Spacers for OME lift
Discussion in 'Suspension' started by Garftore, Feb 11, 2012.
  1. Feb 11, 2012 at 1:31 AM
    Garftore
    Garftore [OP] Well-Known Member
    Sam
    Oahu, Hawaii
    '11 T|X, BLACK
    OME 9000s/ TrimPacker/ 886s/ N182s/ Dakars+AALs+Shims, LR UCAs, BakFlip F1 Bed Cover, AMP MotoXtender, FrontBed OEM Tiedowns, PopLock RearCam Tailgate Latch, RFab Steel Bumpers (Front-Full BrushGuard + mounted Warn x8500i, Rear-OEM style) & Welded Kickout Rails, 16" TRD Wheels, 1.25" SpiderTrax, 285/75 Toyo MTs, Chopped Body Mounts.
    ALCON,
    -My Dakars have softened to about a 1.5" lift after a bit of off-roading w/ a 600# ATV in the bed. An RFab Steel bumper will replace the rear soon, too. Estimating a 1" lift for the rear.
    -My 886s are still @ 3". An RFab steel bump w/ full brush guard & mounted Warn x8500i will replace the front, though. Estimating a 2.5" lift for the front.
    Question: What kind/size of top plate spacers & shims will I need to maintain a 3" lift @ both ends?
  2. Feb 13, 2012 at 11:48 AM
    Garftore
    Sam
    Oahu, Hawaii
    '11 T|X, BLACK
    I would like to thank everyone for their input! I'm gonna put 1.5" blocks under my dakars to bring my rear lift up to 3", and 15mm top plates above my 886s. Yeeuh.
  3. Feb 13, 2012 at 11:52 AM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    Do you have the additional OME over load leaf on the Dakars?
    EDIT: OME AAL.
  4. Feb 13, 2012 at 11:53 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You're not supposed to run top plate spacers with 886's , and why not get the OME AAL for your Dakars instead of blocks ?
  5. Feb 13, 2012 at 11:53 AM
    OZ-T
    Peter North
    British Columbia
    It's actually not another overload , but another " regular " leaf
  6. Feb 13, 2012 at 11:54 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Aren't the 15mm spacers the ones OME sells for their lifts to compensate for the tacoma lean?
  7. Feb 13, 2012 at 11:54 AM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    i would think the top plates would keep you at 3", i have the arb and warn M8000 on mine with 886's without the trim spacer and I'm still getting a full 3", and I've had it mounted since june 2011, so i think you'll be fine! and i'd recommend getting the dakar add a leaf before you put blocks, the blocks will really kill your ride!
  8. Feb 13, 2012 at 11:55 AM
    Toy Yoda
    Garrett
    06 DCLB
    i think they sell a trim spacer and a couple other one's for an extra 1/4-3/4" of lift
  9. Feb 13, 2012 at 11:56 AM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    Yeah, you're not supposed to run the top spacers with the 886. Just the trim packer to compensate for the lean.
  10. Feb 13, 2012 at 12:02 PM
    OZ-T
    Peter North
    British Columbia
    No , that's the 5mm Trim Packer
  11. Feb 13, 2012 at 12:02 PM
    OZ-T
    Peter North
    British Columbia
    OME doesn't
  12. Feb 13, 2012 at 12:11 PM
    tbturner47
    tbturner47 Well-Known Member
    '16 Barcelona Red TRD Off Road
    A top plate spacer is different than the OME trim packer. Th trim packer goes underneath the spring, top plate spacers go on top. OME doesn't make spacers, just a trim packer so they do not have to manufacture 2 different springs for each kit. The factory Toyota drivers side coil is longer to compensate for weight.
  13. Feb 13, 2012 at 12:45 PM
    Toy Yoda
    Garrett
    06 DCLB
    yes they do
  14. Feb 13, 2012 at 1:44 PM
    OZ-T
    Peter North
    British Columbia
    99% sure those are just generic top plate spacers , not made by OME as part of their lift system
  15. Feb 13, 2012 at 2:21 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    Toytec website: "Add top plate spacers for a full 3" front lift with 884 and 885 coils." Does not say that they are OME though.
  16. Feb 13, 2012 at 2:26 PM
    OZ-T
    Peter North
    British Columbia
    Same thing , generic top plate spacers , and also note , they only suggest to use them with 884 and 885 springs , NOT 886 springs
  17. Feb 13, 2012 at 2:28 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    Exactly why I posted it.
  18. Feb 13, 2012 at 2:46 PM
    OZ-T
    Peter North
    British Columbia
    :thumbsup:
  19. Feb 13, 2012 at 4:25 PM
    Toy Yoda
    Garrett
    06 DCLB
    hmmm i wonder why they have them in the OME suspension page:confused:
  20. Feb 13, 2012 at 4:41 PM
    OZ-T
    Peter North
    British Columbia
    To add to 884 , 885 springs to get more height . Those springs gain you 2" and 2 1/2" respectively , but some people want a full 3" .
    OME does not make top plate spacers though .
