Space and Science BS Thread
Discussion in 'Off-Topic Discussion' started by Monster Coma, Oct 29, 2013.
  1. Jan 17, 2024 at 5:23 AM
    Hunterdc1
    Hunterdc1 1st shift Waste Control stupidvisor
    Brrrrother
    Mamas don't let your cowboys grow up to be babies
    13 8 lug ltz gasser
    Absolutely yes. It will go from the Neil Armstrong Operations & Checkout(O&C) facility when testing is complete to the Multi-Payload Processing Facility(MPPF) where it will be fueled. Then to the VAB for stacking. VAB isnt clean room but the other two are both clean to the nth degree.
  2. Jan 17, 2024 at 7:00 AM
    My Name is Rahl
    And you do the fueling on the capsule?
    PzTank likes this.
  3. Jan 17, 2024 at 7:06 AM
    Hunterdc1
    Brrrrother
    13 8 lug ltz gasser
    I'm just the trash guy
    :D
  4. Jan 17, 2024 at 11:00 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
  5. Jan 17, 2024 at 12:38 PM
    My Name is Rahl
    Right....
    PzTank and gsubioguy like this.
  6. Jan 18, 2024 at 3:13 AM
    PzTank
    Above the Notches
  7. Jan 18, 2024 at 10:31 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Makes sense that the VAB and ML-2 are somewhat similar environments to the Bays and OLM/OLT(once you are past the actual construction of the vehicles) but the ordering of assembly/movement is different. It’s the fact that the various tanks and stages for Artemis are all built in clean rooms and assembled in the VAB as complete units but ships and boosters are stacked/welded in the Bays from open sections so the environments the insides the sealed sections are made in are vastly different. The Star factory should enable at least the critical upper portion of each ship which houses satellites or crew to be built in a much more controlled environment but it seems that all fuel tanks will continue to be welded where they are now. I’m curious as to whether the header tanks will remain in the nose of crewed ships or if the mass of the crewed section is sufficient to allow the headers to be shifted aft.
    PzTank and My Name is Rahl like this.
  8. Jan 18, 2024 at 10:40 AM
    My Name is Rahl
    With the expansion (and near completion of Starfactory), and the addition of roll doors on the Highbay and both Megabays; the assembly of tanks and the payload sections will become much more contained.
    2008taco, PzTank and bagleboy[QUOTED] like this.
  9. Jan 18, 2024 at 11:28 AM
    PzTank
    Above the Notches
  10. Jan 18, 2024 at 11:41 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Agreed, they just aren’t up to the same standards as where Artemis H2 and LOX tanks are manufactured. It’s different and likely to remain so. I presume cryo testing takes care of flushing any remaining contamination not removed after stacking/welding, exposure to the elements and/or occasional bird droppings. Every ring & dome section still sits in the ring yard prior to stacking. I see it as an innovation rather than a flaw.
  11. Jan 18, 2024 at 12:00 PM
    PzTank
    Above the Notches
    bagleboy and Farcedude like this.
  12. Jan 19, 2024 at 5:57 PM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    I remember when SpaceX and then Blue origin release a video of their factories and progress. Spaces was a job shop, like many that I've worked at, their facilities were made for work. BO took the time to make custom embroidered vinyl covers to keep dust out of parts because they knew it'd be sitting for a long while.
    Sometimes cleanliness is a good thing, but it can be taken too far.
    bagleboy[QUOTED] and PzTank like this.
  13. Jan 20, 2024 at 9:23 AM
    PzTank
    Above the Notches
  14. Jan 20, 2024 at 9:58 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    And we get to see what’s necessary and what’s excessive only when it’s done differently.
  15. Jan 20, 2024 at 12:50 PM
    PzTank
    Above the Notches
    bagleboy likes this.
  16. Jan 20, 2024 at 1:07 PM
    PzTank
    Above the Notches
  17. Jan 20, 2024 at 8:37 PM
    2008taco
    chris
    san diego
    PzTank and bagleboy like this.
  18. Jan 21, 2024 at 12:00 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Neat stuff. I wonder if 3D printing(or some other method) becomes a more readily available and less time consuming option than large format forging which seems to be slow, rare, and costly.
    PzTank likes this.
  19. Jan 21, 2024 at 5:35 AM
    PzTank
    Above the Notches
  20. Jan 21, 2024 at 11:49 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    gsubioguy and PzTank[QUOTED] like this.
