Southern California Taco/Offroad shop recommendation
Discussion in 'Southern California' started by xyzzy, Aug 17, 2017.
  1. Aug 17, 2017 at 4:45 PM
    xyzzy
    xyzzy [OP] Active Member
    Hey folks, it's about time to start doing some mods. Anyone have any recommendations for a good shop in the North County San Diego area for lift/wheel/tires?
    Thanks!
  2. Aug 17, 2017 at 4:47 PM
    SocalOC
    SocalOC Well-Known Member
    2015 Sport
    17" rockstart 2 levling kit 285/70/17 toyo ipen country
  3. Aug 17, 2017 at 4:47 PM
    bassfish319
    bassfish319 Well-Known Member
    2014 Tacoma 4x4 TRD
  4. Aug 17, 2017 at 4:49 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    The Truck Shop does good work for installs. There's also local members who will do the work (some full time job, some on the side).
    As for the wheels and lift I might be able to set you up with a good deal through my work. Whatcha looking for?
    SocalOC likes this.
  5. Aug 17, 2017 at 7:17 PM
    xyzzy
    I need new tires, and it has a bit of a wobble at highway speeds 55-65 so I figure while Im doing tires may as well do a few things. I'm looking to do some duatracs at 265/75/R16, some standard black steel wheels, and a 1-2" lift to give it a little more aggressive stance.
  6. Aug 18, 2017 at 2:56 AM
    Rburdeaux
    Rburdeaux Well-Known Member
    2004 Double Cab Prerunner
    The truck shop
  7. Aug 18, 2017 at 7:34 AM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    At my work I don't carry goodyear duratracs, and the steel wheels I have won't fit a Tacoma but they're out there.
    I can definitely help you out with a little lift though. A really popular option is to go with Bilstein 5100s which will yield you the lift you're looking for. You could also do coilovers (Fox, Icon, King) if you'd like to have something more heavy duty and properly valved for offroad use.
    To get everything done all at once the truck shop is a great place to go.
  8. Aug 18, 2017 at 8:58 AM
    xyzzy
    Thanks for the response. I was going for a pretty utilitarian look, and figured some simple 16" steel wheels like these:
    But realistically, I wouldn't mind spending the extra money for something a little higher end. Maybe the Eagle Alloy 100's or the Method Hole wheel looks pretty classic, although I'd probably like to powder coat the silver bolts around the rim.
    DSC06532B_9ecca925f63638751c8ac276ecbe00eee64f1516.jpg [​IMG]
    As far as lift, I'm open to the 5100s or the OME setup, whichever makes the most sense. I don't do any real hardcore off-roading,.. maybe the 16 hour drive to Scorpion Bay in Baja would be about the extent of it.
    SoCalTbird likes this.
  9. Aug 18, 2017 at 9:04 AM
    SoCalTbird
    SoCalTbird Well-Known Member
    South OC
    06 PreRunner DCSB 05 AC 4X4
    :spy:
    got back beginning of Aug
  10. Aug 18, 2017 at 9:08 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
  11. Aug 18, 2017 at 11:48 PM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    Look for speedfreak I'm the forums he has donekts of work @Speed Freek
    Speed Freek likes this.
  12. Aug 20, 2017 at 10:08 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    I can help out with the lift, but not wheels and tires as Im an installer/welder, not a retail guy. Bring me the stuff, I'll put it on properly, ;emme know if I can help.
    Thanks @opteron
