Spacer lifts - How bad are they really?
Discussion in 'Suspension' started by Joaopac, Apr 11, 2018.
  1. Mar 13, 2020 at 9:33 AM
    #41
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    Dirty Harry likes this.
  2. Oct 22, 2020 at 6:05 PM
    #42
    Bears2020
    Bears2020 Member
    Pete
    2020 cement 4x4 TRD double cab
    Cargo lights
    Why are the spacers so bad if you don’t go off rd just for looks? Toyota Dealers push it 3/2 1100 I rather do Shocks at the price
  3. Oct 23, 2020 at 8:00 AM
    #43
    AccuTune Offroad
    El Cajon, CA
    I think we explain it pretty well in that video. Adding an upper control arm and bump stop spacers would help eliminate some of the main issues. At the end of the day, it's up to you and what you needs are.
  4. Oct 23, 2020 at 8:06 AM
    #44
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    You can buy the kits for a couple hundred dollars, which will give you the exact same look and height as spending thousands on suspension parts. To each their own but if I never took my truck off road I would of kept my spacer lift. Dont be swindled into buying a fancy suspension lift.
  5. Oct 27, 2020 at 10:21 AM
    #45
    ELVIS
    ELVIS Well-Known Member
    Paul
    TX
    2020 TRDOR
    my 2/1 spacer lift works just fine on the hightway, beach, and our property.
    coma toy likes this.
  6. Jul 4, 2021 at 12:08 PM
    #46
    unbrokenchain
    unbrokenchain Member
    Black Mountain, NC
    95 Tacoma SX
    So I got a 95 Tacoma sx about a month ago, it's stock except for a heavy winch bumper on the front. The bumper causes the front of the truck to sit about 2" lower than where it seems like it should. I realize that a heavier-weight spring is the real solution here, but I'm wondering if spacers would be ok in my circumstance. I drive a lot of gravel/forest service roads but no serious off-roading.
  7. Jul 4, 2021 at 12:31 PM
    #47
    Running Board Man
    Running Board Man Well-Known Member
    They will do the job but not for long or that well
    unbrokenchain[QUOTED] likes this.
  8. Jul 5, 2021 at 5:11 AM
    #48
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Seems a lot of people run the lean spacer,
    So how much spacer is to much?
  9. Jul 7, 2021 at 12:37 AM
    #49
    Phil61s
    Phil61s Well-Known Member
    N PHX
    2021 Tacoma SR 4x4
    Check out this guy. I'v been researching and came across him in N.Phoenix (Westcott Designs)
    He worked for Toyota for 20yrs, Harley Davision, and Hummer. He designed some of the first off-road after market parts for racing Baja.
    I went with him for my 3" front lift,(lower shock spacer) 1" rear lift. Bilstein 5100's shocks front & rear, (yes, he even had the rear 5100's in stock):thumbsup:
    used stock front springs (I installed air bags for the rear) and used his kit. Do it for yourself, and watch some of his You Tube videos
    Edit: The lift kit I purchased is for "up t o 3" (5 settings) (1 1/2" to 3") mine is on 3rd setting, approx 2" lift
    https://www.youtube.com/watch?v=mgDsi4RSQKQ
  10. Jul 7, 2021 at 12:42 AM
    #50
    Phil61s
    N PHX
    2021 Tacoma SR 4x4
    MTB58, VR812 and AccuTune Offroad like this.
  11. Jul 7, 2021 at 7:09 AM
    #51
    AccuTune Offroad
    El Cajon, CA
    Yea like he mentions in the first video, his design is not your typical "spacer lift". He is technically adding preload to the spring so the shock travel/length is not changing. Simple and cheap alternative to getting a lift.
    unbrokenchain likes this.
  12. Jul 7, 2021 at 10:25 AM
    #52
    coma toy
    coma toy Off Road Taco
    I lifted 2" up front without the spacer. (Bilstein 5100's). Both sides came out even, nor was there lean before I lifted.
  13. Jul 7, 2021 at 10:36 AM
    #53
    coma toy
    Bilstein 5100's recommend you use the stock coils. You will void the Bilstein warranty by not doing so. You did waste your money on the 887's. Also, Ad a leaf ads more weight, when a perfectly good 1" (or less) block in the rear is just fine, ride wise.
    The new OEM TRD lift kit includes a 1" rear block. So for anyone that says a rear block is a bad idea, is shooting you the Bull. Sorry you had to find out the hard way.
    Adding 5100's up front is still far superior to front spacers.
  14. Jul 7, 2021 at 10:47 AM
    #54
    AccuTune Offroad
    El Cajon, CA
    Adds more weight? Do you mean allows for more weight?
    Depends on what you are looking for. If you are after performance and better ride quality, then a block is a bad idea and not doing anything other than gaining you lift height.
    Burns and coma toy[QUOTED] like this.
  15. Jul 7, 2021 at 10:53 AM
    #55
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    :eek::eek::eek::D:eek::eek::eek::eek:
    My 08 had 5100s with stock coils at 1.75 and a 1” block in the rear. Wasn’t bad a little stiff but tighter than stock.
    My 12 was pretty soft but then I had rear leafs replaced with Hd springs.
    3” of rake :eek: wasn’t expecting that!
    Not sure how long I’m gonna keep it the frame will decide before 10/2023.
    I’ve already done more to it than I was gonna seeing it may be a flip!
    Seeing how the lean spacers seem to be accepted here but spacer lifts are not how much “lean” spacer is ok?
    Neither of the trucks had/have much lean so one on each side should be good for a 1/2 inch up front at least.
    Guessing the three studs thread length come into play vs bolting thru to spacer.
    I can make my own spacers and only cost is alignment.
    I got 500lbs in bed and still have 2” + rake.
    It’s like the old days with air shocks on my 69 Malibu.
    coma toy[QUOTED] likes this.
  16. Dec 5, 2021 at 10:35 PM
    #56
    Dhmonkey
    Dhmonkey Member
    Tom
    Missoula, MT
    2018 Tacoma Off Road - DCLB/Cement
    Considering a very similar setup, minus the bags. How are you liking it? Any issues or things u’d do differently? What 1” rear option did you do, spacer block or add a leaf? Would love to see a picture or two. Thanks for your time!
  17. Nov 15, 2024 at 9:09 AM
    #57
    VR812
    VR812 Well-Known Member
    Vincent
    I'm about to install a 2 inch spacer and block because I'm cheap and want to learn the hard way.
