Spacer + Fox coilover
Discussion in 'Suspension' started by Broheim, Apr 12, 2017.
  1. Nov 8, 2017 at 8:01 AM
    #41
    *TRD*
    *TRD* Well-Known Member
    Carson, Ca
    There are two separate issues here, and a spacer isn't the proper fix for either one.
    A spacer will change the extended and collapsed lengths. So now you'll bottom out on the coilover and overextend the ball joints.
    If you're rubbing your tires are too big and you need to move the bump stop down on the frame. I believe there are aftermarket bump stops and spacers to accomplish this.
    If you've added weight you probably need new springs. It's unfortunate, but the reality of fine tuned suspension. We swap springs on off-road trucks all the time because of different weights. Only makes sense that you might have to change them on a Tacoma.
    chucklefunkk likes this.
  2. Oct 1, 2019 at 7:15 PM
    #42
    Edward25
    Edward25 Member
    So the tighter you make the coil over the more lift? I’m confused I thought adjusting the shock longer made more lift?
  3. Oct 2, 2019 at 9:08 AM
    #43
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    Hopefully this will help clear it up:
    danthach and jerzsubbie like this.
  4. Mar 22, 2021 at 12:24 PM
    #44
    meats
    meats superwhite MT taco meats
    Justin
    Grapevine, TX & Cushing, OK
    '20 Super White DCSB 6spd MT 4x4
    Lots--
    I bet the OP is glad you did this.
    Tacoma’20 likes this.
