spacer kit install video? I need help.
Discussion in '1st Gen. Tacomas (1995-2004)' started by mtxsub, Dec 18, 2012.
  1. Dec 18, 2012 at 6:32 AM
    mtxsub
    mtxsub [OP] Well-Known Member
    tacoma prerunner
    sound system led lights
  2. Dec 18, 2012 at 6:35 AM
    xaqori
    xaqori Grammer knotsy
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    ARB lockers and 4.88s front and rear, OME 886s, Dakars, etc., Safari Snorkel, 17"Fuel Revolvers w/ 35x12.50r17 KM2s, fenders cut 3" all around, Pioneer AVH-P4400BH w/ Backup cam, CB/PA (PA Installed), Weathertech Digis, Foglight anytime, AP: front bumper, skids, and pack rack, custom sliders, Warn 9.5XP, dual VIAIR 480Cs with a 2.5gal tank, OTRATTW switches galore, URD y-pipe, RCI skids, LF 240s, etc.
    Some tire shops will do it for a "decent" price. Look for a shop that can do alignment
  3. Dec 18, 2012 at 6:38 AM
    JRod4928
    JRod4928 Well-Known Member
    Pittsburgh
    '12 Tacoma SR5
    Extang Trifecta Tonneau WeatherTech Floor Liners Pop & Lock Tailgate Lock Antenna X Black Mesh Grillcraft with Tacoma Badge (Upper) and Cross (Lower) 18" BMF Wheels / Cooper 31.5" Tires 2" Leveling Kit
  4. Dec 18, 2012 at 6:38 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Raise the front of the vehicle with the front wheels off the ground. Secure on jackstands.
    Remove front tires
    Remove 3 nuts holding top of coilover to top mount
    Remove 1 nut and bolt holding coilover to lower mount.
    Remove coilover from vehicle.
    Place spacer on top of coilover and secure with 3 nuts on studs previously used to hold coilover to vehicle.
    Reinstall coilover, with spacer installed on top, in vehicle reversing removal steps.
    It will be necessary to push down on lower control arm to fit the now longer assemble in place. You may need to remove sway bar end to gain more droop.
  5. Dec 18, 2012 at 5:32 PM
    Mxer256
    Mxer256 Well-Known Member
    Tyler
    Mississippi
    2012 Prerunner
    2012 Tacoma Trd sport, 10" bulletproof lift with traction bars and icon resi rear shocks, custom headlights and tail lights, 24x14 American force jades,37x13.50x24 Toyo mt, 1" borla wheel spacers, 30" lightbar, new build so more to come come
    I have this same lift..didnt get 3 inches though:(
  6. Dec 18, 2012 at 6:28 PM
    Snorkie
    Snorkie JEEP LYFE
    Jeep
    Rubicon
    Prius
    It's very easy.
    1. Remove wheel
    2. Remove 4 bolts from bottom balljoint
    3. Remove bottom bolt from shock
    4. Remove top 3 nuts from top shock plate
    5. Disconnect sway bar from bottom control arm.
    After this you can pull the spindle back and out and the shock will come out.
