Spacer or preload for lean compensation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Peen, Jun 21, 2020.
  1. Jun 21, 2020 at 1:34 AM
    Peen
    Peen [OP] Member
    Dean
    2016 Tacoma limited
    I have an Eibach pro lift set to the top setting of 3 snap rings and the icon add a leaf and am currently sitting high up front and tilted left an inch due to the infamous lean.
    my question is, would I be better to drop the front down to the middle snap ring and put the spacer in the front driver coil over; or would it be better to set the driver side down one snap ring, and the passenger down 2 snap rings to the bottom setting?
    I saw a few threads similar but there all with nicer setups than mine and have actual threads rather than snap rings? Would change the preload in just one side up front be a good idea or not?
  2. Jun 21, 2020 at 7:50 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    You should go over to the Eibach thread and chat with members over there they will help for sure
