spacer geometry question
Discussion in 'Suspension' started by 7584, Oct 29, 2008.
  1. Oct 29, 2008 at 2:01 PM
    7584 [OP] Member
    florida
    06 SR5 prerunner V6
    3" lift. 7" indash DVD/GPS. 2x12" RF subs. Cobra CB with PA loud speaker. billet grill. more will be added later
    My truck started out as a show truck on the dealership floor where they threw a bunch of glitter and nice things like rims tires and a lift. It didn’t sell so they traded it to a dealership near me, I showed up the day it got in and had no problem taking it off their hands. Doing my research ive discovered it has 1” blocks in the rear but I’m unfamiliar with the lift the front spacers are giving me. I measured 2”s but somewhere on here I read that spacer lifts lift the truck double the size of the spacer. Due to thermal dynamics or Einstein’s principal of theory… maybe something to do with flux compacters…
    Can someone explain this to me so I know what I need to run my tires with. “285/75-18 toyo open country M/Ts”
  2. Oct 29, 2008 at 5:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Your gonna need to do ALOT of cutting to fit 285/75/18's
  3. Oct 29, 2008 at 6:32 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    it depends on if the spacer sits on top of the assembly or on top of the coils. 3" on top of the assembly=3" of lift. 1.5" above the coils=3" of lift...
  4. Oct 30, 2008 at 3:15 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It doesn't matter where the spacer sits......
    The physics is at the lower control arm where the coilover is attached. If the coilover strut was mounted at the very END (outter edge) of the control arm, you'd get 1 for 1 (1/2" block = 1/2" lift).
    But since the coilover strut is mounted at the halfway point (approx) inward on the lower control arm, you get about 1 for 2 (1/2" block = 1" lift).
  5. Oct 30, 2008 at 3:23 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    up early janster
  6. Oct 30, 2008 at 3:28 AM
    Janster
    Jandy
    Lancaster, PA
    :thumbsup: Work at 8am....:rolleyes:
    What about you? Gotta get my fix before another long day.
  7. Oct 30, 2008 at 3:34 AM
    David Tarantino
    N.J.
    08 tacoma
    do you use rt 80 i thought i saw a truck like yours
    iam at work here at 6am to open up we start at 7am
  8. Oct 30, 2008 at 4:15 AM
    Janster
    Jandy
    Lancaster, PA
    That must have been someone else - I use Rte 30. You don't travel up in PA do you?
  9. Oct 30, 2008 at 4:20 AM
    David Tarantino
    N.J.
    08 tacoma
    thought it was you i on each day work in denville live in landing
    ex 28 rt 80 Have a good day time to go work may see ya tonight :D
  10. Oct 30, 2008 at 6:33 AM
    7584 [OP] Member
    florida
    06 SR5 prerunner V6
    so 2" spacer between coil and assembly equals 4" of lift? im trying to figure this out because im getting my TSB spings in today and im addicted to having a level truck.
  11. Oct 30, 2008 at 9:34 AM
    jhodge83
    SC
    then how come my 1.25" spacer above the coils for 2.5" of lift, but my 3" spacer above the entire assembly onlt got me 3" of lift?
  12. Oct 30, 2008 at 5:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This is what I thought true until I read:
  13. Oct 31, 2008 at 4:17 AM
    Janster
    Jandy
    Lancaster, PA
    Measure again.....;)
  14. Oct 31, 2008 at 7:09 AM
    jhodge83
    SC
    there's nothing to measure again....the 2.5" lift was on the 07 and the 3" is on the 09. but thats exactly the way it was/is b/c i wondered this before and measured the spacer on the 07. the 09 is just a solid brick of 3" thick aluminum.
