Spacer on top of another spacer?
Discussion in 'Suspension' started by caleb337, May 17, 2008.
  1. May 19, 2008 at 1:38 PM
    caleb337
    caleb337 [OP] Lifted Tacoma
    Carencro, Louisiana
    6 inch lift on a 05 SR5 TSS
    6 inch Procomp Lift, 35 inch Mud Terrains.
    It says i need a longer brake line, theres no price, and you can't buy it online i just don't want to have to go thru all the trouble, if i can't put a 2 in. spacer on top of my 2.5 in. spacer, then can i replace mine with a 3 inch spacer and add a 3/4 in. top plate spacer to it?
  2. May 19, 2008 at 1:52 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Can't hurt to call the number on the site and ask for a price. Might also want to give Total Chaos a call and see when their offering will be available:
    http://chaosfab.com/product/accessories/05tacoma/86350.html
    I'll reiterate what I said before: Do not stack lifts.
    You should realize that longer brake lines are recommended with that much lift regardless of whether it's from a spindle or some other solution. Brake lines are *easy* compared to installing spacers, coils, spindles, etc. Bleeding the system is the most complicated part, and that's cake as long as you have someone in the cab to step on the brake pedal for you.
    Seriously man, don't cut too many corners.
  3. May 19, 2008 at 2:12 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    u dont need all this shit done to run 33's. if u wanna go higher than 2.5-3" just for shits and giggles, then the only wan to get it will be to add either a body lift to a 3" lift...or a 6" suspension lift itself. there's no stacking of spacers, there's no putting spacers on top of 5100's set to 2.5" of lift themselves....
  4. May 19, 2008 at 2:52 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Guys, if he's so set on stacking spacers then let him do it. We've all given him advice, but he seems to be dead set on doing what he wants. Don't say we didn't warn you, bro.
  5. May 19, 2008 at 3:28 PM
    caleb337
    Carencro, Louisiana
    I defintly appreciate the advice, and i'm defintly not set on getting 3 in. spacers and stacking them. I don't know much about lifts i'm just trying to get as much information as possible, i'll look into some body lifts but i'm not doing just what i want to do, i'm just hearing new information and trying to get the most out of this thread.
  6. May 19, 2008 at 3:37 PM
    The_Hodge
    SC
    u'll be able to run 33's w/ ur 2.5" that u have now. u'll just have to remove the mudflaps and possibly trim a lil extra plastic in the front fenders....cost=$0
  7. May 19, 2008 at 3:38 PM
    caleb337
    Carencro, Louisiana
    Sorry about the misunderstanding, but back to the 3 inch body lift, say i currently have a 3 inch toytec lift with 33 in. tires and then i added a 3 in. body lift to it, would there be any problems or adjustments that i would have to make?
    Thanks
  8. May 19, 2008 at 3:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have seen the extended spindles for arround $800.00. If you dont want a 6" lift, thats the next best thing. Listen to what everyone is saying, Dont stack spacers. :)
  9. May 19, 2008 at 3:42 PM
    caleb337
    Carencro, Louisiana
    The problem I have with keeping my 2.5 in. lift is that my front is 1.5 inches lower than my back which looks bad, that's why i wanted the 3 inch spacers in the front, and I am considering the 6 inch lift because I just love the way huge lifts look on trucks.
  10. May 19, 2008 at 4:15 PM
    The_Hodge
    SC
    mine is almost 1.5-2" higher in the back than the front. i personally like the way it looks b/c it actually looks like a truck that gets used, instead of a mall crawler. but anywho...u can get the 3" spacers or coils, 4" spindles, or the full 6". u can do the body lift too, but w/ those i think u'll need to extend fuel tank lines, brake lines, steering shafts, etc w/ that...not 100%...but it wont fix ur 1.5" difference front to rear though
  11. May 19, 2008 at 7:01 PM
    caleb337
    Carencro, Louisiana
    :confused: 2.5" Front Spacers & 2" Blocks + TSB and Toytec Shims, Black Daystar Shock Boots
    What's tsb,toytec shims, and shock boots?
  12. May 19, 2008 at 7:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    "TSB" is the new "acronym" for the rear TSB springs on the new Tacomas. "Toytec shims" are to re align the drive shaft to the pinion. And "shock boots" are probably what he replaced the factory ones with. :)
    Oh, and the 2" blocks are used for lift in the rear.
  13. May 19, 2008 at 7:08 PM
    The_Hodge
    SC
    ding ding....chris gets...ummm....his pic on the top right of the page...lol
  14. May 19, 2008 at 7:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :rofl::rofl::rofl::rofl:
    Im cryin......LOL
  15. May 19, 2008 at 7:34 PM
    #35
    caleb337
    Carencro, Louisiana
    my bad for askin, u guys r givin me a hard time as it is
  16. May 19, 2008 at 7:37 PM
    #36
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Dont get the wrong idea. I was giving you the answer. Not messin with ya. We are all hear to help out and have fun. :)
  17. May 19, 2008 at 7:55 PM
    #37
    The_Hodge
    SC
    i was just joking w/ chris for answering for me....
  18. May 19, 2008 at 8:06 PM
    #38
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    TSB= Technical Service Bulletin, referring to the corrections to the rear suspension on some late model Tacomas
    Shims=chris covered those already
    Shock Boots=the little rubber accordian looking things that cover the shaft on a shock. You can order them in different colors.
  19. May 20, 2008 at 6:47 AM
    #39
    mjp2
    NJ
    We give EVERYBODY a hard time. :p
  20. May 21, 2008 at 5:24 PM
    #40
    in2nite
    in2nite Well-Known Member
    James
    SoCal.
    blk 07 prerunner
    Engage Offroad L/T front and rear, Kings and 50t pack, Hella 4000's, Pro Comp Wheels and tires
    www.amsuspensions.com just released there spindles within the past few months.. I think they were around 600.00.
