Spacers or no spacers?
Discussion in 'General Tacoma Talk' started by Agent004, May 21, 2025.
  1. May 21, 2025 at 8:45 PM
    Agent004
    Agent004 [OP] Active Member
    Custom 2004 4door long bed trd
    Simple lift, custom long bed, rack ,and winch with lights
    Does anybody have any thoughts on wheel spacers? Would anybody recommend them or not?
  2. May 21, 2025 at 8:56 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    I don't personally recommend them because either they're just slip overs which will reduce the amount of lug nut thread engagement or the bolt over ones may require you to cut the lug studs. The proper thing is to get a rim with your desired offset. Places that do inspections I heard will make you remove them to pass. Check your local regulations.
    That all said, I've installed many on peoples vehicles. My only suggestions if using the bolt on ones is to
    A.) clean your hub of all corrosion before installing them with no lube under them
    B.) put a little blue locktite on the studs before installing the spacer
    C.) just in case, take off your wheel and retorque them like a wheel.
    I'm not a fan of them personally but when doing the three above mentioned things, I can't honestly say i've personally seen issues with them
  3. May 21, 2025 at 9:03 PM
    Bishop84
    Bishop84 Well-Known Member
    Only time one would recommend them is if the tire is rubbing on a control arm. There's no benefit otherwise, unless you're having issues with work sites having full sized truck tracks.
    Personally I'd never run them, the side of my truck is muddy enough as it is.
    Chew, petethemeat and joba27n like this.
  4. May 21, 2025 at 9:10 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I'd never cut my studs
    I had .75 Bora for a few years and liked the little extra stance with some clean factory alloy wheels. There was a little pocket of space between the lug holes on the alloys (18" 4runner limited) where the studs fit, so I never had to trim them. Aftermarket wheels may or may not have that little cavity
  5. May 21, 2025 at 9:19 PM
    tacomarotto
    tacomarotto Tempus Fugit, Memento Mori
    Jon
    Jacksonville, FL
    2001 DC 4WD TRD 2022 Lexus GX460
    I personally like my wheels and tires inside the wheel-well and with the stock positive offset.
    if you haven’t seen tinkerer’s adventures explanation on fitting larger tires, it’s super eye opening how the geometry works. I’m pretty sure he discusses wheel spacers in this video…
    https://youtu.be/Q7MyN1qOFgs?si=EquI6otac3dONxzF
    Chew and Agent004[OP] like this.
  6. Jun 11, 2025 at 5:00 PM
    Nicholijack
    Nicholijack Well-Known Member
    Nicholi
    2024 Tacoma 6MT
    no. cheap solution and makes the setup less reliable IMO.
