Spacer/Adapter....PROBLEM! Please help
Discussion in 'Wheels & Tires' started by e96eclipse, May 25, 2010.
  1. May 25, 2010 at 5:36 PM
    e96eclipse
    e96eclipse [OP] Member
    Eric
    04 toyota tacoma 3.4L Supercharged
    Supercharger,22" BIGG Wheel rims, Interior paint
    I have a 2004 tacoma 2wd. I recently purchased a set of 22" rims to put on my truck,but to be able to put these rims on I had to buy a set of 1 1/2 spacer/adapter to go on it to make these rims fit. So i put everything on lifted the truck two inches front and back and it all looks awsome! but..... now, when im driving down the road everything rides good from take off and on but once i start pressin the brake the Whole front-end of my truck starts shakin reallllly badly. I have checked all the adapters and all the lugs and everything is sitted properly.I cannot figure it out but it rough when pressin the brakes. Any ideas?
  2. May 25, 2010 at 6:14 PM
    98tacoma27
    Ben
    Not Beech Creek
    Did you get it aligned?
  3. May 25, 2010 at 6:28 PM
    e96eclipse
    Eric
    no i didnt.. would that cause the whole front-end to shake that bad? like the tires are gonna come flyin off... its bad
  4. May 25, 2010 at 6:30 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    How did you lift it?
  5. May 25, 2010 at 6:33 PM
    98tacoma27
    Ben
    Not Beech Creek
    May be but it's a stretch. Any time you change the geometry of the suspension, you need to get an alignment. Post up the specs, wheels, tire size, etc.
    X2 on how did you lift it.
  6. May 25, 2010 at 6:36 PM
    JDMcQ
    Are the 1.5 " spacers spring spacers or are we talking wheel spacers?
  7. May 25, 2010 at 7:06 PM
    e96eclipse
    Eric
    I lifted the rear with 2" blocks and i use coil boosters for the front. tire size is 305/40/22 hancook tires and BIGG WHEEL 22"rims. and we are talking wheel spacers...actually they are 1.5" adapters,you basically bolt on the spacers to your orig studs and these come with new studs on them
  8. May 25, 2010 at 7:16 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Try throwing your stock wheels/tires on the front without spacers and see what happens.
    Only happens when you hit the brakes..? Brake problem? Did you torque your UCA etc tight?
    Front only or front and back?
  9. May 25, 2010 at 7:55 PM
    e96eclipse
    Eric
    it doesnt do it when it has the stock ones on it even if i leave the spacers on with the stock it stll doesnt do it.....could it be the rims? bent? or not balanced? should i try puttin the front one one the back and the rear ones on the front?
  10. May 25, 2010 at 8:06 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Try getting an alignment, you are running a low profile tire it might be the tires amplifying the road bumps. especially if your tires in the front looks like this \ /
  11. May 26, 2010 at 4:50 AM
    JDMcQ
    So we have a 2wd Tacoma lifted with coil spacers in the front, blocks in the rear on 22's and wheel spacers. So many levels of wrong...IMO
  12. May 26, 2010 at 5:49 AM
    crazybayman
    crazybayman Oh 'eah
    Newfoundland
    09 4x4 4.0L V6 Access Cab Standard
    AutoStart, Sirius Satellite Radio, 16x8 Moto Metal 955s, 265/75/16 Duratracs, Fog Lights, Skid plate
  13. May 26, 2010 at 6:41 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    +1, way to many variables. Any of of those mods could cause vibes if not installed/torqued properly (or in the case of the lift, even it it was installed correctly).
  14. May 27, 2010 at 2:51 PM
    e96eclipse
    Eric
    why so many things wrong? so ur saying the lift could be causing the prob? or the spacers
  15. May 27, 2010 at 2:56 PM
    e96eclipse
    Eric
    before i lifted the truck i put the spacers and the rims on and the 22s rubbed..so i took the 22s off and left the spacers there, and i drove it that way for a day of so till i got what i needed to lift it and it drove fine with the stock wheels and spacers. now that i have lifted it and put the 22s back on its doing this...so i really dnt think its the spacers
  16. May 27, 2010 at 3:02 PM
    TexasTacoma37
    If I'm understanding you correctly, at one point you had the lift and wheel spacers, without the 22's on there. Then you put the 22s on and got the vibes.
    That would mean the rims are bent or the tires are not properly balanced.
  17. May 27, 2010 at 3:19 PM
    Chachie
    Chachie Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    I think i just puked in my mouth a little... But hey if you like it more power to ya. You might have warped rotors. You might not have noticed it when you had the stock wheels and tires on but the bigger wheels and tires will exaggerate the shaking. Do you feel it in the brake pedal too?
  18. May 27, 2010 at 3:23 PM
    e96eclipse
    Eric
    puked in your mouth? it would blow anything you got off the road....so swallow that puke!...and yes only started shakin when i put 22s on the guy said they were already balanced but i been thinkin i might need to get them checked. it shakes in the pedal and the steerin wheel and the shifter...
  19. May 27, 2010 at 3:25 PM
    Chachie
    Justin
    Nor Cal
    I dont think you want to say "anything i got" because then you would make yourself a liar. But in anycase is it like a pulse in the break pedal?
  20. May 27, 2010 at 3:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If its pulsing when pressing the brakes, Odds are, the lugs were not torqued propperly, on the spacers, or the wheels, and are causing the rotors to be warped. Take the wheels off, and the spacers, and re install to the correct torque. Tighten them in a start pattern.
