Spacer lift vs. suspension travel
Discussion in 'Suspension' started by aww1970, Sep 29, 2008.
  1. Sep 29, 2008 at 1:43 PM
    aww1970
    aww1970 [OP] Well-Known Member
    2009 Tacoma TRD Long Box
    Reading as much as I can before I lift my truck am I coming to the right conclusion that whatever ammount you lift the front of your truck with a spacer lift you are losing that much in suspension travel?
    This also goes for using the Bilstein 5100's?
    Thanks.
  2. Sep 29, 2008 at 4:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You loose that amount in down travel. 3" lift = 3" less down travel you will have.
  3. Sep 29, 2008 at 7:38 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What chris said pertains to the front suspension - as that's the biggest limitation on these trucks. IFS
    The rear is a whole different ballgame. Lifting the rear should give you more suspension travel, however, that'll depend on how you lift it.
  4. Sep 29, 2008 at 7:40 PM
    sooner02r1
    sooner02r1 Well-Known Member
    That is correct with a spacer lift. The question is though, do the 5100s allow more droop than the stock shock? The stock shocks top out before the ball joints bind so if the 5100s allow more droop than the stock shock, which would depend on what height they are set at, then you may not lose any or could gain a small amount. I have 5100s but honestly don't know the answer, I didn't cycle the front before I put the springs on. Either way it's a cheap front setup (5100s are much better than spacer though), and it is a temporary setup for me until I can pull the trigger on some coilovers.
  5. Sep 30, 2008 at 7:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    5100's have the same travel as the stock shocks. The only shocks that are a direct replacment, other than coilovers, that have a longer stroke than stock are the OME's. :)
  6. Sep 30, 2008 at 10:46 PM
    sooner02r1
    If I'm wrong I would like to see proof, cause I don't wanna be spreadin the wrong info, but I have heard from a Bilstein tech that the 5100s travel more than the stock trd shocks.
  7. Sep 30, 2008 at 11:16 PM
    random hero
    random hero Active Member
    01 "pre" 4runner
    Saw's, 2.0 fox 8" travel rear shocks, downey coils
    Where did you find this info on the bilsteins???
  8. Oct 1, 2008 at 5:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I sent an e-mail to Bilstein asking about them. I considered them before I went with OME's. I was looking for a shock with more stroke, and a bit longer travel. The response I received from Bilstien said that the 5100 front shocks were a direct replacement for the OEM, and they had the same stroke, and travel. They said they had a larger diameter for better cooling, and some other stuff I dont remember off hand.
  9. Oct 1, 2008 at 6:43 PM
    random hero
    01 "pre" 4runner
    Dang, i did not know that.. learn somthing new everyday!
  10. Jul 6, 2009 at 11:35 PM
    doc151
    doc151 Active Member
    Doc
    Central U.S.
    09 Prerunner
    Cumburg 4" lift
    Ok everyone we need to stop and think a min , if you lift the front with new coilovers or spacers you are changing the angles of all the ball joints and that WILL shorten the life and the travel of your front-end , So the best lift that I can see for the money would be camburg , do to the fact that you might not even have to have an alignment. Just my opinion , but I have talked with 4-5 suspen companies . and they agree , so take it for what its worth...
  11. Jul 7, 2009 at 5:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You need an alignment after any lift.
  12. Jul 8, 2009 at 11:26 PM
    doc151
    Doc
    Central U.S.
    09 Prerunner
    Cumburg 4" lift
    If you don't know what your doing , mine was perfect when I finished.
  13. Jul 8, 2009 at 11:51 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    anytime suspension geometry is changed an alignment will be required.
    In lifting a truck you lose camber and you're wheels will look something like this....
    welcome to TW:)
  14. Jul 9, 2009 at 5:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If yours was "Perfect" after a suspension swap, then you didnt lift it, or it was screwed up before you did the lift, and the lift brought it back into alignment.
  15. Jul 9, 2009 at 6:01 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    +1- Mine DROVE fine- No wandering at all...but at anything more than 1/4 turn of the wheel over 5 mph the tires were scrubbing/squealing something horrible...
    You might not have noticed the issues- but they were there. Or like Chris said-It was off before and the lift managed to be the right thing to fix it.
