Spacers or suspension
Discussion in 'New Members' started by Milfanator719, Apr 4, 2023.
  1. Apr 4, 2023 at 7:19 AM
    Milfanator719
    Milfanator719 [OP] New Member
    Shayla
    2018 White Tacoma TRD off road manual
    I’m new to the Taco world, well truck world at all! I’m looking to do a 2ish inch lift and level.
    Should I do spacers or a full suspension lift?
  2. Apr 4, 2023 at 7:29 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Suspension lift.
    ToyoTaco25 likes this.
  3. Apr 4, 2023 at 7:57 AM
    stcoffey
    stcoffey Toyota enthusiast
    Indianapolis
    2023 4 Runner TRD Pro Solar Octane
    Agreed I think you’ll be happier with the suspension lift. It’s more money but you certainly get more bang for your buck. If you decide on a spacer lift I would check out Wescott Designs preload collar lift kit. I’ve heard positive things about them and it won’t break the bank. Good luck
  4. Apr 4, 2023 at 8:04 AM
    JoeT4R
    JoeT4R I don't have a Taco
    Joe
    NOVA
    '01 4R, SR5 4WD
    Suspension is the way to go. You will thank yourself in the long run, especially if you intend to keep the truck for a while/and or haul around family or daily drive it. Spacer lifts create more of a harsh ride whereas a suspension lift will give you a better quality ride while being lifted.
    Yes, spacer lifts are cheaper, but saving the money for a new suspension setup is better in the long term. I have firsthand experience with both and will say hands down the suspension lift is the way to go.
  5. Apr 4, 2023 at 8:13 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Devils advocate, you'll be completely happy with a spacer lift. Anyone who disagrees is more than welcome to make a case with the lack of information given in OP's post.
    Simply put, we can't choose for you on limited knowledge of your truck's intended use/budget/etc. My best guess is that if you don't why a spacer would or wouldn't be worse, you don't intend to use it in those ways. So a spacer lift it is.
