Space and Science BS Thread
Discussion in 'Off-Topic Discussion' started by Monster Coma, Oct 29, 2013.
  1. Dec 2, 2021 at 11:30 AM
    #6421
    taco_rhyno
    taco_rhyno Well-Known Member
    06 DC 4x4 Sport
    SPECTRE Bird One from 1967’s James Bond movie ‘You only live twice’.
    Another interesting future space-related technology in the movie. In the Toyota 2000GT a moving map in a car. Something that only happened decades later with GPS and significant advances in electronics. As a fun GPS note - the the first GPS signal was received out on the NTS-2 (Navigation Technology Satellite) on July 19, 1977.
    https://www.aviationtoday.com/2017/...s-receives-worlds-first-gps-satellite-signal/
    PzTank[QUOTED] likes this.
  2. Dec 2, 2021 at 11:35 AM
    #6422
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    I knew it looked familiar :D
    Good stuff :thumbsup:. Welcome to the thread :hattip:.
    taco_rhyno[QUOTED] likes this.
  3. Dec 2, 2021 at 12:47 PM
    #6423
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Works for me. I wonder how long it will be before it’s a union job. And where would they picket?
    rip Albert Broccoli, one of his better efforts.
  4. Dec 2, 2021 at 2:11 PM
    #6424
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    If it's a small enough rocket this method could be less weight than chutes would be. Same with the legs. Hydraulics and all the systems involved could be more weight than just sticking them out and dealing with the drag. Less room for error with landing though. We eve seen SpaceX take some hard landing and survive only because of the legs moving. And we've seen some landings that were a bit too hard.
  5. Dec 2, 2021 at 3:24 PM
    #6425
    PzTank
    Above the Notches
  6. Dec 2, 2021 at 9:59 PM
    #6426
    bagleboy
    Scott
    Norcal, Santa Rosa
    Fixed may not mean they can’t absorb any impact, might just mean that they don’t fold away. A shock absorber might weigh less than a completely fixed leg built to a high enough impact standard plus the fuel to slow it a little bit more.
  7. Dec 3, 2021 at 4:53 AM
    #6427
    PzTank
    Above the Notches
  8. Dec 3, 2021 at 5:43 AM
    #6428
    PzTank
    Above the Notches
  9. Dec 3, 2021 at 6:22 AM
    #6429
    PzTank
    Above the Notches
  10. Dec 3, 2021 at 10:12 AM
    #6430
    PzTank
    Above the Notches
  11. Dec 3, 2021 at 10:58 AM
    #6431
    PzTank
    Above the Notches
  12. Dec 3, 2021 at 3:20 PM
    #6432
    PzTank
    Above the Notches
  13. Dec 3, 2021 at 11:22 PM
    #6433
    bagleboy
    Scott
    Norcal, Santa Rosa
    2008taco and PzTank[QUOTED] like this.
  14. Dec 3, 2021 at 11:24 PM
    #6434
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
  15. Dec 4, 2021 at 4:12 AM
    #6435
    PzTank
    Above the Notches
    Yes, inside the perimeter. See the pic midway down here:
    https://www.cnbc.com/amp/2021/12/03/elon-musk-spacex-starts-construction-of-starship-launchpad-in-florida.html
    I guess it’s gonna be an ‘improvement’ from the Boca Chica design.
    My Name is Rahl likes this.
  16. Dec 4, 2021 at 6:11 AM
    #6436
    PzTank
    Above the Notches
  17. Dec 4, 2021 at 7:36 AM
    #6437
    PzTank
    Above the Notches
  18. Dec 4, 2021 at 7:48 AM
    #6438
    PzTank
    Above the Notches
  19. Dec 4, 2021 at 7:54 AM
    #6439
    AWD OWNZ U
    AWD OWNZ U Well-Known Member
    SoCal
    2021 White Tacoma TRD Pro
    I know this was a while ago but to answer this, no. Depending on the launch vehicle shock loads are normally driven (aka highest) by the clampband release and not the “vibrating rocket” so a deployment is going to be your worst case. I don’t know how they how they tested JWST but normally you’ll test by actually deploying a spacecraft on an air table or something that simulates zero g for small stuff or on a vibe table that simulates those inputs for bigger spacecraft. The important point here is that you are inputting the loads into the base of the spacecraft where it’s designed to take them. Since JWST didn’t fall over (thank god) it was almost certainly attached to a holding or lifting fixture when it happened. So now you have a bad shock event going into the base but ALSO loads wherever you’re attached to the fixture. That means you have significant loads into the spacecraft in ways it was never designed for, hence having to do analysis to see if it’s ok.
  20. Dec 4, 2021 at 9:27 AM
    #6440
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    AWD OWNZ U likes this.
