Spacer on top of another spacer?
Discussion in 'Suspension' started by caleb337, May 17, 2008.
  1. May 17, 2008 at 9:12 PM
    caleb337
    caleb337 [OP] Lifted Tacoma
    Carencro, Louisiana
    6 inch lift on a 05 SR5 TSS
    6 inch Procomp Lift, 35 inch Mud Terrains.
    I have a 05 Prerunner with a 2.5 inch toytec lift with 2.5 inch spacers, I want to put 33 inch tires on so I wanted to lift it a little more, can I add 2 inch spacers to lift it higher?
  2. May 17, 2008 at 9:21 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    No, bad call. Just get a full 3" lift and that should clear those tires. If not, keep your current spacer and add a 1" body lift. I'm sure there are other options out there, but the one you asked is NOT one of them.
  3. May 18, 2008 at 3:53 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X2
  4. May 18, 2008 at 12:19 PM
    alextreme76
    alextreme76 Well-Known Member
    Tucson, AZ
    05 Reg Cab 4x4 5spd 265/70/16 Rugged Fails
    i say take out the sawzall and you'll clear the tires
  5. May 18, 2008 at 2:10 PM
    caleb337
    Carencro, Louisiana
    I don't want to do any cutting, what about cranking the torsion bar, and how high will it lift it?
  6. May 18, 2008 at 2:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You dont have torsion bars, so you wont get any lift from them. :D
  7. May 18, 2008 at 2:18 PM
    caleb337
    Carencro, Louisiana
    Could I add 3 inch coil springs to it?
  8. May 18, 2008 at 2:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    3" coils springs added to a spacer will make your ride horrible. If you are really searching for more clearance, you may need to lookinto a drop bracket type lift. The addition of a body lift is a sound idea.
  9. May 18, 2008 at 3:05 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Get a 6" lift with a diff drop, problem solved.
  10. May 18, 2008 at 5:13 PM
    caleb337
    Carencro, Louisiana
    Well, I was trying to save some money, the cheapest 6 inch lift I found was $1300, and if I did get a 6 inch, I've heard that I will need new gears and my transmission will die not long after I put the lift on. Are these statements true?
  11. May 18, 2008 at 7:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Gearing is dictated by the size tires you run. Since you are a Prerunner, another option to consider would be some 4" lift spindles. Less than a drop bracket lift. But, if you are going to be running larger than 33" tires you may want to consider re-gearing. :)
  12. May 18, 2008 at 7:17 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    u can run 33's on a 2.5" lift. u will have a lil trimming to do, but it'll work. roxspin has 33's on 2.25" spacers...if u dont wanna trim what u have, the next cheapest route will be to buy some cheap 3" spacers to replace the 2.5's that u have. coils will run way more than a 3" spacer
  13. May 18, 2008 at 7:31 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    Keep in mind also, you won't be trimming metal. You'll have to remove your front mudflaps and probably trim some inner fender plastic.
  14. May 18, 2008 at 8:01 PM
    caleb337
    Carencro, Louisiana
    I defintly won't be going any bigger than 33's, so I guess i'll get the 4 in. spindle lift. :confused: I've never heard of this, can u explain what it is, how much it costs, and what website I can find it at. Thanks it will help a lot.
  15. May 18, 2008 at 8:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I cant remember the name of the lift. Checkout Wheelers off road. I think they sell it. Its a good lift for those of us that have a Prerunner. :)
  16. May 18, 2008 at 8:49 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Spindle lifts are available for 6 luggers?????
  17. May 18, 2008 at 8:56 PM
    The_Hodge
    SC
    the spindles are over $1k i do believe. i cant remember who sells them, but i dont think i ever saw them on wheelers
  18. May 19, 2008 at 4:24 AM
    Janster
    Jandy
    Lancaster, PA
    GOOGLE is your friend....use it and it'll show you lots of things. :thumbsup:
    http://www.google.com/
    Here's a couple off the top of my head.
    http://www.explorerprocomp.com/PDFs/07cat/54-59.pdf
    http://www.trailmastersuspension.com/suspension/toyotachart.htm
    Also - search this forum:
    http://www.tacomaterritory.com/forum/
  19. May 19, 2008 at 1:13 PM
    caleb337
    Carencro, Louisiana
    Procomp only has a 6 in. lift(too much money) and trail masters had only a 3 inch lift, so I guess i'm going to get the 3 inch toytec spacers unless their are any other suggestions... Could I buy the 2.5 in. shocks from toytec and keep my spacers?
  20. May 19, 2008 at 1:23 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Spindle lift, dude. Haven't found pricing but a phone call to the manufacturer is cheap.
    http://www.alliedoffroad.com/4_lift_spindle_2005_tacoma.htm
    Don't go stacking things. We're talking about your safety here. Plus, a little extra for the right solution could save you the cost of a new truck in the long run.
