Space and Science BS Thread
Discussion in 'Off-Topic Discussion' started by Monster Coma, Oct 29, 2013.
  1. Sep 20, 2015 at 7:50 AM
    #861
    TheGrayRider
    TheGrayRider MARANATHA !!!
    NW Florida
    2017 BBP DC 4X4 OR
    Always has ... Always will
    The experts will always argue why and how fast
  2. Sep 20, 2015 at 8:20 AM
    #862
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    In the context of say 10,000 years, isn't this just a continuation of the cycle?
  3. Sep 21, 2015 at 1:33 AM
    #863
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    Not exactly..
    For most if not all of the Holocene epoch (approx 11-12thousand years) the Earth has been in an interglacial period.
    Climatic optimum, which is about the point where sea levels are at their highest, for the current interglacial was reached between 2.5 to 5 thousand years ago. Our sea levels are rising very
    quickly at present, a fact that is seen in the scientific community as quite concerning. As Earth's tilt on its axis continues to decrease, we should experience milder climate. This would mean a
    global average of cooler summers and warmer winters. With the data we have now, it would appear that the opposite is happening.
    Here is a graph showing the change in global temperature vs. the change in solar activity:
    This change does not seem to fit into any perceivable cycle.
  4. Sep 21, 2015 at 3:08 PM
    #864
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
  5. Sep 21, 2015 at 3:36 PM
    #865
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    If I follow correctly, the cycle hasn't ended. At least if you agree with the definition of the Holcene Period.
    And if the ice hasn't stopped melting, it only stands to reason sea level will continue to rise.
  6. Sep 22, 2015 at 1:00 AM
    #866
    WheelInTheSky
    G
    Jackson Hole
    Not at all how it works..
  7. Sep 22, 2015 at 5:17 AM
    #867
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Enlighten me.
  8. Sep 22, 2015 at 11:09 AM
    #868
    WheelInTheSky
    G
    Jackson Hole
    Ok, but I'll point out right off the bat that I am not an expert. The information I provide is up for debate, as there is not a full understanding of all the forces at work with regard to systems that take place over hundreds of thousands and even millions of years. There is lots of data from the past hundred years, and we can look back almost a million years with ice cores, but axial tilt's effects on climate and the finer details of glacials and interglacials are not fully understood.
    That said, I'll tell you what I meant about your post:
    As you stated, the cycle is not at an end. It is continuous, interglacials are preceded and succeeded by glacials and vice versa.
    The sentence including the phrase: "..definition of the Holocene Period," is one that I'd like to touch on briefly, just for sake of not letting things get confusing. The Holocene is an epoch, not a period. BUT, sometimes (mostly outside of the geological community) glacials and interglacials are referred to as glacial periods and interglacial periods. So, because the current interglacial is referred to as the Holocene interglacial, use of the name Holocene Period isn't necessarily wrong. This may sound inane or pedantic, but I thought it was worth pointing out as the Quaternary Period might come up in the conversation and it is important to know that the Holocene is the most recent Epoch in the Quaternary Period and it happens to be an interglacial.:facepalm: lol
    Now, as for the ice continuing to melt and the sea level continuing to rise, yes and no. It is thought that the climatic optimum for the Holocene may have occurred 5-8 thousand years ago. The climatic optimum is the point in an interglacial where the climate is at its most temperate and weather extremes are at their lowest. The highest sea levels of an interglacial tend to occur right around the climatic optimum. Not exactly the same time, but very close to it. Our most recent climatic optimum came and went, so presumably the highest sea level that would occur during the Holocene should also be behind us. However, sea levels are continuing to rise at a rate which in recent years has been accelerating.
    Perhaps the climatic optimum for the Holocene has not yet been reached and what we thought to be the warmest part of the supposed mid-Holocene was actually a fluctuation that will look trivial once we actually reach the climatic optimum. This doesn't seem particularly likely though, as the last glacial was a long one and longer glacials tend to be bordered by shorter interglacials.
    Well, that's all I have time for before I head to work. In case you couldn't tell, I love to nerd out on this shit so please feel free to question anything that I said and to bring new info to the table. I've got a cursory understanding of this stuff but have only scratched the surface and am hungry to know more. If you really want to get balls deep into this topic please do, and share with us what you find. When I get some time I'll post a few sources if you are interested in reading up on it.:goingcrazy:
    HomerTaco likes this.
  9. Sep 22, 2015 at 6:51 PM
    #869
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I still don't get it but props for trying to explain. :thumbsup:
    I'd like to see a mock up of what the earth would look like if it all melted.
  10. Sep 22, 2015 at 6:53 PM
    #870
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    Just wait :oops:
  11. Sep 22, 2015 at 6:57 PM
    #871
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Just googled it. Looks like philly becomes the new AC and we don't have to feed the mouse in Florida any more Money because Orlando goes the way of Atlantis.
    I can live with that. :cool:
  12. Sep 22, 2015 at 6:58 PM
    #872
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    At least it's not some crazy shit like Waterworld... :rolleyes:
  13. Sep 22, 2015 at 7:24 PM
    #873
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Lots of Florida is in danger from high water sooner than later
  14. Sep 22, 2015 at 7:54 PM
    #874
    se7enine
    se7enine MCMLXXIX
    Reno, NV
  15. Sep 22, 2015 at 7:57 PM
    #875
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    I think we are saying essentially the same thing.
  16. Sep 24, 2015 at 11:32 AM
    #876
    se7enine
    se7enine MCMLXXIX
    Reno, NV
  17. Sep 24, 2015 at 11:33 AM
    #877
    se7enine
    se7enine MCMLXXIX
    Reno, NV
  18. Sep 24, 2015 at 1:49 PM
    #878
    Larry
    Larry CARL
    CARL
    My home is on a peninsula...across the street from the bay...9 foot elevation... :D
  19. Sep 25, 2015 at 5:43 PM
    #879
    TheGrayRider
    NW Florida
    2017 BBP DC 4X4 OR
    I think you will be just fine Larry... unless there is a large storm. If you should need higher ground you can always park at my house. Over 150 feet above sea level ... No water wings required
  20. Sep 25, 2015 at 5:47 PM
    #880
    OZ-T
    Peter North
    British Columbia
