Spacer lift Thoughts
Discussion in '1st Gen. Tacomas (1995-2004)' started by saweetlou, Oct 1, 2010.
  1. Oct 1, 2010 at 6:02 AM
    saweetlou
    saweetlou [OP] Well-Known Member
    Guelph Ontario
    TRD Stepside
    2in Skyjacker
    What do you guys think about the 2 0r 3in front coil spacer lifts, I dont offroad so much anymore, I just like my trucks lifted.
    I see them on e-bay for 60 bucks.
  2. Oct 1, 2010 at 6:10 AM
    TacoNinja12
    TacoNinja12 Well-Known Member
    Boone NC
    99 2.7L SR5
    3 inch lift
    well thats what i have, and its a stiff ride, i wish i got some more expensive stuff, i also have blocks in the back and its miserable on a gravel road. i say if its worth doing save money and do it right even if you dont offroad much. its hard to take a girl out on a date when every speed bump makes her hit the roof
  3. Oct 1, 2010 at 6:14 AM
    saweetlou
    Guelph Ontario
    TRD Stepside
    2in Skyjacker
    So does the spacer actually compress the coil.
  4. Oct 1, 2010 at 8:07 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    There are two different places you can put spacers. On the top of the assembly or inside of the coil assembly. Do some research to find out the pros & cons of each. Personally, I would AVOID top plate spacers.
    Top plate spacers do not compress the coil.
    Spacers inside the coil assembly will compress the coil and make for a stiffer ride.
  5. Oct 1, 2010 at 10:19 AM
    saweetlou
    Guelph Ontario
    TRD Stepside
    2in Skyjacker
    Ah I see so I do want the top mount to raise my front end and maintain ride quality.
    So what would the point be of compressing the spring other than to ruin the ride.
  6. Oct 1, 2010 at 10:36 AM
    Janster
    Jandy
    Lancaster, PA
    Because top plate spacers can cause damage to parts of your suspension.
    Search for it....lots of threads about it already.
  7. Oct 1, 2010 at 11:24 AM
    MaTt98
    MaTt98 Well-Known Member
    Medford Or.
    96 4Runner SR5 V6
    Runner SR5, xeon headlights, 6inch kc spotlights, cb in ashtray mod, roof rack, 2.5 inch lift in front with dodge 1500 coils in the rear and skyjacker shocks
    i have a 2.5 in spacer on mine that mounts to the top of the top plate it rides just as good as it did stock
  8. Oct 1, 2010 at 12:18 PM
    Anthony250
    Anthony250 Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    I heard the top plate spacer hurts CV's but on the 5 Lug models. Im gonna get a 2.5'' lift top spacer for my 99 tacoma 6 lug. Plus i dont have a spring compressor
  9. Oct 1, 2010 at 3:42 PM
    MaTt98
    Medford Or.
    96 4Runner SR5 V6
    it doesnt seem to effect the cv on mine but its a 6lug
  10. Oct 1, 2010 at 7:39 PM
    trd7
    trd7 4wd tacoma
    Tyler
    Columbia, SC
    95.5 Tacoma 4x4 4cyl auto
    AEM air intake
    my buddy has a 2.5 spacer lift and his rides fine. just don't forget to get an alignment ;)
  11. Oct 1, 2010 at 7:44 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    any lift in front if high enough will damage cv boots if front diff is not lowered some bit. i personally like top mount spacers, just cuz they are easier to install. not a harsh ride, do not compress the spring. shock travel remains at factory spec. spring bound/rebound is not altered as much as the other type spacer (spring spacer). the spring spacer forces the spring to far from the limits of the shock when fully extended. too much stress.
    idk thats my opinion. im just saying.
  12. Oct 3, 2010 at 8:33 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    it rides fine, but i am deffinatly going to upgrade to a more quality lift in the future. i stayed away from blocks and put on a set of 1.5" shackles on mine to give it a nice level stance! I am also runnin 265/75/16 mastercraft MT's
  13. Oct 3, 2010 at 8:51 PM
    Janster
    Jandy
    Lancaster, PA
    Shock travel is extended farther than spec because you've lowered the entire assembly. This is why the top plate spacers can be bad - especially if you offroad and stretch the suspension. The front suspension will droop too far, can cause damage to balljoints & the upper A-arm/steering knuckle can hit the coils.
    If you strictly drive on the street and don't 'stretch' your suspension - you're probably OK with a top plate spacer. Just don't quote me on that. Balljoints might not like it.
  14. Oct 3, 2010 at 8:58 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    just get some billy 5100s those are about 100 ea
  15. Oct 3, 2010 at 10:10 PM
    tacos89
    tacos89 Well-Known Member
    Mout Holly NC
    2007 TRd Sport
    Intake
    this!
    will be buying some tomorrow :)
  16. Oct 4, 2010 at 5:01 AM
    saweetlou
    Guelph Ontario
    TRD Stepside
    2in Skyjacker
  17. Oct 4, 2010 at 10:14 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    5 Lugs don't have CVs...
