spacer lift idea. opinions?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SargeSlapnuts, Feb 1, 2011.
  1. Feb 1, 2011 at 7:56 AM
    SargeSlapnuts
    SargeSlapnuts [OP] SargeSlapnuts 보고용의!!!!
    Nick
    alpharetta, GA
    2004 TRD 4x4 converted PreRunner SR5 lifted l
    255/85-16 tires, front push bar w/9000lb winch, driver and passenger windows tinted to match factory rear tint, quick at home spray on bedliner, hid's, lifted with 3"toytec rear lift kit and ome front lift, locked with powertrax, and a cb radio in place of ash tray, fog light mod, diff breather mod, greasable shackles, Home made Baja Rack, "extra" bright reverse lights. also converted to 4x4 safari snorkel
  2. Feb 1, 2011 at 8:47 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    I'm confused where does that all mount up? If it really does increase travel (which it won't) you still have over extension issues of alot of other parts. Save up and do it right
  3. Feb 1, 2011 at 8:55 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    No.
  4. Feb 1, 2011 at 8:57 AM
    SargeSlapnuts
    Nick
    alpharetta, GA
    well the shock extender would keep the shock from over extending by making the shock attach at the bottom of the spacer instead of the top. the polyurathane bump stops would replace the oem rubber bump stops on the lower control arm to avoid bottoming out the shock. this is all just theory right now. not sure if wanna put all that money twoards to find out it doesnt really solve the issue. it might possibly work though.
  5. Feb 1, 2011 at 9:01 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    I just ditched my spacer lift and what a world of a difference! I guess spacer lifts aren't all that bad if you don't wheel
  6. Feb 1, 2011 at 9:01 AM
    JDMcQ
    For starters, you r front shocks do not attach in that manner. They are actually strut assemblies with the top spring seat attached directly to the strut. Even if it would work, you would be overextending the top of the strut assembly and hose extensions would likely snap off rather quickly.
  7. Feb 1, 2011 at 9:04 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x2...I just looked at those links...
  8. Feb 1, 2011 at 9:05 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    .........and you loose up travel.
  9. Feb 1, 2011 at 9:26 AM
    SargeSlapnuts
    Nick
    alpharetta, GA
    alright well that pretty much settles it for me that this is a bad idea. how about some ome's will they work with stock front struts? more concerned with over extsion with the ome's on stock struts
  10. Feb 1, 2011 at 10:31 AM
    Di Trut
    Di Trut Well-Known Member
    Stop thinking about taking shortcuts with your truck. This is a bad idea, and if you get lift coils, you should be getting new shocks too.
    If you're that dirt poor, you shouldn't be lifting your truck and putting lockers in it anyway.
  11. Feb 1, 2011 at 10:54 AM
    SargeSlapnuts
    Nick
    alpharetta, GA
    well the way i see it if i can manage to put the right items in it ill then be able to make more money. . . i.e. cleaning up remote property, yanking stupid highscholl kids outta mud and so on and so forth.
  12. Feb 1, 2011 at 2:34 PM
    malander
    max
    01 limited trd 4x4
    You won't make money doing that shit unless you're a total dick who isn't willing to pull out some stuck cars/trucks out of the goodness in your heart. It sucks to not have money believe me. It took me 8 months to save up for my lift and there are still things I have to redo. Save your money
  13. Feb 1, 2011 at 2:45 PM
    SargeSlapnuts
    Nick
    alpharetta, GA
    for people that just genuinely need help i help them for nothing. but up here where i live which by the way is one of the richest towns on the east coast alot of these little kids are freaking rolling in mommy and daddy's money. i see nothing wrong when some one is in much better standing than me and offers to throw me some cash to tug em out.(which gets offered quite often) relax i feel some built up tension here dood. im just a college kid willin to work for a few bucks here and there. im not the kinda guy who is gonna just drive by some one on a trail who is buried without at least offering to help (for nothing) cause i have had some random people do that for me.
  14. Feb 1, 2011 at 3:02 PM
    malander
    max
    01 limited trd 4x4
    No tension here man, I'm just having trouble seeing how all of this will work out. I live in an area where people don't do incredibly dumb shit with their parents cars so I don't know how that works out over there. If you have been offered some money to pull out cars and trucks I would look around, do more of that and use that money to save up for some bilstein 5100s and an aal. The nice thing about that set up is that later down the road you can upgrade to new springs and reset the bilsteins to 0" of lift. Your truck will be fine in stock configuration for pulling out the occasional stuck car or truck. That sounds like a pretty good area to be in if you want small jobs an what not as well
  15. Feb 1, 2011 at 3:14 PM
    SargeSlapnuts
    Nick
    alpharetta, GA
    im either thinking about doing that or just saving for like the few months and see if i can just pick up a complete ome lift kit in one shot.
    i know it seem odd that so many people would be that dumb around here but here is a funny statistic in the paper about a week ago that alpharetta has some of the highest drug traffic in the southeast. prolly cause everyone has alot of money and nothing to do around here.
  16. Feb 1, 2011 at 3:18 PM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    i got my lift for $400:D with all new shocks and add-a-leaf:p
  17. Feb 1, 2011 at 3:21 PM
    SargeSlapnuts
    Nick
    alpharetta, GA
    dam where did you get and what set up/parts did you pick out???
  18. Feb 1, 2011 at 3:25 PM
    tacosupreme54
    tacosupreme54 Well-Known Member
    NW GA
    Off-Road 4x4 SR-5
    OME 885's, 90000 and n182 shocks, CB drop, 295/75/16 Hankook Dynapro MT RT03's, 16"x8" Pro Comp 7089 wheels, Avid Off Road Light Bar, Magnaflow 12226-14'' Muffler dumped after axle, color matched grille, Team Realtree camo seat and steering wheel covers, Husky floor liners, towing hitch, bed extender, Tacoma bed mat, all black emblems, black sockmonkey decals, bedlined rear bumper.
    that one. do it right the first time. so many people on here don't listen and get spacers or something cheap. eventually they end up having to redo it the right way or get used to the shitty ride. so save yourself a few hundred bucks by waiting and saving what you can until you can afford a real lift, not a couple of pieces of metal that push your truck up higher.
  19. Feb 1, 2011 at 3:27 PM
    SargeSlapnuts
    Nick
    alpharetta, GA
    the ride wouldn't bother me its just fear of bending the piss out of my front struts that i was more concerned about. ride wouldn't matter but breaking shit does
  20. Feb 1, 2011 at 3:31 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    that's what i said too. but trust me, after a few months of driving on it, you will get sick of bracing yourself for impact every time you get near a pot hole or drop off. i got spacers before i knew about tacomaworld. i wish i had become a member sooner so i could have had someone tell me not to get them.
