Space and Science BS Thread
Discussion in 'Off-Topic Discussion' started by Monster Coma, Oct 29, 2013.
  1. Mar 30, 2021 at 6:35 AM
    #4281
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    Yea, other than that it wasnt too interesting. Spacex’s feed glitched at the end, so I was really only watching the nsf feed and saw the pieces falling everywhere.
    PzTank likes this.
  2. Mar 30, 2021 at 6:35 AM
    #4282
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
  3. Mar 30, 2021 at 8:19 AM
    #4283
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    Sounds like everyday astronaut and nsf might have lost some cameras/equipment. And all for a bright orange flash in fog...
    PzTank likes this.
  4. Mar 30, 2021 at 10:06 AM
    #4284
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Will the final Starship have the ability to eject/separate the forward crew capsule? I'm noticing the same issue now as the space shuttle. If shit goes sideways, is there an abort or safety escape method that doesn't involve the crew getting cooked?
    Dragon can escape from a bad launch and on it's way down it's basically fueless so it doesn't matter. Thinking now Starship might have a problem safety wise unless it can ditch the crew capsule as well?
  5. Mar 30, 2021 at 11:21 AM
    #4285
    2008taco
    chris
    san diego
    This has been discussed many times on several videos and the answer is no. The reality is before they put people on it, they will have dozens if not hundreds of launches and landings under their belts. Once they have landed a few times they will likely start using Starship for Starlink launches. Considering they have 1,300 satellites now, need a minimum of 12,000, and have a planned 42,000, they have enough need to dial in the launch to be 99.99% reliable eventually. Even airplanes crash killing all, and they can glide when things go wrong, and they had a similar bumpy start.
    PzTank likes this.
  6. Mar 30, 2021 at 1:07 PM
    #4286
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  7. Mar 30, 2021 at 1:39 PM
    #4287
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Dude, just letting you know but your answers come off pretty arrogant lol. I know you're in the field, but wording is a godsend if you want people to not think you're a dick :fistbump:. Not all of us watch Elons YouTube. Thanks for the information, just try to give it direct without exaggeration next time if you care to
    As for Starship, the lack of an ejection/abort system is a concern in a manned system but a manageable one. I just hope they don't have a Challanger incident where they get asked why one doesn't exist when it does on the Dragon, that's all.
  8. Mar 30, 2021 at 3:45 PM
    #4288
    PzTank
    Above the Notches
    Too bad they did catch the glow of SN11’s explosion.. (not that I was hoping for it..)
    Man, they have the launch and decent under pretty good control. Here’s to hoping SN15 nails it :cheers:.
    Anyone have what ‘improvement iterations’ have been made for 15?
    2008taco and Gregthespy like this.
  9. Mar 30, 2021 at 3:52 PM
    #4289
    2008taco
    chris
    san diego
    I'm not saying I'm NOT an arrogant dick, because that would be a lie, but usually the reason my answers are often short and simple is because i am responding from my phone at work. But here is a more complete answer for you. The main reason is weight. The bulkhead required to handle a rapid unscheduled disassembly would weigh 30-50,000lbs. Add a complete interior for crew 30-50,000lbs. By the time you need to detach, you're too low for parachutes so that means rocket engines +fuel for the rocket engines + fuel tank. A single raptor engine weighs 3,500lbs and burns 2,000lbs of fuel per second. All this on a rocket with a 100ton payload capacity.
    For scale, the dragon capsule has a dry weight of 9,000 lbs and a return to earth payload capacity of 6,000lbs. That's the equivalent of 4.5 outer ring segments of Starship.
    There is however another option. Currently these are prototypes. When they crash they are just hollow tubes that collapse upon themselves. Eventually they will have an entire inner structure. Add to that the fact that they also intend to launch and land at sea. As we've learned with a previous falcon 9 + the fairings, it is possible to land in the ocean without complete destruction. And SN10 lasted 8 minutes before it went boom, that could have been enough to get everyone off the rocket...
  10. Mar 30, 2021 at 3:54 PM
    #4290
    2008taco
    chris
    san diego
    No, but one of the streams said Elon said there were literally hundreds from structural, engine, to software/firmware. And it is supposed to be on the pad in a couple of days!!
    PzTank[QUOTED] and Sterdog like this.
  11. Mar 30, 2021 at 4:10 PM
    #4291
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    I was thinking they could make the forward crew cabin similar in a style to the escape capsule used in the former F-111. I'm sure it was considered and they decided against it, but one has to wonder after the recommendations from Challanger if the reward would out weigh the risk.
    We are still a long way off from a working crew version of Starship, I get that, just chewing some fat so to speak.
  12. Mar 30, 2021 at 4:25 PM
    #4292
    2008taco
    chris
    san diego
    We'll see where they go. As it sits now, the crew cabin is a distant dream. They're just trying to prove they can land it, and they're not even using the landing legs that they intend to use. The current legs are just stand-ins. That said They/We get pretty confident with their tech pretty fast. The falcon 9 has only landed 78 times, and now it is only in the news when it doesn't.
    PzTank and Sterdog[QUOTED] like this.
  13. Mar 30, 2021 at 5:35 PM
    #4293
    PzTank
    Above the Notches
    I had my suspicions :rofl:
  14. Mar 30, 2021 at 5:56 PM
    #4294
    2008taco
    chris
    san diego
  15. Mar 30, 2021 at 9:16 PM
    #4295
    2008taco
    chris
    san diego
  16. Mar 30, 2021 at 10:16 PM
    #4296
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
  17. Mar 31, 2021 at 1:54 AM
    #4297
    TK-422
    So Cal - SCV
    2015 4Runner TEP
    The thing that seems weird to me is with all these new Space-x ships is they have a stainless steel exterior and wings/flaps.
    Why do they not have a smooth exterior? They look like they were assembled by a bunch of pre-schoolers with lots of hammers.
    wilcam47 likes this.
  18. Mar 31, 2021 at 3:06 AM
    #4298
    PzTank
    Above the Notches
    That’s a short one for Tim :D
  19. Mar 31, 2021 at 3:10 AM
    #4299
    PzTank
    Above the Notches
    They’re all prototypes.
    No need to put a ton of money and time into finishing off the exterior just to have it blow up on landing or at any time during the launch process.
    With SpaceX wanting to go orbital this year, it’ll be interesting to see how Starship’s exterior evolves. They will at least have to install ship-wide thermal protection...
  20. Mar 31, 2021 at 8:33 AM
    #4300
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    I was also told it helps keep the fuel cryo and saves weight. To paint something the size of the prototype adds a tonne or two of extra unnecessary weight which means more unnecessary fuel burn.
    2008taco likes this.
