Space and Science BS Thread
Discussion in 'Off-Topic Discussion' started by Monster Coma, Oct 29, 2013.
  1. Feb 14, 2023 at 8:16 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
  2. Feb 14, 2023 at 9:04 AM
    PzTank
    Above the Notches
  3. Feb 14, 2023 at 9:18 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    2008taco and PzTank[QUOTED] like this.
  4. Feb 16, 2023 at 2:08 PM
    PzTank
    Above the Notches
  5. Feb 17, 2023 at 12:04 PM
    PzTank
    Above the Notches
    gsubioguy, bagleboy and Pixeltim like this.
  6. Feb 17, 2023 at 12:29 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
  7. Feb 17, 2023 at 12:42 PM
    PzTank
    Above the Notches
    And they’re bigger than they look when landing:
  8. Feb 17, 2023 at 4:45 PM
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    Took the words right out of my mouth. Seems so surreal. And as @PzTank said: the scale isn't appreciable from the videos.
  9. Feb 19, 2023 at 6:53 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    Same.
    I'd watch the old 50's sify movies where they'd land vertically on Mars and think " this is so stupid, that will never happen that way"
    bagleboy[QUOTED] and PzTank like this.
  10. Feb 19, 2023 at 7:18 AM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    Well… where do you think Elon got the idea from?
    PzTank and CTSpruceMica[QUOTED] like this.
  11. Feb 19, 2023 at 1:46 PM
    PzTank
    Above the Notches
  12. Feb 19, 2023 at 11:14 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    The belly flop works great to get through the atmosphere but they’d need a whole nother set of engines to land that way. Or wings but either one cuts into payload. I suppose in low gravity landings it might be possible to decelerate with main engines then rotate 90 and land using ventral thrusters. That’s an old sci-fi thing too.
    PzTank likes this.
  13. Feb 20, 2023 at 6:56 AM
    PzTank
    Above the Notches
  14. Feb 20, 2023 at 7:18 AM
    PzTank
    Above the Notches
  15. Feb 21, 2023 at 6:07 AM
    PzTank
    Above the Notches
  16. Feb 21, 2023 at 7:00 PM
    Tibetan Nomad
    Tibetan Nomad Well-Known Member
    2016TRDOR:DCLB:JBL
    NitroGear5.29,B6112,.25"spcr,SPC:UCA,Diff-drop,ECGS
    B5160,Dakar-HD-leaf-pk+OL,UBolt-Flip,33s,Superbumps
    PzTank likes this.
  17. Feb 22, 2023 at 8:57 AM
    PzTank
    Above the Notches
  18. Feb 22, 2023 at 10:00 AM
    PzTank
    Above the Notches
  19. Feb 22, 2023 at 10:20 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    I’m glad to see so much hardware being readied but I hope they also have the flight hardware and launch tower ready for those. And Spacex has a vehicle for them to rendezvous with. It’s mostly the mobile launch tower for Artemis 3 that has me skeptical though if they are going to use thrusters mounted high up on HLS at some point I’d like to see a hop test at 1/6 thrust/weight on a test vehicle to verify control and landing leg operation since it will probably be different than F9 legs to account for an unprepared surface. The engines might have to hover to allow the gear to “find” where solid ground is under each leg. Obviously site selection will attempt to choose the most level, solid zone but anything flat will be covered with loose regolith making it imperfect. I can’t imagine them not testing this. The Apollo landing modules didn’t have this CG issue.
    2 years until Artemis 2 and then probably at least another before Artemis 3 so it’ll be interesting to see what Spacex prioritizes and what things are tested concurrently. Starlink has to be #1 but the different versions needed to get HLS operational will also need time and testing with prototypes. I see those competing needs requiring the use of one or both towers at KSC with Boca Chica serving as the test facility for development. If pad 40 gets a crew launch tower then it might also get the second mechazilla or they might opt to separate them entirely. Star liner is still a ways from full service and even after it’s available there may not be an Atlas 5(only 19 left all accounted for?)or Vulcan to stack it on and Dream Chaser is still at least a few years from a crewed version being certified. Are any Atlas 5’s set aside for the Star Liner crewed missions? I know the military has stopped using them.
  20. Feb 22, 2023 at 11:22 AM
    PzTank
    Above the Notches
    Trying to follow what you’re saying here but for the first part I’ve bolded- I don’t think the Artemis III mobile launcher has anything to do with the HLS Starship. They’re two completely separate, but compatible systems.
    2008taco likes this.
