Spacer Lift kits vs Spindle Lift kits
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Socal00711, Jan 8, 2012.
  1. Jan 8, 2012 at 3:25 PM
    Socal00711
    Socal00711 [OP] Active Member
    Ralph
    So Cal
    07 prerunner SR5 TRD sport
    DIY and modified Relentless Two Piece kickout sliders,6000 hellas in custom grill. 4"MT spindle lift with 5100 bils set at 2.5. rear 3"angle blocks with 5100 bils long shocks 2" over stock, Home fab front bumper, modified Trail Gear rear tube bumper, Hidden license plate. Home fab speaker box and amp mount, D.O.T. approved blacked out head and tail lights. Weather tech front window vent shades,
    Ok, This is my first post, and yes I am a new member. But have been comming to the sit for awhile. I recently sold my 99' tacoma prerunner and picked up a 06' Tacoma Prerunner SR5 TRD access cab. As the title says, point me in the right direction. I am looking for feedback from members who have 4"spindle lift with 2" rear blocks, and 3" spacers w/1.5 rear blocks. What is the best for the trucks sake. Thanks in advance, and yes I am glad to be a member, alot of great resources and rides...
  2. Jan 8, 2012 at 3:28 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    The two kits couldn't be more different. Spindles are pricey, but keep all your geometry and ride stock. They don't hurt the truck or the ride, in any way.
    Spacers are cheap, and depending on the type, they either make the ride very stiff, due to preloading the spring while still using stock shocks, which are not designed for stiffer springs, or they extend the stock shocks, rendering the bump stops useless, and leading to ball joint damage at fool droop.
    As for the blocks, those lead to axle wrap. An add a leaf would be a much better option for the rear.
  3. Jan 29, 2012 at 10:23 AM
    07tacos
    07tacos Well-Known Member
    Raul
    Sacramento
    07 4x4 Debadged
    Bilstein with 2" spacers, Bull bar, Black valence, Mini H1 Retro 6000k, Chevy 2500 leaf packs
    Hey Im in the same boat. I have 2" spacers on the front and AAL on the rear. I have bilstein all around as well. I have some sag in the rear especially when accelerating.I want to level out with blocks what size would you recommend? Ive read that some will do 2" spacers in the front and 2" block in the back and I noticed other will do 2" in the front and only 1" in the back. I dont get which set up is better.
    Also if you arent doing mad offroading but are shooting for a nice look does it really damage (axel warp) your truck that much if you use blocks?
    thanks and sorry not trying to steal thunder from OP
  4. Jan 29, 2012 at 10:29 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
  5. Jan 29, 2012 at 10:30 AM
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    Get spindles, I have the Camburg 4" Spindles and LOVE THEM!
