Space and Science BS Thread
Discussion in 'Off-Topic Discussion' started by Monster Coma, Oct 29, 2013.
  1. May 16, 2023 at 11:12 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Single launch to get it up and running? It’s a way station meant for temporary habitation of a few weeks at a time by a few rather than permanently with months long rotations by many. Still, claustrophobia is going to be a concern.
  2. May 17, 2023 at 8:07 AM
    My Name is Rahl
    I guess maybe they could use HLS, when docked, as the main living quarters?
    PzTank likes this.
  3. May 17, 2023 at 8:15 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    It’s the poor saps stuck in that sardine can while the others are enjoying all that Starship luxury I was thinking of.
    PzTank likes this.
  4. May 17, 2023 at 8:17 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    I’d think the HLS itself would make a better Gateway platform than anything else that could get there.
  5. May 17, 2023 at 11:34 AM
    My Name is Rahl
    If Gateway could just be the size of a Starship payload bay, even if it had to go up in pieces, would be better.
  6. May 17, 2023 at 12:56 PM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    PzTank likes this.
  7. May 17, 2023 at 6:40 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    If it ended up just being a dedicated gateway Starship it would also have tank space for refueling descent craft and if it were sent there direct from refueling in earth orbit on a low thrust fuel efficient flight path similar to the gateway test satellite(Capstone, thank you PzTank) it could arrive with most of its fuel still available. As an upside it has built in return/rescue capability, a measure of redundancy another module would lack and something to consider. A solar panel parasol (a la James Webb) would keep the fuel plenty cold enough. Any satellite that fit in the payload bay would by definition have less capacity.
    PzTank likes this.
  8. May 18, 2023 at 2:44 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    CAPSTONE
  9. May 18, 2023 at 7:38 AM
    PzTank
    Above the Notches
  10. May 18, 2023 at 8:18 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    PzTank[QUOTED] likes this.
  11. May 18, 2023 at 8:21 AM
    My Name is Rahl
    Basically Artemis 2.
  12. May 18, 2023 at 8:37 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    PzTank likes this.
  13. May 18, 2023 at 8:37 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Yes, except for no one ever being there before. Artemis 2 will be more like being the party to almost summit Mt Everest after Sir Edmund Hillary. However unfairly there’s a reason close but no cigar isn’t a thing.
  14. May 18, 2023 at 8:52 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Regarding the OLM and GSE I have to wonder what will happen when the water deluge hits it instead of concrete debris. It’s still going to be a lot of stuff moving at a fast clip in every direction save for the shadows of the OLM pillars. Have they made a test article and put any equipment in the exhaust plume ? You generally don’t put equipment at the outlet of a flame trench but at Starbase it’s all there, 5 plumes each with 3-1/2 million pounds of thrust driving them.
  15. May 18, 2023 at 9:13 AM
    PzTank
    Above the Notches
    More like Apollo 8.
    No lander, just a ride around the moon but without even 1 orbit.
  16. May 18, 2023 at 5:44 PM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    The vast majority of the water should be turned to steam pretty much instantaneously. Last I heard they were adding piles under the pad for support, because apparently the concrete didn't fail. The earth underneath the concrete couldn't support the weight of the thrust, compacted, and then the concrete broken apart since it isn't very flexible and couldn't contour to the new shape of the dirt below.
    gsubioguy, PzTank and Farcedude like this.
  17. May 18, 2023 at 6:51 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    I’m assuming the issues under the OLM get resolved by the current modifications. And I realize the long term plan is to eliminate the vertical storage tanks in favor of horizontal tanks but My innate skepticism just has me thinking this won’t be the end of dealing with the colossal thrust and what remains in its path. It wouldn’t surprise me at all to see just a different kind of damage from the next launch. I’m sure they’ll figure it out but I don’t think they’ll be able to rapidly turn around launches until they do.
  18. May 19, 2023 at 12:15 AM
    PzTank
    Above the Notches
    gsubioguy likes this.
  19. May 19, 2023 at 6:28 AM
    PzTank
    Above the Notches
    The F9 Iridium/One Web launch from Vandenberg has been scrubbed for today.
    Aborted the countdown at just under a minute - no cause given.
  20. May 19, 2023 at 6:43 AM
    PzTank
    Above the Notches
    bagleboy likes this.
