spacer lift and 5100???
Discussion in 'Suspension' started by 225nontypical, May 3, 2010.
  1. May 3, 2010 at 2:34 PM
    225nontypical
    225nontypical [OP] ????????????
    backwoods
    11 tundra DC TRD OffRoad
    bilstein 5100's weather tech floor mats katskinz leather heated seats
    OK i am a little slow and my mind is numb from reading. so here is my question.
    i put a 3" (tuff coutry) spacer lift with AAL on my 2010 DCLB. would i gain anything by also changing the shocks to the 5100??? would that be a waste of money?? also with the spacer lift do i need to worry about the uca??? should i have changed that out also?????
    i am confused by it all. is there any problems with the stock drive line with the AAL????
    here is a link to the lift i have.
    http://www.tuffcountry.com/suspension-kit/toyota-tacoma-2005-06-lift-kits.html
    thanks for the help
  2. May 3, 2010 at 2:48 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    Not worth it you are already limiting your coil travel with the spacer, if you put 5100's on and set them to a higher setting it would be a horrible ride
  3. May 3, 2010 at 6:51 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    If you get the 5100's you would be better off ditching the spacers and setting the billys to 2.5". That's a much higher quality lift than the spacers.
  4. May 3, 2010 at 9:19 PM
    225nontypical
    backwoods
    would i need to change the UCA? what else would be involved with using the 5100 over the spacer. should i have changed the UCA with the spacer lift?
  5. May 4, 2010 at 6:18 AM
    TexasTacoma37
    You only need to change the UCA if the shop can't get your alignment right. The new UCA puts the geometry closer to stock.
