what’s in the listing. What should I ask the seller that may be GX specific questions? Or should I be looking elsewhere to begin with?
  20. Nov 30, 2024 at 1:24 PM
    #4720
    Roody
    Roody Well-Known Member
    Ross
    SW CT
    GX460
    Rust (though it says there isn't any)
    Coolant valley leak
    Trans / fluid condition
    backcountryj[QUOTED] likes this.
