Space and Science BS Thread
Discussion in 'Off-Topic Discussion' started by Monster Coma, Oct 29, 2013.
  1. Aug 29, 2022 at 5:14 AM
    #9161
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
  2. Aug 29, 2022 at 5:17 AM
    #9162
    PzTank
    Above the Notches
  3. Aug 29, 2022 at 5:37 AM
    #9163
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    Scrubbed
    PzTank likes this.
  4. Aug 29, 2022 at 5:39 AM
    #9164
    PzTank
    Above the Notches
    I believe the SRBs have an ablative material that protects the nozzle and segments. No active cooling system.
    2008taco and gsubioguy like this.
  5. Aug 29, 2022 at 5:40 AM
    #9165
    My Name is Rahl
    Came here to say this.
    gsubioguy[QUOTED] and PzTank like this.
  6. Aug 29, 2022 at 5:40 AM
    #9166
    PzTank
    Above the Notches
    Official? Thanks for the heads up :hattip:
  7. Aug 29, 2022 at 9:02 AM
    #9167
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Sounds like it’s a bleed in one of the engines and not the umbilical connector. Can they swap with one of the other 12 they have before the launch window closes on the 5th or when is the next window after that? I’m assuming an engine swap is easier than a part swap because they’d still have to test the engine after repairs.
  8. Aug 29, 2022 at 9:12 AM
    #9168
    .劉煒
    .劉煒 Well-Known Member
    2016 Inferno DCSBTRDORMT
    This isn't starship, they gotta roll it back into the VAB for a swap.
    PzTank and 2008taco like this.
  9. Aug 29, 2022 at 10:29 AM
    #9169
    My Name is Rahl
    You were able to understand the NASA press conference? I couldn't get the audio to come through correctly.
  10. Aug 29, 2022 at 10:47 AM
    #9170
    bagleboy
    Scott
    Norcal, Santa Rosa
    I’d assumed that much at least which is why I don’t think they can make the 2nd window and possibly not the third but even SH went back to the high bay for engine repairs or swaps after the spin prime explosion. They have the new platform and eventually might use it for a quick swap but that event required a more extensive survey and repairs.
  11. Aug 29, 2022 at 10:51 AM
    #9171
    bagleboy
    Scott
    Norcal, Santa Rosa
    It was from a later broadcast I guess. It was just audio on YouTube with a few different views of the launch site. They were saying that engineers wanted to keep it fueled a bit longer to gather more data on the bleed before draining the tanks.
  12. Aug 29, 2022 at 11:06 AM
    #9172
    bagleboy
    Scott
    Norcal, Santa Rosa
    Partial answer; in general two weeks on, two weeks off so if we miss the 5th then somewhere around the 3rd or 4th week of September at the earliest(don’t know where we’re at in the current window) .
    https://www.nasaspaceflight.com/2021/11/artemis-1-launch-periods/
    2008taco likes this.
  13. Aug 29, 2022 at 11:17 AM
    #9173
    PzTank
    Above the Notches
  14. Aug 30, 2022 at 4:53 PM
    #9174
    bagleboy
    Scott
    Norcal, Santa Rosa
    The launch window is approximately two weeks on two weeks off but they have only 20 days to get going or it’s back to the VAB to stay for a lengthy recertification process. Let’s hope they can find the problem and fix it but it’s been an ongoing issue it seems throughout the wdr’s. Dealing with hydrogen is hard. Don’t want to flame anyone but isn’t this what wdr’s are supposed to sort through? Some serious money just got wasted.
    My Name is Rahl likes this.
  15. Aug 30, 2022 at 6:32 PM
    #9175
    PzTank
    Above the Notches
    Saturday, next attempt. I’ll find a source.
  16. Aug 30, 2022 at 7:21 PM
    #9176
    My Name is Rahl
    The WDRs, apparently, stopped short of engine chill.
    PzTank and gsubioguy like this.
  17. Aug 30, 2022 at 8:08 PM
    #9177
    bagleboy
    Scott
    Norcal, Santa Rosa
    What was said today in a briefing was that they were intended but didn’t happen in the previous wdr because of the leak issue. They knew this could be an issue as well as the leak since neither were subsequently tested at cryo temps. At least now they say they have the data and plan needed to correct the issue by the new launch time on Saturday. I guess that means they have no way to cryo test short of a full wdr and for some reason were unwilling to perform another even though they hadn’t yet been fully successful. I suppose it also means we’ll be going into Saturday similarly untested. I don’t mind me crossing my fingers but it seems odd at this point they would proceed on that basis.
  18. Aug 30, 2022 at 8:10 PM
    #9178
    bagleboy
    Scott
    Norcal, Santa Rosa
    The plan being to begin engine cooling earlier in the countdown.
  19. Aug 30, 2022 at 8:15 PM
    #9179
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    Well, since they’ve rushed this project through so fast, there’s never enough time to really test things. If only they had more time and money so as to meticulously test and revise as needed, they certainly would have launched by now.
  20. Aug 31, 2022 at 3:51 AM
    #9180
    My Name is Rahl
    I wonder if they will detank between now and Saturday?
    Also, I thought I read somewhere that the leak was actually a non-issue because it was on the hydrogen recycle side of things?
    :rofl::rofl::rofl:
