Spacers- 5100s
Discussion in 'Suspension' started by nytmarecoma88, Jul 1, 2009.
  1. Jul 1, 2009 at 4:32 AM
    nytmarecoma88
    nytmarecoma88 [OP] Well-Known Member
    07 tacoma
    Tonnuea Tint euro Tail lights halo head lights billet grille- black debadged black powdercaoted 17's "knight rider" mod aero turbine exhaust black bull bar multicolor halo fogs
    ok im new to suspension lifts so help me out, a spacer basically just bolts to the top of the strut making it "longer" causing lift, but from what i hear hurting your ball joints, so wut exactly do 5100s do different to not impact ball joints?
  2. Jul 1, 2009 at 4:54 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    They preload the spring so it "sags" less with the weight of the truck which equals lift. But you have not elonged the strut assembly so it doesn't smack your balls.
  3. Jul 1, 2009 at 5:41 AM
    TacoTycoon
    TacoTycoon Well-Known Member
    Justin
    Hayes, VA
    07 TRD Sport 4WD Indigo Ink
    Bilstein 5100 Coilovers, Diff Drop Kit, TSB AAL, 285/70/17 BFG A/T Tires, 17X8 Helo HE835 Wheels, Rear Bilstein 5100s, Dual Flowmaster 50 series, TRD CAI, TRD Front Seat Covers, Rear Suspension TSB, 35% Tint, Redline Hood Struts, MagLite Mod
    yes smacking balls is not good, not good at all.
  4. Jul 1, 2009 at 7:59 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    There are two different types of spacers.
    There are spacers that go into the Coil assembly and require compressing the coil to install it.
    THere are spacers that install ontop the coil assembly - no coil compression needed.
    The spacers that can cause balljoint failure - are the spacers that install ONTOP the assembly. A lot of people install 1/4" spacers (1/2" lift) spacers ontop the coil assembly to correct a lean problem or leveling purposes. I wouldn't install anything larger than 1/4" thick spacer ontop the coil assembly.
    The coils that go INSIDE the assembly are easier on the balljoints than the other spacer types.
    Do some research - use the search button at the top blue bar. Spacer discussions are all over the forum.
    Good Luck!
