Spacers vs. bilstein 5100 shocks at 2"?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Levi12345, May 21, 2013.
  1. May 25, 2013 at 6:49 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    So how would u raise the front axle transfer case skid plate to ground height legitlly?
  2. May 25, 2013 at 8:36 PM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Am I the only one not understanding this question?
  3. May 25, 2013 at 8:40 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
  4. May 25, 2013 at 8:58 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    I have spacers and they suck balls...
  5. May 26, 2013 at 4:29 AM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    SPACERS FOR LIFE!!!
  6. May 26, 2013 at 4:56 AM
    YOTA LOVER
    NH
    SMH
  7. May 26, 2013 at 9:21 PM
    Shawster
    Shawster Member
    I just pulled a spacer lift out of mine last night. Was installed by the previous owner. After some serious issues on the front with the shock bushing being rusted solid to the shock nut, we got the 5100's in. Now I only have mine set at 1.5 inches as I don't run 285's, the ride is night and day. I actually have a suspension again.
    Go 5100's. If you are going to all that work to pull everything out, do it once.
  8. May 28, 2013 at 8:41 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    maybe im thread jacking here a bit but my question is how is using a spacer any different then adjusting the 5100 up? im 5100 and eibachs, 5100's set at .85 putting me at 2.45" of lift but im weighed down with plate bumper/winch. wheel measure is 21.75" so thats only about 1.5" of lift after the weight. i want another 3/4" of lift give or take. what would work best, a spacer or 5100's up another notch? again sorry if im thread jacking. seemed to be the same question the main guy was asking
  9. May 28, 2013 at 11:12 AM
    YOTA LOVER
    NH
    The 5100 is more robust, and can take some abuse. The ride will suffer a little when you crank it up, but it's been designed to handle it.
    A stock strut sitting under a 2" spacer is more likely to bottom out on rough terrain and blow apart or bend where the shock is welded down near the LCA.
  10. May 28, 2013 at 5:28 PM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    That is unless your spacer goes above the coilover, in which case disregard the bold.
  11. May 28, 2013 at 6:53 PM
    YOTA LOVER
    NH
    That's exactly what I was saying, LOL
  12. May 28, 2013 at 7:31 PM
    Buckoma
    Buckeye, AZ
    2016 TRD Sport 4x4
    Exactly! ;)
  13. May 29, 2013 at 6:13 AM
    mightytacoman
    Kel
    4.5L 1grfe
    ok, time to ask the question that makes me feel like a complete noob.
    up the 5100 to 1.7 to get .8" more lift or get this spacer (.75" of lift) ???
    again with the eibachs and 5100 at .85" im only getting about 1.5" of lift and want to get closer to 2.5"
    what would work best? sorry im such a noob on this :(
  14. May 29, 2013 at 6:34 AM
    YOTA LOVER
    NH
    You should've installed the OME in the first place :poking:
    If you use the spacer on top of the C/O you will loose up-travel. If you crank the snot out of your C/O to get as much lift as it'll give you you'll sacrifice ride quality.
    Consider the demands of your truck. If it'll never see any real trail time/abuse then throw in the spacer and be done. if you want the lift and are going to thrash on your truck you had best find a more robust and reliable solution. Reference my opening statement.
