Space and Science BS Thread
Discussion in 'Off-Topic Discussion' started by Monster Coma, Oct 29, 2013.
  1. Apr 28, 2022 at 5:54 AM
    #7881
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I expect it will be different on the surface or in a lunar cave with all the dust as opposed to the clean room environment of a man made vacuum chamber or in orbit. If water ice is plentiful it might be that concrete plays a significant role and dismantled lander shells are used as forms or lining. Large scale boring machines already use prefab concrete panels to line tunnels. Shielding, insulating, and pressurizing will take a layered approach I think. Might also need a self sealing layer as well.
    PzTank[QUOTED] likes this.
  2. Apr 28, 2022 at 5:58 AM
    #7882
    My Name is Rahl
    I didn't think about robot welding. We've pretty well perfected that by now, so that probably makes more sense than a clunky box.
    PzTank likes this.
  3. Apr 28, 2022 at 7:36 AM
    #7883
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
  4. Apr 28, 2022 at 8:10 AM
    #7884
    Farcedude
    Farcedude Well-Known Member
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
    I really liked the idea in Seveneves of instead of having a suit, basically give a person a comfortably-human-sized fully pressurized cylinder with a nice big viewport on top, and give them some sort of remote-control arms on it, so they're not having to fight pressure to just hold on to things. Obviously this is an on-orbit tool, not something usable on the surface of moon or Mars.
    PzTank and My Name is Rahl like this.
  5. Apr 28, 2022 at 8:32 AM
    #7885
    My Name is Rahl
    So, a small coffin sized space ship?
    PzTank likes this.
  6. Apr 28, 2022 at 8:37 AM
    #7886
    Farcedude
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
    Basically, yeah. Just give up on the fiction that a spacesuit is not just a small spaceship, and stop worrying about trying to make them look person-like. Maybe make it big enough for the pilot to bring their knees up, move their arms around, etc. so they can spend more time in it comfortably.
    EDIT - current Quest airlock hatch is 4ft x 4ft, right? Make the pod 3 ft diameter, have the pilot seated, maybe makes it 4 ft, 4 1/2 ft 'tall'? That should work. Or you can give it a hatch and have it dock to a module, so you're not having to depressurize a space.
  7. Apr 28, 2022 at 8:40 AM
    #7887
    My Name is Rahl
    Or gel type interior with VR/brain interface.
    Farcedude[QUOTED] likes this.
  8. Apr 28, 2022 at 8:54 AM
    #7888
    bagleboy
    Scott
    Norcal, Santa Rosa
    Maybe any ship fitted out with Waldos and a variety of camera feeds for that environment.
  9. Apr 28, 2022 at 9:27 AM
    #7889
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    Welding in space is easy. The only reason you need gas for mig and Tig is because earth has atmosphere and the gas displaces that atmosphere so that the weld can cool in an inert atmosphere. In a vacuum there is no atmosphere so it's already inert.
    Cold welding is cool, but getting 2 large panels flat enough to cold weld an air tight seam would require a ton of work. Flatness is king, and getting large things flat is tough.
    Robots are cool, and yes they can weld, preprogrammed welding paths. The biggest problem with robots is they are incapable of critical thinking. That said my bet is along the lines of humanoid/ish robots with vr/esque control
    My Name is Rahl and PzTank like this.
  10. Apr 28, 2022 at 12:10 PM
    #7890
    PzTank
    Above the Notches
  11. Apr 28, 2022 at 5:03 PM
    #7891
    bagleboy
    Scott
    Norcal, Santa Rosa
    It’s not the welding as much as the difficulties that arise from where it’s happening. Arc welding assumes a sufficient energy source that needs to be up and running first. Both robotic welders for assembly line work such as tunnel linings and ROV welders for non standard operations will need it. One thing a boring machine could provide is the cubage for shop space for machining & repairs and simply the elbow room to stay sane for larger groups.
  12. Apr 29, 2022 at 4:13 AM
    #7892
    PzTank
    Above the Notches
  13. Apr 29, 2022 at 4:16 AM
    #7893
    PzTank
    Above the Notches
  14. Apr 29, 2022 at 6:40 AM
    #7894
    PzTank
    Above the Notches
  15. Apr 29, 2022 at 7:02 AM
    #7895
    My Name is Rahl
    PzTank[QUOTED] and 2008taco like this.
  16. Apr 29, 2022 at 8:04 AM
    #7896
    PzTank
    Above the Notches
  17. Apr 29, 2022 at 8:39 AM
    #7897
    Farcedude
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
    Can't imagine it's that hard to compute the best orientation towards an arbitrary point on the surface of the earth.
  18. Apr 29, 2022 at 8:40 AM
    #7898
    Farcedude
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
    Something to look forward to this afternoon - watching RocketLab try to catch a 1st stage with a helicopter!
    EDIT - not today, bumped out to Sunday for better weather.
    https://www.youtube.com/watch?v=74sXa2qySPM
    PzTank and 2008taco like this.
  19. Apr 29, 2022 at 9:06 AM
    #7899
    My Name is Rahl
    I suppose not, but I guess I don't know how strict that is. Like, what if he's upside down in comparison to the plane of the earth?
    PzTank and Hunterdc1 like this.
  20. Apr 29, 2022 at 10:01 AM
    #7900
    R77toy
    R77toy Well-Known Member
    2015 DCSB Pyrite 4x4 Off-Road
    SpaceX has a launch from the Cape this evening
    Farcedude likes this.
