Spacers and axle warp?
Discussion in 'Wheels & Tires' started by puddin67, May 6, 2013.
  1. May 6, 2013 at 8:42 AM
    puddin67
    puddin67 [OP] Well-Known Member
    Zach
    Savannah, GA
    04 PreRunner SR5
    Westin bull bar with blacked skid, 6000k xenon bulbs, 2 Almani 12" subs, 1600 w Boss amp, Kenwood head unit, AVS rain guards, removed mudflaps, UWS toolbox, 3/4 debadged, blacked grille emblem, blacked tail lights, sockmonkey 3rd brake light cover
    So I've been lookin into gettin the 1.25" spidertraxx spacers from ToyTec for my 04 Prerunner. A buddy of mine said he had spacers on his old jimmy blazer but they torqued and warped his axles real bad. Has anyone had this problem with their Taco or does anyone advise against this?
  2. May 6, 2013 at 8:53 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Are you referring to blocks for the rear springs? If so, then they will cause axle wrap. Another culprit of axle wrap would be worn springs.
  3. May 6, 2013 at 9:56 AM
    Cactusone
    Cactusone Active Member
    Sonoran Desert
    05 PreRunner Off Road
    BHLM, Sport hood and grill, Deezee side steps painted super white, 5100 w/OME884 and AAL
    I think you are confusing wheel spacers and axel blocks (spacers).
  4. May 6, 2013 at 12:22 PM
    puddin67
    Zach
    Savannah, GA
    04 PreRunner SR5
    Ah yeah maybe he was confusing the two cause I know a lot of guys run wheel spacers and I've never heard of any problems with them so that would make sense. Thanks guys
  5. May 6, 2013 at 6:27 PM
    JdMeF9SiR2
    JdMeF9SiR2 PARTS HOARDER
    Riverside CA
    06 Tacoma
    Wheel spacers shouldn't cause your axles to warp, but they will add stress to your wheel bearings, suspension and steering components. They won't add any more stress than what an aftermarket wheel with the equivalent offset would add, and in my experience I've never had wheel spacers cause any issues on a Toyota even when used in conjunction with extremely low offset aftermarket wheels.
    Overall I don't think you'll have any issues with a good quality 1.25" wheel spacer and a set of OEM or aftermarket wheels as long as your wheel bearings and suspension bushings are in good shape.
  6. May 7, 2013 at 2:52 AM
    puddin67
    Zach
    Savannah, GA
    04 PreRunner SR5
    Okay great, thanks man
  7. May 8, 2013 at 10:05 PM
    JdMeF9SiR2
    Riverside CA
    06 Tacoma
    No problem!
