Spacer Question
Discussion in 'Suspension' started by 4x4runner2002, Oct 6, 2010.
  1. Oct 6, 2010 at 9:18 AM
    4x4runner2002
    4x4runner2002 [OP] Well-Known Member
    Zach
    2002 4x4 limited
    suspension and armor
    I have the OME 3" lift with the Total Chaos UCA and i have the rugged trail black baja toyota rims with a 285/75/16 BFG all terain ko. I am having a rubbing issue. Without any wheel spacers i rub on the uca at full turn. with a 1.25" spidertrax i hit the cab mount when turned and going over a bump. I was wondering if there were any smaller spacers that would give me a happy medium. If not then i must chop the body mount and run spacers.
    let me know what u think.
  2. Oct 6, 2010 at 9:29 AM
    dirtytaco2010
    dirtytaco2010 Well-Known Member
    south lake tahoe, CA baby
    SR5 TRD Sport LB
    custom badging, Black Badges, tint, General AT/2's, nerf bars black, ultra-gauge,toytec AAL, removed mud flaps, Bilstein 5100's @ 2.75, AFE pro dry s air fliter, spidertrax, black rock 17'' wheels
    i think there are 1'' spacers available but not 100% sure. if you find them and buy them I'd be interested in your 1.25 spidertrax if youll be selling them
  3. Oct 6, 2010 at 9:34 AM
    4x4runner2002
    Zach
    2002 4x4 limited
    ya ive been looking and havent found a thing, but if i do ill let u know about the 1.25s
  4. Oct 6, 2010 at 9:45 AM
    dirtytaco2010
    SR5 TRD Sport LB
    sounds good
  5. Oct 6, 2010 at 12:39 PM
    roadrashchic
    roadrashchic Well-Known Member
    Jessica
    boo-kay
    2015 Black TRD Sport double cab
    Engine: K&N filter CAI Suspension: KING 2.5" Rem. Res. Ext. Travel Coilover w/Comp Adj (front and rear). Total Chaos Uni-Ball UCA’s and Deaver J66 1.5" Rear Leaf Pack. Tires: 285/75/16 BFG KO2's FUEL WHEELS D525 REVOLVER MATTE BLACK AND MILLED Exterior: Pelfreybilt sliders and hybrid front bumper/skid Front-runner Roof Rack, slim-line II, bed rack, tent, and 3 INCH LED 16W FLOOD LAMPS, (mounted to the hood via rentlentless fabrication mounts.) WishList: (pending soon..) bushwacker fender flares 40" LED bar winch rear high clearance bumper bigger tent with higher bed rack
    do what I did.. I had 3" lift... rubbed like a mofoe.. so I raised it another 3"
    BOOM! problem solved! :)
  6. Oct 12, 2010 at 2:46 PM
    eltaco
    eltaco Well-Known Member
    Littleton, CO
    '07 4x4 DC Offroad
    I've been trying to find other spacer options for some time with no luck.
    I have almost the identical setup as you, except with Camburg arms. They're pretty much the same thing, and I'm not getting any rubbing, so I'm not sure what's causing your issue.
    Have you had your alignment done?
    Maybe one of us is higher or lower than 3" by a bit...
  7. Oct 12, 2010 at 2:52 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Just do the cab mount chop. I remember seeing a thread on here where someone did a really clean nice job on it.
  8. Oct 12, 2010 at 3:02 PM
    08pretaco
    08pretaco IG @14burrito
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    ^ x2 do it right and enjoy it!
  9. Oct 12, 2010 at 3:07 PM
    eltaco
    Littleton, CO
    '07 4x4 DC Offroad
    Can anyone show me (us) where this thread is?
    We just lifted my buddy's Tundra this weekend, and even though he selected his wheels based on other's input... Houston, we have a problem.
    The local 4x4 shop wants $600 (6-hrs) to do these cab mounts, but it doesn't seem to me that this should be more than a 3-hr job. Maybe I'm missing something?!
  10. Oct 13, 2010 at 3:57 PM
    4x4runner2002
    Zach
    2002 4x4 limited
    ya i got the alignment done. my OME have one of the lift enhancer kits so im thinking about taking that out and i found some one inch spacers, so maybe together it will give me enough distance for no more rubbing.
  11. Oct 13, 2010 at 4:02 PM
    eltaco
    Littleton, CO
    '07 4x4 DC Offroad
    1" spacers? Are they hub centric w/ lugs?
    I'm not sure what a lift enhancer kit is...
  12. Oct 13, 2010 at 4:09 PM
    4x4runner2002
    Zach
    2002 4x4 limited
