Spacers vs Wheel offset
Discussion in 'Wheels & Tires' started by hud445, Feb 7, 2009.
  1. Feb 7, 2009 at 7:51 AM
    hud445
    hud445 [OP] Member
    Glendale az
    08 TACO TRD DBL CAB 4X4 6cyl
    I understand spacers can be used to aid in decreased tire rub by setting the tire further away fron the chassis. Can the same be achieved by getting a different rim offset?
    What is the maiximum that can be done without effecting the ride/handling?
  2. Feb 7, 2009 at 7:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Most common wheel offset seems to be 4.5" on the second gens. Too much, and you get increased bump steer, and increased wear on the wheel bearings.
  3. Feb 7, 2009 at 8:10 AM
    hud445
    hud445 [OP] Member
    Glendale az
    So then adding a spacer is probably not recommended either?
  4. Feb 7, 2009 at 9:33 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    anytime u do anything other than stock it causes premature wear on many things.some guys r running spacers and many r running new wheels.i think im going with the spacers due to the funds for new wheels.spydertrax is the ONLY spacer to go with if u do that.
  5. Feb 7, 2009 at 9:47 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    4.5 seems to be just about perfect. If you want to run the stock wheels and bigger tires, you'll need the spacers... :thumbsup:
