Spacer question (w/pic)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gasturbine, Aug 29, 2015.
  1. Aug 29, 2015 at 11:03 AM
    Gasturbine
    Gasturbine [OP] Well-Known Member
    Central Ohio
    2011 Regular Cab 2.7l 5-speed 4WD
    32" BFG KO tires on MT rims, Front lifted 2", N-Fab 12,000lb front pull point w/10,000lb red clevis, mud flap delete, tail pipe delete, 20" LED light bar, 2 Hella 500s, N-Fab light bar mount, tinted windows.
    Okay, I ordered 2" spacers for the front of my taco, but when they came in the mail today, they measure exactly 1". Are these the correct spacers for a 2" lift? Does it end up being 2" through suspension geometry, or did they send the wrong ones?
  2. Aug 29, 2015 at 2:07 PM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    They lift the truck 2X their thickness.....Really.....
    Arcticelf likes this.
  3. Aug 29, 2015 at 2:08 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    They are correct.
  4. Sep 4, 2015 at 5:32 AM
    Gasturbine
    Central Ohio
    Thanks guys...got'er done! But hey, should I get it aligned now?
  5. Sep 4, 2015 at 5:54 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Ummm... yeah.
  6. Sep 4, 2015 at 6:43 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Have alignment checked. I put a set of top plate spacers on a truck for a friend a few weeks ago. We knew it was out of alignment going in, but imagine the surprise when we had the alignment done and the spacers brought it as close to "spec" as you can get one. Point is, ANY lift will CHANGE alignment, and one in a million change it to where it's supposed to be. Very rarely will you ever stumble on to even a brand new truck where the alignment is perfect.
  7. Sep 4, 2015 at 10:12 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    but really.... spacers. do it proper with a set of 5100's.
  8. Sep 4, 2015 at 10:13 AM
    la0d0g
    running for the hills
    For crawling not hauling
    Lolz. If he was doing it 'proper' he wouldn't use 5100s either.
    Justinlhc likes this.
  9. Sep 4, 2015 at 10:15 AM
    Gasturbine
    Central Ohio
    Thats right. I dont go off-road, and just needed to clearance some rubbing tires. Why spend hundreds more to accomplish the same effect? :facepalm:
  10. Sep 4, 2015 at 10:22 AM
    medic2230
    Murph
    Bama! Roll Tide
    Because someone's going to come in your thread and tell you that your truck's gonna blow up cause it has a spacer lift on it. lol
    Justinlhc and oafMUNN like this.
  11. Sep 4, 2015 at 10:24 AM
    nd4spdbh
    SoCal
    much more proper than being able to bottom your stock shock before hitting bumpstop by going over a simple speedbump while mall crawling.
    see above ^ .... and hundreds.... you can get a set of 5100s for the front for ~ 170 .... aluminum strut spacers are 130ish....
  12. Sep 4, 2015 at 10:34 AM
    Gasturbine
    Central Ohio
    My spacers were $34.
  13. Sep 4, 2015 at 10:35 AM
    medic2230
    Murph
    Bama! Roll Tide
    Boom Bitches.
    Justinlhc and ThunderCookies like this.
  14. Sep 4, 2015 at 10:44 AM
    Gasturbine
    Central Ohio
    Sounds like somebodies butthurt, because someone spent way less money, than someone else, while achieving the same result. [smile]
  15. Sep 4, 2015 at 10:46 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Spacers are still a turd if you want them for actual functionality, and don't care about ride quality, but if their for aesthetics then who cares. I can't imagine 5100's are that much better for anyones suspension if they are running stock coils, especially the way people jack them up to the highest settings.
    medic2230 likes this.
  16. Sep 4, 2015 at 12:23 PM
    nd4spdbh
    SoCal
    my 5100's have been great but i have them at 1.75in. 200mi off road through the desert just recent and they were nice and smooth, i would of most definitely come back with a bent or broken shock had i been running spacers however.
    To each their own. Good luck OP.
