Space and Science BS Thread
Discussion in 'Off-Topic Discussion' started by Monster Coma, Oct 29, 2013.
  1. Jun 4, 2024 at 4:24 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
  2. Jun 4, 2024 at 6:38 PM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    so Elon mentioned in a tweet that he is going to do something with TD next week, and one of the things they'll talk about is the heatshield. He has also said their is a chance at them attempting a catch with ift5 if ift4 is successful. I think their biggest hurdle there is approval. All the segments for the second tower are build, most are already in Texas, and have many visible improvements that will speed their assembly compared to the first tower. It could theoretically be build in under a month, but likely will be around 2-3. iirc the first was 5-6.
    As for Hubble. If they're talking about increasing altitude with a dragon, then they have some ideas on how to attach to it. Would love to see it, especially with the camera views Spacex gives us, and I think that's Hubble's only hope. I don't think Starship will save it unless they have a customer for Starship that requires a large payload door. Elon has already talked a little about the possibility of a Telescope variant. That means a 30 foot diameter mirror vs 8, not to mention much more up to date hardware. Theoretically they could even land it for servicing and repairs. That means the only real reason for Starship to do it is nostalgia, which has a fair chance considering this is Elon. That said I would love to see Spacex launch 5-10 space telescopes and rent them out to governments, universities, etc.
    PzTank and gsubioguy like this.
  3. Jun 4, 2024 at 7:41 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Launch them yes, build them? Elon has said there’s much to do that others will have to get done so without a direct tie to something they need it would likely fall into that “others” category. That said they could probably get them into position for a fraction of the cost even completely expending a ship in the process. Ie jettison the nose cone and rule out reentry. I think it also would need a longer duration fuel than methalox for orbital adjustments.
  4. Jun 5, 2024 at 2:03 AM
    PzTank
    Above the Notches
  5. Jun 5, 2024 at 2:11 AM
    PzTank
    Above the Notches
    bagleboy and gsubioguy like this.
  6. Jun 5, 2024 at 3:36 AM
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    Obviously SpaceX will attempt a controlled re-entry but if they tell the FAA in advance that it'll be uncontrolled then attempt controlled it won't auto trigger an investigation?
    Am I interpreting it correctly that had this Launceston license were for the last launch, starship's re-entry would not have been investigated?
    (Apologies for the rambling, likely not very coherent comments/Qs--still having coffee and popping fuses between the ears.)
  7. Jun 5, 2024 at 3:51 AM
    PzTank
    Above the Notches
    I don’t know about the last launch but Eric is reporting if SpX informs the FAA BEFORE launch that that landing will be uncontrolled, then no investigation will happen.
    gsubioguy[QUOTED] likes this.
  8. Jun 5, 2024 at 7:48 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    I think they had to clear the hurdle of no risk to life or property ground side and maintaining flight profile before the change in licensing. Can’t have it wandering off trajectory and coming down where it’s not supposed to. That might have had a bit to do with loss of attitude control triggering no in flight relight. Having demonstrated that they’re free now to play with how it comes down as long as they say what they intend in advance and continue to paint inside the lives. Pretty sure losing control to the extent either stage comes down outside of the targeted area placing life or property at risk would still trigger an investigation so it’s not a totally free pass. “You’re improving, keep it up and your good to go, backslide and we start all over”.
    PzTank and gsubioguy[QUOTED] like this.
  9. Jun 5, 2024 at 7:52 AM
    PzTank
    Above the Notches
    Looks like just 2 guys at the press site with the countdown clock….
  10. Jun 5, 2024 at 8:10 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Starliner is up!
    abou824, PzTank and gsubioguy like this.
  11. Jun 5, 2024 at 8:38 AM
    PzTank
    Above the Notches
    2008taco, Deathbysnusnu and gsubioguy like this.
  12. Jun 5, 2024 at 8:42 AM
    abou824
    abou824 Well-Known Member
    Aidan
    Central PA
    '21 TRDOR Army Green 6MT, '13 Lexus RX350
    TRD Lift (Toyota 5100's) LT265/75 AT4W Method MR305 16x8 Bronze ARB Diff Breather Subaru Tweeters Garmin Dash Cam Clutch accumulator delete plate Vibration dampers on MT driveshaft shield
    Was a bit of a nailbiter watching that, glad they launched safely
  13. Jun 5, 2024 at 8:46 AM
    My Name is Rahl
    :goingcrazy::goingcrazy::goingcrazy:
    bagleboy and PzTank[QUOTED] like this.
  14. Jun 5, 2024 at 8:47 AM
    My Name is Rahl
  15. Jun 5, 2024 at 9:54 AM
    PzTank
    Above the Notches
    Huh, I’ve always thought SpX provided the best, most unique perspectives :notsure:
    And sometimes, the NSF folks just yammer to much :frusty::D
    If I were gonna be home, I’d have multiple streams going. As is, I’ll be in the office watching on my phone and getting all the replays when I get home.
  16. Jun 5, 2024 at 9:55 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    The have a ton of F9 data to jump start things but SHB’s are a whole new kettle. Managing to reach the ground intact allows them to collect more control data but doesn’t ensure they actually have control. It’s going to take some flight experiences to get that and refine the software. A soft water landing would be a huge step and one that comes after getting the engines to all relight. I’d count even just a full relight as a success, anything more is a huge bonus. If they can manage 3 more flights before the tower is completed (w/wout an OLM) they might have that control. After it cools they could set it directly on a transport stand.
    gsubioguy and PzTank[QUOTED] like this.
  17. Jun 5, 2024 at 10:31 AM
    My Name is Rahl
    Yeah, they do tend to talk a bunch, but that's what the mute button is for. Members also get a commentary-free multi cam view.
    SpaceX did do a good job, but the video formats on X just aren't like what they were able to do on YouTube.
  18. Jun 5, 2024 at 11:37 AM
    PzTank
    Above the Notches
    I get it. I don’t watch the X feed, I go straight to their website.
    Here’s to hoping John makes an appearance :fingerscrossed:
  19. Jun 5, 2024 at 3:09 PM
    2008taco
    chris
    san diego
    Yeah, but the views and quality SpaceX gives us... So much better than any other rocket launches
    gsubioguy, bagleboy and PzTank like this.
  20. Jun 5, 2024 at 5:34 PM
    PzTank
    Above the Notches
