Spacer Lifts Post them Up
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 71tattooguy, Aug 30, 2019.
  1. Feb 16, 2020 at 5:29 PM
    #141
    Navigator1
    Navigator1 Assistant to the Regional Manager
    Spokane WA
    18 TRDORDCLBCEMENT
    The setup he posted was 6112. Assembled they are close to $800 alone. Add the extra hardware and it's not a terrible deal. The Eibachs are more like the 5100s.
  2. Feb 16, 2020 at 5:36 PM
    #142
    Flkracker
    Flkracker Well-Known Member
    2/1 with 265/70
    Navigator1 likes this.
  3. Feb 16, 2020 at 5:39 PM
    #143
    Navigator1
    Spokane WA
    18 TRDORDCLBCEMENT
    If you were originally looking at 6112s I would go that route. They are a serious piece of equipment when compared side by side with a 5100 or Eibach. I have 2nd gen 6112s and started with them on clip 3. I just recently moved the driver side up another notch, added a 1/2" spacer to both sides and JBA UCAs. Rides the same as before.
    71tattooguy[OP] and GreyBaldTaco like this.
  4. Feb 16, 2020 at 6:16 PM
    #144
    enjm10
    enjm10 Well-Known Member
    Eric
    NM
    2020 White Double Cab
    5% Front strip and doors, 20% wrapped around the rest of the truck.
    Just added the tailgate inlays (non 3D), glovebox inserts (non 3D) and tailgate handle overlays, I have the cut files myself so I cut them out. 20200211_065957.jpg 20200215_151536.jpg 20200215_150618.jpg 20200212_164840.jpg
  5. Nov 10, 2020 at 3:30 PM
    #145
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    Would any of you that have added a 1" spacer on top of the coil assembly measure the distance from the top of the top hat to the middle of the lower shock mount hole?
    This can be measured at full droop after lifting the truck to get the front tire off the ground (top of top hat to center of lower shock mount bolt).
    I measured my 2021 TRD off-road in stock configuration at full droop and got 21 3/4".
