Spacer Lift
Discussion in 'Suspension' started by abcdef, Jan 7, 2015.
  1. Jan 7, 2015 at 10:48 AM
    abcdef
    abcdef [OP] Member
    I'm looking to put a little lift on my Tacoma. I have the 2014 Tacoma TRD Sport. any suggestions on a lift. I don't have a big budget for the lift.
  2. Jan 7, 2015 at 10:51 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    What's your budget? I wouldn't put a $200 lift on a $34K truck :crazy:
  3. Jan 7, 2015 at 12:18 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Will you be off-roading or mall-crawling?
  4. Jan 7, 2015 at 12:24 PM
    Aw9d
    Aw9d That one guy
    Spacers = bad everything about them.
    You have a 2014 truck, save up and put some decent parts in it.
  5. Jan 7, 2015 at 12:33 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Budget?
  6. Jan 7, 2015 at 12:35 PM
    T4RFTMFW
    5100s up front and rear block OR single AAL is an inexpensive lift. Cheap? Not as low cost as spacers, but less than $250 in parts.
  7. Jan 7, 2015 at 12:38 PM
    chaz834
    chaz834 Tacoma 4 Life.
    Chase
    Kendrick, Idaho
    2012 Sport MGM
    3'' Tuff Counrty Lift, Moromoto Mini H1 Projectors 5000K 35W, BHLM, 30'' LED Light Bar, Black TOYOTA Emblem, Excelon Touch Screen Deck, Hertz Speakers,Excelon AMP, 2 10'' JL Audio Subs, Wet Okle seat covers, Weather Tech Floor Mats.
    I've had a 3'' tuff country spacer lift for 2 1/2 years never had a single problem. I do a little light off-roading here and there. The ride is fine on the road but sucks for everything else that being said I'll be looking to upgrade to the new Bilsteins 6112 series in the near future. If you can afford more get something better than a spacer lift if you can't a spacer lift will work just fine.
  8. Jan 7, 2015 at 4:57 PM
    4x4Active
    4x4Active Well-Known Member
    Saltwater Texas
    '13 Taco DC OR 3" lift stock rims on 33s
    I think only people who have used them should comment. Not heard or saw on some thread.... Or say its "common" knowledge
    I have 3" front 2" rear spacer lift a few weeks after I brought my 2013. I cruise around the beach. Also minor "offroad" to my fishing spots. Do I jump the dunes or flex? No..... Probably over 75% of lift truck you see out there are running spacer/blocks.
    Bottom line. Dont drive like you have a high end lift or long travel and your good to go.
  9. Jan 8, 2015 at 8:06 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Get the bilstien 5100s and put them on the 1.75 setting. Shocks are about 250 and install should be around 200.
  10. Jan 20, 2015 at 7:24 AM
    abcdef
    abcdef [OP] Member
    I've been looking around. Anyone now about the 3" rough country suspension lift.
  11. Jan 20, 2015 at 7:33 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Do the 5100's and call it a day. For a small budget it's a great way to lift your truck. OME coil springs would really help if you had the extra money. I did it to my truck and have been happy...however, if I were to do it again I'd wait and upgrade when I had more cash.
    5100's - about $150
    Rear AAL - about $75
    OME springs - about $160
    Rear 5100's - about $150
    You could also buy $25 shock extenders for the rear and re-use your stock shocks. I have them on mine now because I f'd my rear 5100's. It was supposed to be a temp fix while I ordered new ones but they have worked fine and I'm waiting to do a full upgrade.
  12. Jan 20, 2015 at 8:33 AM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    Dont do a spacer the ride will be like crap on and offroad. It will be quite harsh. Better off stock than with a spacer.
  13. Jan 20, 2015 at 6:22 PM
    blazer190
    blazer190 Active Member
    Walker Louisiana
    TRD offroad 4X4
    I have a 2011 4x4 with a 3" front and 1" rear readylift I have 104,000 miles on this lift with no issues what so ever. The truck is used off-road quite frequently and in very muddy conditions. A good friend of mine has a 2012 with the 5100 set at 2.5" and his rides like a log truck he has often commented on how he wishes his rode as good as mine.
  14. Jan 20, 2015 at 7:27 PM
    abcdef
    abcdef [OP] Member
    What size tires do you have on yours? I'll look into this lift. I like the 3in front with 2in rear.
  15. Jan 21, 2015 at 12:31 AM
    blazer190
    Walker Louisiana
    TRD offroad 4X4
    265-75-16 Kelly tsr 3" front 1" rear leveled the truck.
  16. Jan 22, 2015 at 4:34 PM
    chitowntaco
    chitowntaco Well-Known Member
    Robert
    Chicago
    2015 DCSB TRD Sport
    I had a store today tell me not to spend so much money on shocks and coils use spacers instead. His reasons was because my coils and shock are new and since I only have 1k miles on my 2015. I thought a business would have a better reason and would give me better advise. I'm a newby and want to level my truck but I get so confused with all these options and terms.
