Space and Science BS Thread
Discussion in 'Off-Topic Discussion' started by Monster Coma, Oct 29, 2013.
  1. May 2, 2024 at 1:48 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    It came in pretty hot(fast) so I wonder if they could reduce the speed at which it leaves lunar orbit. It would still accelerate from the gravity neutral point but maybe not end up going as fast upon reentry.
    tcBob, gsubioguy and PzTank[QUOTED] like this.
  2. May 3, 2024 at 7:14 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    From Reddit:
    Someone’s living a deluded life..
    FastEddy59 and tcBob like this.
  3. May 3, 2024 at 7:48 AM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    They believe in science when a mechanic needs to read their car's diagnostic codes to fix a problem. Then their brain turns off once everything is fine again.
    b_r_o, gsubioguy and PzTank[QUOTED] like this.
  4. May 3, 2024 at 10:32 AM
    PzTank
    Above the Notches
  5. May 4, 2024 at 1:49 AM
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    Moon's reflection near the end? Seems too small in my mind
    PzTank likes this.
  6. May 4, 2024 at 2:42 AM
    PzTank
    Above the Notches
    The spot in the middle just above the bottom? I’d say it IS the moon. What else could it be :notsure:
    Good catch :thumbsup:
    gsubioguy[QUOTED] likes this.
  7. May 4, 2024 at 5:53 AM
    PzTank
    Above the Notches
    https://x.com/torybruno/status/1786514106112991349?s=46
    :woot:
    Hopefully Starliner OFT-2 is successful allowing it to enter into regular crew rotations. That would half Crew Dragon flights. Any thoughts on if this excess capacity will be picked up by more private endeavors? Say more Axiom flights? Maybe other brokers?
    Farcedude likes this.
  8. May 4, 2024 at 6:02 AM
    PzTank
    Above the Notches
    gsubioguy likes this.
  9. May 4, 2024 at 6:10 AM
    PzTank
    Above the Notches
    gsubioguy, Pixeltim and tacokid09 like this.
  10. May 4, 2024 at 11:54 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    That's assuming they can build another one, let alone in a timely manner.
  11. May 4, 2024 at 3:11 PM
    PzTank
    Above the Notches
    Yeah, good point.
    Anyone hear if Butch and Suni are going to name this capsule?
  12. May 4, 2024 at 4:46 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Isn’t Dragon supposed to serve Vast Haven-1? And I expect further reductions when Sierra Space regularly flies DC and then gets the crew version certified. It was certainly good for Spacex to take advantage of the situation but I think there will be a gradual slowdown before things heat up again.
    PzTank[QUOTED] likes this.
  13. May 4, 2024 at 5:22 PM
    PzTank
    Above the Notches
    I’d be slightly amazed if DC goes into routine operations much less crew certification. There’s already reports the first flight will be delayed due to issues and one would think after at least 2 decades, maybe more, they would’ve made it by now. Not to mention it’s dependent on BE-4s….
    bagleboy[QUOTED] likes this.
  14. May 4, 2024 at 6:48 PM
    PzTank
    Above the Notches
  15. May 4, 2024 at 11:02 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Dream Chaser won’t be crew certified but it’s successor should be and is already under construction though I won’t be holding my breath. Also it’s supposed to launch on Vulcans but could be launched on F9’s as well. I think the whole space plane idea is a lot harder to accomplish than a capsule or it would be more in use and as fun as it is to watch, the business model Spacex uses to develop Starship probably isn’t available to them. I think BE-4’s will perform as projected, it’s BO’s production rate that has me concerned. Even there though I think they’ll get them done and they aren’t trying to meet the demand of 39 engines for thousands of Super Heavies so comparing them to Raptor production is more tempting than apt.
  16. May 4, 2024 at 11:11 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
  17. May 5, 2024 at 6:16 AM
    PzTank
    Above the Notches
    gsubioguy and bagleboy like this.
  18. May 5, 2024 at 6:32 AM
    PzTank
    Above the Notches
  19. May 5, 2024 at 8:19 AM
    PzTank
    Above the Notches
  20. May 5, 2024 at 9:55 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    I don’t think anyone since Apollo has moved at this pace except the Chinese. I’m not certain Spacex can do 5 launches this year but they don’t seem to dread failure, instead they both count and thrive on it which along with their other successes providing plenty of funds allows all these disposable iterations. You’re absolutely right though, they have to keep up the pace of iterations and likely amp it up but considering what they’ve accomplished working in tents without bridge cranes I do believe the new Star factory facilities (including the office building) should at least double production right from the start and keep increasing as the larger plant crews learn the process and more robotics are introduced. Finishing up tile work, engine install, and flight prep will be the production/iteration bottle necks. With bridge cranes in the factory taller sections result in fewer seams needing to be tiled after stacking in the bays and Raptor 4’s should install and get flight prepped much faster as well. The bottleneck to launches remains the OLM but even if they only have the one launch system available for the next 18 months they should be well into Starlink launches and perfecting fuel transfer by then. They might have to accept “only” a 10-week flight cadence for now but with what they’ve learned I expect that to change drastically for OLIT-2. If they have the means along with the answers then if they can have 2 new OLIT’s operable by 2026 then HLS should be there for the taking. By the time OLIT-1 gets upgraded they should easily be able to complete a full launch and refueling mission profile. Say, 2027? It would not surprise me in the least if it was further delays at NASA and other Artemis partners that actually ends up driving the timeline to the moon. I’d like to say watch the progress on a gateway launch because they won’t launch it until they’re close but I’m beginning to think(and hoping as well) that the excessively cramped space in it might push them to include a LIFE module to the design(even a bare-bones empty one with a window, gateway doesn’t have one). 2 weeks in a windowless closet is going to be more of a challenge than the few days Apollo crews had to endure.
